Question about Kenmore Washing Machines
Kenmore Washer 80 Series Agitates slow
Kenmore 80 series washer 11022872100 will agitate slow w/ full load works good w/ small load. Thanks for the Help!
  • 15,935 Answers
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
I have a top loading Kenmore series 80 washer. The cycle starts, agitates, but won't drain and go into a spin mode. It just stops after the agitate is done and remain full of water. It won't...
This is usually a door closed switch that is either a bad Lid switch It is number 11 on the diagram on this page http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11024032301/0582/0153200/K0403014/00001?blt=06&prst=&shdMod=
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Aug 12, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer agitates minimally but when you push down on agitator slightly it agitates more and is now having trouble starting to spin tub is it a belt issue?
Check out: http://www.appliance411.com/faq/agitator-dogs.shtml You can buy parts here: http://kenmore80serieswasher.com/whirlpool-kenmore-washer-agitator-cam-kit-285809/
Jun 25, 2011 | Kenmore Washing Machines
Kenmore Series 80 washer. Agitates too slow
check the dogs in the agitator take off the cap it should rachett if it turns free replace the dogs in the agitator
Jul 12, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
Series 80 kenmore washer, agitates but won't drain or spin
Hi, There is a good chance the lid switch is going bad. When in the spin cycle, does the motor run at all? If the motor does notrun, you will need to test the lid switch first.
Please get me a model# so I can look this model up.
Thanks
Vic
Jun 13, 2009 | Kenmore 22422 Top Load Washer
Washer only agitates and fills with water at same time.
The contacts in the timer are shorted (fused together). You can try removing the timer, opening it up and releasing the contacts that are fused together with a small flat blade screwdriver (look for burnt contacts). It might work for a while but it likely won't last. Your best bet is to replace the timer.
Mar 03, 2009 | Kenmore 24032\24036 Top Load Washer
Washer barely agitating and not spinning
This may be an indication of a failing transmission. Look underneath the machine and particularly at the base of the transmission for signs of leaking oil. If so, the transmission is definitely failing.
Jun 17, 2008 | Kenmore 24902 Top Load Washer
Washing Machines Logo
143 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
