Question about Toys
I need instruction manual how to put together Dual veldcity raceway
Singer quantum le my sewing machine is frozen and
Check to make sure you do not have a small piece of thread stuck in the raceway area
Aug 12, 2013 | SewShop.com Singer Model Quantum LE...
Need Instructions for a Techno Gears Dual Velocity Raceway
That is an incorrect statement as the 400pc. track comes with a "Full color instruction manual". The creative innovating is an encouraged suggestion, but not a reasonable solution.....
Aug 03, 2013 | Toys
Can't find instructions manual for MEGA BLOKS 96430 STREETZ RACEWAY
I have mega bloks streets raceway 96430 and don't have the instructions. Can someone please help
Dec 14, 2012 | Mega Bloks Toys
Sewing machine handwheel turns and whirrs but needle bar stuck?
my suggestion is that the machine needs to be serviced at a sewing machine shop, because for 1.it's not responding 2. it used & you don't know when the last time it was serviced 3.something is wrong with the machine.
hopefully there are no broken parts, but having the machine serviced will tell that.
as for a manual
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example w510 ) & click search
Mar 18, 2012 | White Sewing Sewing Machines
I need instructions to assemble the Discovery Toys Super Marbleworks Raceway Construction Set.
There are purposely no instructions for building Marbleworks. Any two pieces fit together, and you learn how to tweak it and improve it as you build it. Try it!! Enjoy! www.toysofdiscovery.com for more questions about Discovery Toys.
Apr 05, 2011 | Toys
I have a small length of surface raceway (wiremold by LeGrand) which has one finished receptacle, about four feet from that, at the opposite end of the raceway, is another power outlet box with no...
Yes , that seems high to me also .. when adding receptacles to an existing circuit, you simply connect them color to color, all the blacks together and so forth .. the black wires should be connected to the brass screw on the receptacles , and the white wire to the silver screws. please do not use the stab in connections in the receptacle, you will have a longer lasting job using the screw terminals
Feb 11, 2010 | Wiremold Switch And Receptacle Box
I need a repair manual to show assembly of the power switch
Not sure about the repair manual.. here is a link to the schematics I used:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/makita/LS1013FL
For better view use the PDF version.
Jan 08, 2010 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
How do you replace front bearing assembly on 2000 f-150
After you get the wheel off; remove brake calipers...do not allow them to hang down - you'll damage the brake lines!
Remove the grease cover at the center of the rotor with a flat blade screw driver. Remove the castle pin and nut, then the rotor should slide off the spindle with very little effort.
To remove the bearing raceways...clean the grease out of the center of the rotor...so you can see what you're doing. Place rotor on a solid bench/cement pad, so you can get a flat chissel/large screw driver to the inside of the rotor...pound the raceway out, working around the rotor in a circle - the raceway needs to come out evenly to avoid damage to the rotor. If you can't get the raceways out - take the rotor to a machine shop that can do it for you (sometimes the auto parts store will help...if there're not busy).
GOES BACK TOGETHER IN REVERSE ORDER:
The best thing to do is get pre-packed bearings, new castle pins and a tub of axle grease.
Remember, put about 1/2 cup/palm full of grease into the center of rotor prior to re-assembly. Also, don't over tighten the wheel...put the castle nut on and finger tighten. slightly tighten with a wrench...ensure the rotor turns freely - must be snug and slight resistance should be noticed. Don't forget the new castle pin.
Hope this helps,
Mike...
Nov 20, 2009 | 2000 Ford F150 Flareside SuperCab
NEED MANUAL OR INSTRUCTIONS FOR DURABRAND DUAL POWER VACUUM/BLOWER
I have an Eureka Atlantis Opti Heat Carper Shampooer Model 2596. I do not have an instruction book. What I need to know is how much carpet cleaner & water to mix together.
May 02, 2008 | Vacuums
Toys Logo
44 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
