Funny Noise when i turn on ac the engine gives me a strange noise what is the problem by the way the AC still working well
  • 52 Answers
If the noise goes away fairly quickly, it's perfectly normal. what you are hearing is the compressor beginning to work. compressors require extra power to start because pressures have to be de-equalized in the system, and that is why it makes that noise. now, if the noise continues as long as the compressor runs it may be getting old and worn, but could still last a long time. check freon pressures if possible to verify that the system has the proper charge, sometimes that can affect how it sounds, too.
Posted on Jun 18, 2009
I have a loud noise when turning my ac on 2008 poniac solstice
A/C compressor clutch . Suggest you have it fixed before it seizes up an wreaks the serpentine belt an other parts on front of the engine !
Apr 20, 2016 | 2008 Pontiac Solstice
Roaring noise coming from engine compartment
Air conditioner clutch is going bad and needs to be replaced.
Jun 11, 2014 | Ford Cars & Trucks
Belt squeaking when air conditioner is on
ac clutch could be contaminatd with foriegn material like leaking fluids if not the ac compressor clutch is bad this is located on the the ac compressor
Nov 27, 2013 | 2003 Nissan Primera
Ford F250 Super duty V10 AC stopped working and now I hear a noise when I turn fan on
The a/c noise is either the clutch going bad and slipping which is very common on the V10. When its slips its not pumping, a clutch kit can be bought at any parts house for around $45-$50.00. About 30 minutes to put on. The other is a pump bearing going bad, which isn't a quick fix and needs the whole pump replaced, if that's the case always replace a new dryer when replacing the pump,, I would put money on the clutch...
Mar 25, 2013 | 2003 Ford F250 Super Duty Crew Cab
Ford taurus 2000,air conditioner makes strange noise when ac is on
I think the AC belt is worn or loose either tighten it up or buy a new one. Or it could something else.
______________________
Autel DS708
Jun 17, 2012 | 2000 Ford Taurus
When I turn on the ac or heater I notice that my engine starts making a funny noise. When I step on the accelator it sounds like a pulley is making a strange noise
you may have an a/c compressor clutch and or clutch bearing going bad. may be time for a new a/c compressor or compressor clutch assembly. the a/c comes on when you have the defrost or recirculation on in heater mode.
May 30, 2011 | 1996 Buick Century
I have en Honda Accrod 2003, the engine makes an strange sound, if i turn the wheel sounds like Crak Crak Crak!! if i turn on de AC happens the same.. Crak Crak Crak.. HELP...
the only thing these two have in common is they are run by the serpetine belt,have someone turn the wheel or turn the AC on while you,with the hood lifted find if noise is a pulley or something driven in belt area
Nov 23, 2009 | 2003 Honda Accord
Noise coming form engine compartment. maybe the a/c compressor clutch. a/c off and the lines are cold
ac clutch is not working fine, ac compressor is staying on even though when you turn it off, check clutch and also check freon level it migh be causing the problem
May 23, 2009 | 1998 Ford Escort
Noise from front of motor
Yes the idler pulley can make noise, but not very common. It can do it though.
Jul 24, 2008 | 2003 Ford F150 Regular Cab
Heating & Cooling Logo
144 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
