Question about Lexmark X3470 All-In-One InkJet Printer
Set it up to scan and the scanner simply won't work
Tis is
Posted on Jun 15, 2009
Brother control center 4 won't open on my computer
This may help others with scanning issues:
I just bought a Brother MFCJ6510 printer/scanner and was nearly driven cracked trying to get the scanner to work as it was not talking to the PC, even though as a printer it was working fine. Realised eventually that it was just the Brother Control Centre 4 it wasn't talking to. After hours of re-installing software and updates, etc, nothing worked.
The solution: I went into Control Panel on my PC (I use Windows XP), to the Scanners and Cameras section, and in there the Brother Scanner was visible and could be used from there, Click on it to open the Windows Scanner and Camera Wizard and use that. Further, by right-clicking on it and going to properties I choose the software to start when it talks to the PC. I abandoned the Brother CC4 and set it up to start the Scanner and Camera Wizard if I choose 'Scan to Image' on the scanner control panel, and to open Photoshop if I 'Scan to File' on the scanner. Works fine either way, just make sure you choose the right dpi setting to suit your needs.
Hope this helps somebody else as frustrated as I was.
Apr 17, 2013 | Brother DCP Office Equipment & Supplies
Won't Scan -- "Cannot properly communicate with the scanner"
I think the USB cable is defective or the scanner is failing.
Apr 25, 2017 | Epson Gt-15000 A3 Flatbed Scanner Eu-45
How do I set up the scanner on my HP J3680?
use the CD that came with the printer.it has the full feature software that will enable the printing and scanning capability of the printer.
- insert the disk in the CD-ROM drive - hit install - reminder:do not plug in the USB cable yet unless you are prompted by the installer to do so - after installing the software , make a test print to prove the functionality of the printer. - then we move on to test the scanner -there are two ways to make a scan: 1. click on the solution center icon on the desktop. 2. in the solution center , there are two buttons for scanning: scan pictures and scan document 3. scanned documents are saved under the MY SCANS folder. file path is : my documents or simply documents---->MY SCANS 4.for scanned pictures file path is
my pictures or simply pictures---->MY SCANS
Jun 27, 2011 | HP J3680 Officejet All In One Printer
Hi, i am trying to configure my barcode scanner LS2208 to put a {TAB} in when scanning
There should have been a sheet or book of bar codes that came with your scanner. These codes will allow you to program your scanner to do most anything, including adding a tab. You simply look at the bar codes and read what they do. you simply scan the one that adds a tab and it will forever add the tab unless you re program it.
If you have lost your book/bar code page, you should be able to go to the manufacturer website and download/print a document with the programmable bar codes.
Feb 26, 2010 | Symbol LS2208 Handheld
HP SCANJET 2400 ONLY SENDS ATTACHMENT AND NOT IMAGE TO FAX
It would be best to simply save the scan as a File, JPG, and then simply open it in say Word or the like. and use it that way. You can get software that actually turn you Scanner & Modem into a Fax machine.
Here is a link with a tutorial of how to set it all up..http://www.microsoft.com/windowsxp/using/setup/hwandprograms/printfaxscan.mspx
Feb 08, 2010 | HP ScanJet 2400 Flatbed Scanner
My hp psc 750 all-in -one printer scanner not working
A friend of mine had a HP printer (Not a PSC 750) that he had simply plugged into his computer and was able to print properly but received the "options not set" message when he tried to scan.
The solution was to install the HP driver package for his printer.
If you are using the default Windows drivers for your printer you may need to install the HP driver package to access all of your printers functions.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&custom_solutionid=rd_bpu04809&product=57769
Mar 03, 2009 | HP PSC 750 All-In-One InkJet Printer
I cannot find the scans.
Try using the software provided by canon in your scanner. Set thru that, the path to store the pics at your convenience. Normally if you go to My PC and double click you will see the scanner (icon). Just simply select the icon (left click) and then right click to select the command that you want.
Jan 23, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
Lexmark X3470 All-In-One InkJet Printer Logo
93 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
