Question about Sharp R-1870 Convection/Microwave Oven
Replacing the riveted clearance lights on a 1991 holiday rambler motorhome?
How do I replace the marking/clearance lights on my 1991 Holiday Rambler, they are red in the rear and yellow up front. I have the replacement LED lights by Blazer C12544r. My problem is that the old existing lights are Riveted into the body, What is the best way to get the old ones off and install the new ones? Thank you very much. Jeff Bashor
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 82 Answers
Grind the top of the rivets off, then with a small punch and hammer tap the rivet into the hole.
Posted on Apr 01, 2014
4 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: removal from a motorhome
We regularly repair the circuit boards of microwave which are hit by storm surges, etc.
This repair usually runs $39.95 to $64.95, depending on if we have to replace the low power transformer. I just thought I'd mention this if you're interested.
But if you've decided on replacing it, the installation manual should be helpful in removing it from the wall. See it here.
You will need the free Acrobat Reader to view or print it.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 06, 2008
SOURCE: where are gound fault outlets located on holiday rambler 2009
check the breakers on the inverter located in the outside compartment it has two breackers on it. most people don't know that some of the 120 volt power comes thru the inverter.
Posted on Apr 02, 2009
motor1258
  • 6674 Answers
SOURCE: How to remove microwave ffrom holiday rambler rv
Normally the outside shroud, has screws to remove, then microwave slides out. Be sure to unplug before trying to remove it.
Posted on Oct 14, 2011
Microwave oven - switching on involuntarly.
Not to make light, but most broken items were sound at one point in time. With the price for new small microwaves running less than $100.00 it is likely not cost effective to repair unless there is a known easy fix.
Sep 10, 2016 | Panasonic Microwave Ovens
Tip
Home alone for home electronics
I have come across many complaints of home systems not working when one comes back after a long holiday. This made me think to give some tips so as to take care of your dear products while you are away.
To start with disconnect cable line and power to your TV and Home System , Disconnect power generally to all the other appliances if the period of absence is more than a month.
Now the most important part is that in many cases moisture build up, condensation and insect infestation can be the biggest problem apart from power related issue for which we take off the cable and take power plug off.
Cover the concerned appliance with a GOOD BLANKET to keep it warm within. If there are devices with battery you can remove battery or keep them connected to power specially cordless phones. But laptops can be kept off power. Micro waves must be clearly covered as the kitchen appliances are most vulnerable to such problems.
when you return after the holiday the clocks might have to be set after switch on .
However many may dispute to say that the power can be put on but in many cases lack of human interference results in insects to barge in and cause havoc. Hence if you in such a threat and environment, try this out.
Also you may end up saving power by switching off the fridge during this long period.
Hope this tip finds use with a purpose.
on Aug 19, 2010 | Microwave Ovens
Oct 11, 2011 | Sharp R-930AK Convection/Microwave Oven
The aluminum burner ring in my holiday propane stove is warped and distorted. it measures 2 1/2" (o.d.) by 1 1/8"(i,d,), can you locate 3 replacement rings for me?
Hello & Welcome to FixYa
You can buy the burner rings from here. Please get back to me if you have any other questions.
Kevin
Jul 06, 2011 | Microwave Ovens
HI WOULD YOU KNOW WHERE I CAN GET A MANUAL FOR MY SHARP CAROUSEL CONVECTION OVEN MODEL R1850A? IT IS INSTALLED IN MY HOLIDAY RAMBLER RV.
This manual will be close enough.
Apr 26, 2011 | Microwave Ovens
You stupid crooks, you say it is free advice and then you ask for
Why the "you stupid crooks" thing? You come on here looking for something for nothing, then bad mouth those who take the time to hhelp you at their expense. You are barking up the wrong tree fella. Fixya .com has an address. File your grievance with them. If you can handle the cost of postage. Now, this is free advice but it will cost me the privilage of helping those who want and need the help. Good Luck and have a happy and carefree holiday. I wish you the best the holidays can bring. Ned Cook
Nov 25, 2009 | Frigidaire FMT116E1B Microwave Oven
Flash/sparks occrred (no metal in oven)
You know I just had a similar problem on my old unit. There was a spark and my bowl had no metal rims. I figger your ground connection has corroded at the rivets. So if you can drill a 1/8 inch hole in there and install a #8 sheet mtal screw or two to bond it togeter again.
May 04, 2009 | Microwave Ovens
Where are gound fault outlets located on holiday rambler 2009
Mar 23, 2009 | Sharp R-1874 Convection/Microwave Oven
Removal from a motorhome
William E. Miller
prototech@usa.net
Oct 06, 2008 | Sharp R-1870 Convection/Microwave Oven
Unit runs for 59 seconds and shuts off
This is a problem in one of the damper-related components, most likely the switch or motor, but it may also be the motor or the damper door.
The damper is a door located on the right side of the innards. The damper closes and opens depending on cooking mode.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
You can find a helpful exploded view by entering your model number here: http://www3.sears.com
Nov 16, 2007 | Sharp R-1870 Convection/Microwave Oven
Sharp R-1870 Convection/Microwave Oven Logo
52 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
