Question about Refrigerators
Commercial freezer fan wont start
Plug a 110 into a 208
    Top Expert:
  • Refrigerators Master
  • 35,654 Answers
The fan may have burned out from having the wrong voltage applied.
Posted on Apr 01, 2014
I purchased a BeverageAir commercial refrigerator and the fan won't run. What could the problem be?
CHECK THE THERMOSTAT WHETHER IS IT TO THE LOWEST CAUSING VERY LITTLE FREEZING. TAKE THE KNOB TO THE MAXIMUM AND THEN SEE WHETHER IT STARTED. IN CASE NO THEN CHECK THE WIRING OF THE FAN MIGHT BE SOME CONNECTION NOT IN PLACE
Sep 28, 2014 | Beverage-Air 44.9 cu. ft. / 1271 liter...
Frig wont cool fan not running freezer working
fan is not working thus u have very little cold air circulating into the fridge. check the fan with a multi meter for continuity? it may be out? When u say freezer working? is there an ice build up ? if so u may have a bad defrost terminator or defrost timer, which in turn blocks the fan from working due to ice build up?
Aug 14, 2014 | Samsung RFG297AA (285 cu ft) Bottom...
I have TRUE freezer model number GDM-49F. the compressor start but the evaporator fan wont start what culd be the problem
Could be a number of things. It has a thermistor that sits on the evaporator to keep the fan off until it gets cold. It also has a switch above the door that switches the fan on when the door's closed. It could be a loose connection in the wiring, or, lastly, it could be a seized fan
May 04, 2012 | True 49 cu. ft. / 1388 liter Commercial...
True GDM-72f freezer Fans don't start
Thermo fuse has failed on the core plate, tells the freezer its cold enough to start blowing air, you can bypass it but not recommended. hope that helps, Russ
Jun 11, 2011 | True 72 cu. ft. / 2039 liter Commercial...
Have a 3 door commercial freezer that
might be the overload relay
Jul 20, 2010 | Freezers
Voltage to evaporator fan
Lots of things to look at. Let's get started.
Evap fans usually have some sort of fan delay, usually mechanical. These go bad fairly often. This could add resistance to the circuit.
You can have up to 1 Ohm of resistance through most mechanical t'stat devices. Anything over that, replace it. If you are getting 35 volts out of the board, it's probably the board. If you got voltage going in and not coming out, it's usually the board.
Mar 17, 2008 | Delfield 26.64 cu. ft. Commercial Freezer...
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
