Question about Dell 1600n All-In-One Laser Printer
Hi. I've a Dell 1600n printer. There is plenty of paper in the drawer, but message says No Paper/Add Paper.
  • 674 Answers
Remove the drawer then insert again.. if the same problem.. clean the sensor maybe its broken.
Posted on Jun 15, 2009
Frequent paper jams on a Dell 1600n AIO, sometimes doesn't grab the paper from the tray (not really a jam, just need to open and close tray), sometimes gets caught halfway through the path -- need to open...
This could be caused from the papers you use at times(weight). Call on a Dell representative to check it out for you if you bought it from a Dell shop.
Thanks
Aug 19, 2009 | Dell 1600n All-In-One Laser Printer
Jam msg will not clear ? no paper in path?
when you removed the paper, a small piece might still be stuck somewhere or the sensor might have remained in the on position.
May 19, 2009 | Dell 1600n All-In-One Laser Printer
I get a "no paper" when there is plenty of paper in printer
There is a little white tab on the left hand side of the papper tray. If it dose not pop up the papper when the tray is closed, you will get a papper error,.
Feb 13, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1600N warming up message
Hi Unplug the printer power cable from the wall and disconnect it from the printer as well. Turn the printer power switch on for 15 seconds. This will reset the printer. Turn the printer power switch off and plug the cable back in on both ends. Then turn power on. The Document Jam error should be eliminated.
Please keep in mind you must check for any small pieces of paper or look for a real paper jam prior to completing the steps above.
I hope that helps.
Sep 16, 2008 | Dell 1600n All-In-One Laser Printer
Dell Printer 1600n
Check your manual feed tray. The printer may have a print job in memory that's pointing there.
Aug 13, 2008 | Dell 1600n All-In-One Laser Printer
Scanner locked
Reach in the cavity where the paper comes out. In the top left far corder you will find a blue sliding switch. Pull it forward and press cancel.
Jul 23, 2008 | Dell 1600n All-In-One Laser Printer
Printer will not print. Displays no paper.
Is the page stop at the back of the tray set correctly? If you have the stop a "click" off, rather then seeing letter size, it will see universal or A4 and say no paper, because it's looking for letter size. If it is on the network, just open a browser and go to the IP address of the printer, or print out a configuration report. That will tell you what size the drawer is reading.
Jun 16, 2008 | Dell 1600n All-In-One Laser Printer
Add paper message
you will be glad to know, this is not your printer's fault. We went round and round with dell support when we first got 150 dell 1600n's. We sent in copies of documents that were causing the problem. Finally, they figured it out for us. Embedded in the document was junk that was telling the printer to pull from tray2. All you have to do to fix the problem, is take the word document, go into file, page setup. on paper tab, select default tray for first page, default tray for all other pages, and apply to whole document. to clear the message, you will have to delete the print job from the queue, and turn off the printer, then turn back on, and you should be set. The message add paper, is really what the printer should be telling you, except that it should add to tray2, so you know it is trying to pull paper from the manual sheetfeed port on the front.(you could add paper there, till the document finishes printing, but our docs are hundreds of pages, so that is not practical. Barry Smoke Network Administrator AR Division of Legislative Audit
Feb 25, 2008 | Dell 1600n All-In-One Laser Printer
No paper light stays on and printer won't print (paper is full)
There is a black, curved-shape piece that hangs down (protrudes) from within the paper bay (visible with cartridge removed) that is spring-loaded. That piece might be jammed or broken.
Jan 22, 2008 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
99 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
