Earphone addaptor and wires not connecting
I have scull candy earbuds that are separated from the male adaptor to the wires and would like to fix them
    Problem Solver:
  • 17 Answers
Order replacement 3.5mm audio plug from Digikey (www.digikey.com). It will require soldering.
One example would be http://www.digikey.com/product-detail/en/SP-3501/CP-3502-ND/96987
Posted on Apr 01, 2014
I can't get the scull candy Bluetooth earbuds headset to show up on the pair menu of my galaxy core prime
may not be in 'discoverable' mode after first time pair.
check and do a 'hard reset' or 'forget pair'
Apr 11, 2016 | Radio Communications
Change earbuds
DO YOU MEAN THE FOAM PADS? IF SO MOST OF THEM ARE PINCHED BETWEEN TWO PEICES OF THE HEADPHONES. YOU CAN EITHER SEE IF THERE ARE SCREWS PINCHING THEM, OR THERE IS AN ELASTIC BAND AROUND THE FOAM. YOU MAY HAVE TO STRECH IT INTO PLACE BETWEEN THE TWO PEICES OF PLASTIC.
Nov 20, 2013 | Sumo Aerial 7 Sumo Headphones - Candy...
My gumy earphone popped and i wanna know how to fix it...any tips?
Unfortunately due to the size of the drivers it would be unrealistic to repair. You would have get a speaker from another pair of earbuds and re-solder the connection to the wire.
It would be more efficient and cost effective to replace the earbuds.
Mar 18, 2011 | JVC Gumy Ear Bud Headphone - Peppermint...
How do I fix skullcandy earphones? I think a wire is lose because the sound comes in and out when you move the earphone. How do you open the earphones up to fix the wires? Thank you for you time
I'm sorry to bring you bad news, but the most likely thing is that the copper conductor has become fractured inside the wire. The best you can do is to carefully identify which end of the wire has become broken (it usually happens at an end, where it goes in to an earbud, or a plug) and cut it back to the break, and then pry open the bud, cut back the insulation and re-solder the conductors. This is a pretty involved process, and to be honest, even with all the tools, I wouldn't attempt this. Oh, and plugs are usually moulded, so you can't do it, but if you try to buy a new plug in a store it will cost almost as much as new earbuds.
Feb 03, 2011 | Audio Players & Recorders
Why did my left earbud become silent?
you can make both of the earbuds work. You can open the earbud where the speaker is that you use to hear the musik. Use a soldering iron and a lead. check if the wire inside has removed, fix it back and you will hear sound on both earbuds.
Take care.
Jun 01, 2010 | Sony EX33LPS Headphones
My skullcandy earphones are busted
could be caused by the way you wrap them up the cords should never be wound tightly it causes a short and it just so happens that earphones are made of light weight wiring to make them seem to disapear when wearing them so what to do is instead of winding them when your done simply fold them loosely so to speak
Feb 25, 2010 | Skull Candy Ink'd Stereo Ear Bud...
I have a Wharfedale Slimline MP3 player and I'm
found out that jack size i need is 25mm - and then after searching internet have bought an adaptor that has a 25mm male jack with a 35mm female adaptor on other end - so I can use headphones I've bought .
Nov 13, 2009 | Audio Players & Recorders
Well i have green and black skull candy earphones and the one earphone just died on me today i've trying banging it but that didnt work and I fear I might have made it worse how can I fix it?
It usually isn't the ear bud that fails. It's the wire at the plug. Best bet is to buy a new plug on the end of the cord after cutting the last inch or so off. I recommend 90degree plugs if possible
Nov 12, 2009 | Skull Candy LINK Earbuds Consumer...
I own a Bush RP A3 turntable and radio with CD=need instructions
FIRST READ ALL, then check cables u need, then proceed!
u want to connect turntable to pc - don't need usb
or connect turntable audio-out to radio/cd.player and this combination to pc?
recording on mp3 player is an option, but quality else is much better!
u will need for case 1:
a pc-program called audio-grabber 1.83, downloadable on the inet
a pc with soundcard that has audio-in (3.5mmplug, also used for small microphones
and earphones)
and at least win 2000 on it
the cable connecting turntable and pc(see following)
if turntable has audio-out like
- two red and black-cinch ports (to connect to amplifier/radio)
you need adaptor cable from 2-plug (red/black, male) to 3.5mm audio-in (similiar tor headphones,
male version)
- turn-table has small(3.5mm) or big (6.3mm) earphone-in,
use signal from here, connect tt with pc using adaptor cable
(3.5mm, male + 6.3 to 3.5mm separate adappor (small earphone to fit in big) at one end and
3.5mm, male to plug into pc-soundcard's audio in)
do all the pluggin', then turn on PC, start up audiograbber, turn on tt let play, press record button
in audio grabber, make an test recording, half a minute will do.
now let audiograbber sample theresulting .ogg file to test.mp3 and test-play it with windows media player on your pc
voila une mp3 !
to have every song from vinyl sepatetly as mp3,
record and name it serately in audiograbber, let it sample down to mp3 and enjoy!
u may have to fiddle through audio-grabber's menus and adjust volume, sample rate(quality of mp3)
to your comfort, but now u own legal copies of your vinyls, with still the analog vinyl tickle
and know how to use audio grabber as an recording tool for any music that is played on or put into a pc, incl. webradio other webcasts
please don't stop the music
Jun 18, 2009 | Audio Players & Recorders
128 people viewed this question
 Grubhead
Grubhead
