Well its like i have an oil leak when im running on the freeway my oil pressure goes up and temp goes down but when i stop my oil pressure goes down and my temp goes up???...what could this be a valve...
Valve cover leak (oil) will not cause this problem, what needs to be checked is your radiator cooling fan, more then likely not working, that's why when your going down the freeway it don't over heat, you have air going through radiator, but when at stop, no air going through radiator to cool coolant before it goes back through engine, starts to get hot, and oil will also thin out, and have low oil pressure, check cooling fan's or fan, for voltage, should have voltage at normal oper. temp. about 210 - 220 deg., if you do have voltage and fan are not on, replace fan motor.
