Question about Refrigerators
Whirlpool gold water filter
Just changed the filer in our whirlpool good side by side;a few days ago. now the water comes out cloudy sometimes. there was no problem until i changed the filter.
  • 40 Answers
Drain few gallons of water, it should clean up.
Posted on Apr 03, 2014
  • 1462 Answers
SOURCE: Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Posted on Nov 26, 2008
dblred
  • 68 Answers
SOURCE: Water Filter
most whirlpools have the filter located in the bottom kickplate, right below the freezer door. turn counter-clockwise and toward you to remove. if it has never been removed before, they are hard to get out the first time.
Posted on Jul 24, 2009
SOURCE: Defrost line blocked and dumps water in front of frig once a day
Double door Maytag. Water frozen in the bottom and leaking onto the floor. Happened before and don't wish to pay the same repair person who "repaired" it 6 months ago to come out again. What can I do?
Posted on Jul 28, 2009
  • 16 Answers
SOURCE: I need to change the water filter
Pull of the bottom panel It should be under the freezer door
Posted on Aug 28, 2009
SOURCE: knocking noise coming from Whirlpool Gold refrigerator
I also have a new Whirlpool Gold fridge (bottom freezer with French doors) and it was making a knocking sound. The knocking sound would start when the fridge kicks in and starts running to cool, and would last for about a minute or less and be a slow knock.
I called Whirpool customer service since it is new and on warranty. They sent out a technician and he said the knocking is from gas/air built up in the copper tubing for the freezer because the copper tubing is too cold, and when the fridge first turns on it forces the air through, making the knocking sound.
His "fix" was to adjust the copper tubing so that it is closer to the heat of the motor/compressor and heat of another copper line so that the cooler line stays warm so the air/gas doesn't build up. His fix worked slightly, but the fridge is still knocking, just not as bad and not as long - it knocks fast for about 5 to 10 seconds instead of a minute.
Going to call customer service again soon and see where to go from here.
Posted on Jan 05, 2010
Chemcial taste in water after changing water filter
Well this never happens with me but surely you might get some unusual result.
Chlorinated Solvents Exporters
Sep 12, 2012 | Whirlpool Gold GSS26C4XXB 26.4 cu. ft....
Skunky water/ice.
It will be good to clean well the full line leading to the filter.Since when the filter is changed you must make sure the supply lines had not been clogged. Now drain out the water for sometime after the new filter is changed as it will have a chemical smell. Flush off for sometime before you can start using. There cannot be any other reason than this , make sure there is no fault in the water inlet line.
Hope the filter that was changed was the original component. Hope you check this out. Good day
Aug 03, 2010 | Samsung RS2630SH Side by Side Refrigerator
No water going thru washer arms
remove the pump screen and, clean the pump
you probably have broken glass preventing the pump impeller from moving
May 29, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
Whirlpool gold makes banging noise
If the refrigerator is working fine the banging noise you hear is the isulation inside the refrigeratior walls that exand and cotract with the change of temperatures. you don t have to worried about it.
Apr 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold Ice Maker Quit Working
IF THE FRIDGE IS COOLING AND FREEZING WITHOUT AND HASSLE THEN YOU DONT HAVE A PROBLEM WITH YOUR CONTROL BOARDS.ALSO IF THE WATER IS STILL COMING OUT THE WATER SIDE OF IT.YOU NEED TO LOCATE THE WATER VALVE AND CHECK IF THE VALVE TO THE ICE MAKER IS NOT BLOWN THAT MIGHT BE THE CAUSE OF THE FRIDGE NOT MAKING ICE.
GOOD LUCK.
MOHAMED
Sep 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Our fridge does not make ice - Whirlpool Gold side-by-side GS5SHAXNT00
Same as others. Whirlpool Gold side-by-side. Water was running yesterday but minimal ice. Now that's gone and I don't even hear the water. Turned on/off the infrared sensor. Still get drinking water, just no ice in the bin. There's a couple cubes in the maker itself when I open the door (which I've closed completely). Help?
Dec 02, 2007 | Refrigerators
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
