Question about Toro 2-Cycle 25.4 cc Straight Shaft Gas Trimmer 51974
Gas leak where gas lines enter and leave tank
Gas leaks at grommet where gas lines enter and leave gas tank. Can the grommet be replaced?
    New Friend:
  • 13 Answers
Also, make sure that the vent for the fuel tank is working. the vent is either on the fuel cap itself or thru a device commonly known as a duck bill valve, so named because of the shape of the valve. All the vent does is allow a slight amount of air to enter the tank while the trimmer is running.
Posted on Apr 04, 2014
Service manual for mcculloch mac cat 600038-30 chainsaw
fuel line is available by the foot from a mower shop
most fuel leaks involving lines and tanks can be traced to the rubber grommet at the lines to tank entry
take it to a mower shop and discuss the fix
Oct 20, 2016 | Cars & Trucks
Gas leaks out around the gas cap when trying to trim anything above horizontal level. Replaced the gas cap and it did not fix the problem
most likely not the cap but the grommet around the 2 fuel lines at the top of the fuel tank
easiest fix is a new fuel tank that has the lines already installed
Apr 03, 2016 | Garden
I replaced the fuel lines on my Husqvarna 128LD and they are now leaking, is there a seal or a grommet of some sort to help seal it at the tank? I don't recall any when I pulled it apart.
Some fuel tanks will have a black rubber grommet that have holes for the fuel lines to go into, if your holes are in the tank itself, then no, there's no grommet. And if that's the case ,your lines are not the correct outer diameter. There are multiple sizes of fuel lines. In my shop I have multiple sizes, if you don't have that kinda stock, you're better off either ordering the ones of a parts drawing of your model or simply take your unit and old lines to the closest small engine shop and have them match em up, u actually can just bring the tank with ya.
Aug 20, 2015 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
How do you hook up the fuel filter line inside the tank on a cs400
If you go online and search for the drawings for that saw you will see that the fuel pipe enters the tank at the top through a grommet. You will have to pop out this and then pass the pipe through this after passing it up through the hole from inside, long nosed pliers or tweezers will assist. Once you have that done stuff the grommet back into the hole and don't pUll it out again!!!!!!!!
Apr 03, 2015 | Echo Chain Saw. 18 in. 40.2 cc Gas Chain...
Gas leak at grommet on gas tank where gas lines enter and leave tank
Yes you should be able to replace the rubber tank seal that the fuel line goes through. Be sure to replace the fuel line(s) when you do.
Apr 01, 2014 | Toro 2-Cycle 25.4 cc Straight Shaft Gas...
Fuel leaking carb overflow
Hello Brian,
I would visually inspect fuel lines entering/leaving tank that go to the carb. These tend to get brittle and crack. Also, some models have a rubber grommet that the fuel lines pass through entering/leaving the tank, these too get brittle and crack. If that looks good, you may have a stuck needle in carburetor and it will need to be removed and serviced. Hope this helps. Good luck and happy wrenching!
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Sep 25, 2013 | Ryobi Garden
Cchanged furel lines on my string trimmer and now fuel leaks from where the line enters the tank
Your grommet might be bad or you might have gotten the wrong size fuel line.
Jul 28, 2012 | Troy Bilt Tb70ss Gas Trimmer
My 89 nissan 240 sx fuel EVAP failed the smog test
The carbon canister may saturated. If you are one to try get as much fuel as possible into the fuel tank, that may be how it happened.
Also check the gas cap. There is supposed to be a one way valve to allow air to enter into tank, but not vent out in any direction but by the vent hose to the carbon canister. That valve may be leaking. Also, there is a purge vent to the intake manifold, check to make sure that passage is clear and not carboned up.
Feb 11, 2012 | Nissan 240SX Cars & Trucks
Gas leaking from grommet that goes into the gas tank.model pb-2111.
replace grommet. you may want to replace the fuel lines to you can use echo part number # 90098. its a fuel line kit and it come with all fuel lines, grommet, fuel filter, and vent. its plug and play.
Sep 21, 2011 | Echo Garden
Toro 2-Cycle 25.4 cc Straight Shaft Gas Trimmer 51974 Logo
266 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
