Question about Pioneer DEH-P5000UB Car CD/ MP3 Player
SOUND/Audio is horribley muffled and all base.
Pushed a wrong button and cant get the settings back to anything but muffled/base sound. It's horrible! Have been w/out stereo for weeks now. Can not figure it out with the manual or just trying different things. Is there a reset back to original audio settings?? Help! Please
  • 11 Answers
SOURCE: Audio quit suddenly
Sounds Like your pr-amps are shot. You may have incorrectly wired the power lines up. If you are handy with a meter and check the middle legs of the pre-amps and see that you have continuity one way and none the other. If this isn't the case then they are shot or whatever ones dont pass this test. pop them out and order new ones. About $20.00
Posted on Apr 14, 2007
  • 4 Answers
SOURCE: universal home theater remote for Pioneer VSX-305 audio/video stereo receiver
Don't spend a lot of money for a universal remote. Radio Shack has some good buys. I think you are the same person who is having problems with a 305. Get rid of it. You can make a quantum leap at Amazon for less than $200 for a Pioneer.
Posted on Jun 12, 2008
Duncan
  • 218 Answers
SOURCE: PIONEER VSX-1018AH NO SOUND OUTPUT
If this is a new hookup be sure this amp doesn't have pre-out/main-in jacks that may need to be bypassed. Otherwise, maybe look to see if any tape deck buttons are pushed. Good luck.
Posted on Nov 28, 2008
  • 110 Answers
SOURCE: I need help in finding the audio reset button on
remove the face and there has been known to be a little button that is buried and looks flat using a pen or little screwdriver push the button in with unit turned on and hold until reset starts. if no button then disconnect power to the unit. either undo the pos battery cable for a couple of minutes and reconnect or unplug the back of the stereo for a min. and reconnect. hope this helps let me know.
Posted on Mar 04, 2009
welcomejee
  • 10594 Answers
SOURCE: No Sound on TV/SAT setting on Receiver.
Most TV has Audio Out RCA jack at rear and it gives same TV Sound as coming from its speakers.
Hook audio wire red white RCA pins at TV Out and plug these pins to TV/SAT input of receiver. Select TV/SAT input in receiver to get TV program sound coming out from TV.
Hope that info will help you.
Posted on Sep 15, 2009
I have a dell optiplex gx270 and I installed a sound card. It sounded horrible so I uninstalled and removed the sound card. Now, the audio on my computer sound muffled, echoed, like in a barrel. When I...
Your board has ADI(Soundmax) sound. There is no support for Soundmax anymore. You may want to check into why your sound card gives you rotten sound and/or check into another brand/type of sound card. What kind of card do you have and did you get the most recent drivers for it?
Dave
Jul 28, 2011 | Intel 865G Motherboard
Fender Hot Rod Deluxe has very little sound, stuck and need help! Turn it on and all of tubes light up. Has a horrible muffled sound with volume at 5. Master volume can be put to any level, and it doesn't...
Just because tubes light up does NOT mean they are good or working... While heaters not lit are an indication of failure, teh reverse is not necessarily true.
Time to troubleshoot this... Plug a set of headphones into teh preamp out. See if audio there is clean... it will be low level using headphones and ONLY from one side as the output is mono and your headphones are stereo usually... If audio is clean here and not muffled, then problem is in power amp section else in the early stages of the unit.
Report back the results of this test...
Nov 09, 2010 | Fender Hot Rod Deluxe Guitar Combo...
The sound output on my laptop muffles out monologue
it is most likely that somewhere in sound settings you have chosen to us 5.1 or even 7.1 sound system, and you are probably using simple 2.0
in this occasions 2.0 speakers act like rear speakers
Nov 13, 2009 | Computers & Internet
Sound is muffled toshiba 57h81
There is a switch at the back of the set for audio, it is in the wrong position.
Jan 07, 2009 | Toshiba 42H81 42" Rear Projection...
TV has sound, but no Picture
Does your sound go thru the tv or a sound system ??? when ya turn tv off then on does it show anything like its coming on ??
Nov 16, 2008 | Curtis-Mathis CM19011 TV
Philips 28pw6515/05
Hello dan5260,
Your audio processor might be going bad or at least one of the capacitors might had malfunctioned.
We are actually not talking about much expense in fixing this problem. At my shop here how the pricing would go:
Parts: $20.00-$30.00
Labor: $60.00 per hour (1 hour limit) Total $120.00
Starter Fee: $30.00
So total will be about $170.00 - $180.00
This is just an estimate based on my shop, your local shop might charge more or less.
I hope this helps,
Thank you,
Shuttle83
Oct 03, 2008 | Televison & Video
No sound at all
I suggest if your handy , to open the receiver and look for a circuit breaker or a fuse that protects unit of being damage , replace it and turn it on , hopefully it will work .
Apr 18, 2008 | Yamaha HTR-6030 Receiver
Muffled voice track on JVC TH-C5
It's an audio setting you will need to change. some movies are decoded in dolby and some by dts. This means you will have to adjust accordingly depending upon the source of audio in the movie. a double d is dolby's trademark and dts is regesterted trademark for the company "digital theater sound." The icons are on the dvd usually. Anyways, find the set up button on the remote control and use the directional arrow keys on the remote; up, down, left, or right to adjust for best sound. the thc5 will have the most function on the surround settings, movie, music, and all st. try a sequence, than repeat until desired sound is heard... good luck
Dec 26, 2007 | JVC TH-C5 System
Audio Problems With MP3
First thing you wanna do is to try another set of headphones. If it still sounds muffled then theres a fault in the audio output section and these things are non user serviceable. Your gonna need to send back to the manufacturer. Good Luck
Apr 27, 2006 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Pioneer DEH-P5000UB Car CD/ MP3 Player Logo
21 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
