Question about Sony XM-D6000GTX Car Audio Amplifier
I was driving and it just cut off sony xm-d6000gtx
Checked the wires and the out put of the reciver and still nothing i was wondering if you know a if this is a common problemm or an easy fix
 light comes on the amp and my woofers are okay
  • 3 Answers
U should take your amp and woofers to the tip.
Posted on Oct 31, 2007
Switch on bottom of amp?
are you talking about how to turn your amp on and off? if you are then that is your remote wire. it comes from the cd player to the amp. there is no switches on amps to cut it on and off
Oct 22, 2009 | Sony XM-754HX Car Audio Amplifier
Sony Xplod Amplifier Problem
First make sure you are using at least a 12 guage speaker wire for sub connections. Second make sure you have plenty of breathing room in your mounting position, these things need air badly. Third of all, Xplods are not very friendly if they are cranked all the way up on your dB boost knob. Only crank it about 3/4 of the way up, then use your equalizer settings to tweak the thump.
Oct 20, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony xplod amp(XM-1652Z ) power/protect light
if your amp is overheating your sub is needing to much power that the amp doesnt have.
if its cutting out and the red light comes on you need to check the wiring. nothing not even the tinyest speaker wires can be touching.
proper wiring would be your best bet.
but i would upgrade amps.
cheap bang isnt reliable.
Apr 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod 1000W workign strangely
need a bigger gauge hot wire going to your amp ,maybe a battery cap. amp isnt getting enough power to perform so it cuting out.
Mar 01, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony xm-1652z 1000 watt amp
a loose or corroded connection can cause this problem...do not overlook possible loose fuse holder...also look into remote control line...also check speaker line for a loose or shorted connection...a loose connection in any of these locations can cause a spike in the current drawn from the power supply... a bad speaker can play at low volume but short at high volume; if the flex wires from frame to cone on the speaker start to fail, it happens at high volume first, and sounds like a crackle, and gradually becomes present at lower levels; a voice coil can warp at high signal levels, causing it to short intermittently, in addition, you might check the cooling capability of the amp...i don't recall whether you have a fan on this amp...
Jan 11, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier cuts out when turned up loud
The best thing to do is to get a amp that is more watts than your subs, not the other way around, speakers are known to handel a lil more power but amps cant produce more power than they are capable of... your ground wire should be thick also, say 6 to 8 mm or so, and its best to put in a cap and an equalizer.
Cheers
Dec 19, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Audio
Have you checked the RCA leads at the radio? Usually if you not getting sounds one of two things is wrong. 1.Rca leads in the amp are lost or broke.2. Rca cables are bad or pinched and the radio RCA's have burnt out.
Sep 29, 2007 | Sony XM-D6000GTX Car Audio Amplifier
Amp
The remote wire from the amp is connected to a blue wire behind your head unit. This is a power antenna activation wire; it's only active when the tuner is selected. Switch the remote wire to a blue/white wire at the head unit.
Jun 20, 2007 | Sony XM-D6000GTX Car Audio Amplifier
Sony XM-D6000GTX Car Audio Amplifier Logo
55 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
