Question about Crosley CR-6001A-BK - USB Turntable Archiver, Black
I cannot record lps with crosley cr6001a
I set up audacity following the instructions
  • Crosley Master
  • 3,320 Answers
Posted on Apr 01, 2014
Testimonial: "I went to crosley support but there I couldn't found any help about this problem"
Crosley cr 54 cd records sound bad
It could be that the needle is worn. Also make sure that dust and dirt have not accumulated on the needle. It could be a bad ground. You didn't really describe what "sound awful" means. The phono section of the amplifier is much more sensitive than the amplifier section for the CD or radio because it is using much less input signal.
Mar 10, 2015 | Crosley Audio Players & Recorders
Crosley cr249
are you using a standard microphone jack? like a 1/8" if so this is most likely the problem. also what program are you using. i recommend audacity.
Jun 19, 2008 | Crosley 0187SST Turntable
How do I recovery temporary files in Audacity ?
If you are on Windows you can get it to display hidden files (such as system files) With luck it might show up your missing files. Just type "show hidden files" in the help on Windows and follow the instructions.
Aug 09, 2014 | ION Audio TTUSB 10 Vinyl Recording USB...
Want to connect and play Crosley Executive CR6019A
You have to get a program for your computer to use with Crosley. Unfortunately, there is none.
Jun 10, 2014 | Crosley Audio Players & Recorders
Why is my brand new crosley turntable keepsake hunter skipping tracks?
The turntable may not be level. Also, the stylus could be damaged or defective. The stylus pressure may not have been set correctly in production or may have been affected by shipping.
May 05, 2014 | Crosley Keepsake USB Turntable
Why is my crosley turntable skating across records?
First feel with your finger at the tip of the stylus. It should be sharp. If it's not report it back to the place where you bought it.
If it's sharp, then the weight on the end of the arm might have moved, meaning there is no pressure to the stylus. You can look up what it says in the manual about stylus pressure.
The other way is to test and adjust. If the weight has numbers on it set it about the middle of the numbers. Then try a record, if it skates, stop and increase the weight by moving to a higher number, not much, then test the record again. You keep doing this till the stylus stays in the groove. However don't increase it that much so it rumbles when in the groove. If that happens reduce the weight slightly and test. I find it best to test with headphones on.
May 05, 2014 | Crosley Audio Players & Recorders
Record continously skips after 4 or 5 seconds.
You need to apply more pressure to the stylus. This is done by adjusting a weight on the other end of the arm. See your manual for more details.
May 12, 2013 | Crosley Cr6001a Turntable
I have a crossley lp player cd recorder and dont know how torecord from lp to cd
Is The Lp Player Stand Alone Or Does Have To Connect To A PC Via USB Cable.Your Pc Should Store The Recording In A MP3 File.The Resulting MP3 File Can Then Be Downloaded To The Cd.
Apr 10, 2013 | Crosley CR-2402C-PA - CD Recorder...
Hi, the crosley will no longer record onto any music cdr/rw. It will indicate that the cdr is blank-i know it is- then the zeros/record appears but no recording takes place. thanks if you can help.
I turned it off for two (2) hours - turned it on and it worked. Apparently this unit overheats after one session: one (1) cd-r per session then shut-down.
It is worth it, when it works, because my lps have no hiss when finalized.
Sep 05, 2008 | Crosley CR248 Turntable
Crosley CR-6001A-BK - USB Turntable Archiver, Black Logo
32 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
