Dell monitor not turning on
I think the on off switch is dead. Has no engaging feeling it had before.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 145 Answers
Contact ur vendor for further support .... http://www.dell.com/support/contents/us/en/19/article/Product-Support/Self-support-Knowledgebase/hardware-support/monitors-portal
Posted on Apr 01, 2014
Fail to back on
Yes,Ur power ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Dell W2600 26 in. LCD Television
Can't use as a monitor to my laptop? have connected with a s-video cable but not working. laptop id dell latitude d505
Have you switch to this monitor within you laptop? I think you probably need to to do some setup on your laptop in order to activate an external monitor. Feel free to visit digitalsupporttech for getting help.
Aug 24, 2009 | Sony KLV-30HR3 30 in. LCD Television
Dell e137fp monitor flashing green...
Below you will find my recommendations for troubleshooting this issue:
1. Reseat the power cord and verify a good power source.
To reseat the power cord, follow the steps below:
1.1 Power down the system.
1.2 Unplug the power cord.
1.3 Wait approximately one minute.
1.4 Reseat the power cord.
1.5 Verify that the power cord is plugged directly into a known good power outlet.
2. Verify that the monitor is receiving power from a known good outlet and bypass any power strips.
To test the power outlet, perform the following steps:
2.1 Unplug the monitor power cable from the power outlet.
2.2 Plug in a different device, and verify that the device is operational.
2.3 If there is no power try another outlet. Remove any power strips and try plugging directly into the main power outlet.
3. Verify the monitor is powered on and the power button is engaged.
Ensure that the monitor is powered on and that the power button is fully engaged. To do so, check the power LED on the front of the monitor; it should be lit.
NOTE: There are two types of power switches:
A mechanical switch characterized by a long travel. You have to push it further and you will hear an audible click.
An electrical switch that has a short travel and almost no click.
A lit monitor LED can be any of the following:
* Green
* Blinking green
* Yellow
* Blinking yellow
* A combination, such as alternating green and yellow
Any of these states indicate the monitor is receiving power and that you should proceed.
4. Swap power cables.
To try a known good power cable on the monitor, follow the instructions below:
4.1 Turn off a working monitor.
4.2 Unplug the cable from the back of the working monitor, and unplug the cable from the wall.
4.3 Unplug the cable from the monitor in question.
4.4 Plug in the cable that came from the working monitor.
5. Run the monitor self test.
To run the monitor self test, perform the following steps:
5.1 Power off both the computer and the monitor.
5.2 Unplug the video cable from the computer or video card.
5.3 Reseat the power cord to the monitor, ensuring it is plugged into a known-good outlet.
5.4 Power on the monitor.
NOTE: The monitor self test will move around on some monitor models. If the monitor self test moves, allow it to move to the affected areas of the monitor to check for the problem described.
If the Self test failed, it's possible that the monitor is faulty. Contact dell to check if it's still under warranty so they can replace it.
Jun 15, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Dodge B350 Ignition switch
The lock the ignition key fits in is not the actual start switch. The actual switch is located on the steering column under the dash and is actuated by a metal rod that is pushed when you turn the key. as you turn the key see if you can feel anything moving on the steering column under the dash and then follow it to the switch and see if it is actually activating the start switch.
May 04, 2009 | Dodge Ram B350 Cars & Trucks
4x4 will not engage
check the starter. the battery. or the colenoid switch.
Jan 26, 2009 | 2004 Ford F150
Dimension E510 LCD Monitor with broken power switch
Thanks for responding. Nothing happened when you pressed in the power button and the warranty had expired; Dell was no help so don't bother. I read that there were tab(s) on the plastic power button that had broken off and no longer engaged the power switch. I "solved" my monitor problem by drilling through the plastic case between the power button and the minus button, pulled out the plastic power button and pressed the switch with a flat screwdriver to turn on the monitor. Now I leave the power on all the time and put a piece of black masking tape over the space where the power button was. Not the best solution I'm sure, the hole isn't pretty, but it works. If anyone else wants to try this solution be careful when you drill through the plastic case because the switch you want to engage occupies the space between the buttons, exactly where you are drilling. If you drill through the switch you might as well throw the monitor into the recycle bin. I expected to find an actual button switch and was surprised to find a flat, 2 prong circuit switch instead. Good luck to all.
Matt
Aug 22, 2008 | Dell Dimension 2400 PC Desktop
Power button
remove the button arm, and drill a hole thru the casing. Use a pin to turn it on.
Jul 11, 2008 | Dell UltraSharp 1905FP 19" LCD Monitor
No response from Monitor, Mouse and Keyboard
Definitely a "faulty" motherboard. If fans on PC do not turn, no lights come on and dead screen.
If lights come on, and fans turn, try to reset the BIOS by removing your CMOS (and setting the jumper to clear for about 5 minutes, then put the jumper to normal again) battery for 5 minutes.
Sometimes the bios just "stuffs" up and you'll get no response from your pc at all. So all you do is "CLEAR THE CMOS/BIOS"
Apr 16, 2008 | Dell Dimension 3000 PC Desktop
Dell 2407WFP power on switch
When the switch is rotated to the correct position, run a piece of sellotape (or a strip of the plastic that comes on top of phone or watch screens etc) over the switch. Nearly invisible, simple, and solves the issue.
sgmw
Feb 24, 2008 | Dell UltraSharp 2407WFP 24" LCD Monitor
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
