Question about Federal Industries RSSM678SC
Rssm678sc What is the correct superheat setting for this unit? Thanks Kelly
Compressor shut off for no reason
You need to to determine the superheat and subcooling to check for the proper operation of your system when the compressor is running. I ran into a case just yesterday, the breaker kept tripping. Unit had the same readings as yours. This one had a subcooling of >25 degrees and 0 degrees superheat indicating unit was overcharged. I took an extra 8 pounds of r22 out of the system. During the investigation I also determined the filter/drier was blocking the refrigerant flow causing the technician to overcharge the unit. To check filter/drier performance all you need to do is measure the upstream and downstream temperature. The difference should be less than 2 degrees. This one was 7 degrees indicating it was metering flow. If your compressor stops operating before determining superheat and subcooling, you can get a professional tech to recover and weigh out the refrigerant in your system. You can look on the nameplate data on the side of the outside unit and see the ounces of refrigerant it is charged. If the compressor is operable go ahead and adjust charge by recovering the excess refrigerant into a recovery container for that refrigerant. Normal superheat and subcooling is normally around 10 - 15 degrees.
Hope this helps
Jun 20, 2014 | Goodman CLQ36AR49 Air Conditioner
Superheat subcooling
the model says that this is a cooler/freezer combination unit. super heat has to be measured on each section separately. As a general rule: Freezers run around 6-8 degrees and coolers are 8-10. I have seen freezers go as low as 4 degrees right before they hit set point temp and shut off.
Dec 19, 2013 | Delfield Refrigerators
How to use superheat in a ac unit
Wow this is a very wide question!! superheat can not be used but is set or is preset. Please elaborate on the question a bit more.
Aug 02, 2013 | Heating & Cooling
The agitator was not working correctly. I did the work myself but im stuck trying to put the clutch/brake assembly together & on. The unit is Whirlpool Ultimate care 2. Mod# LSQ9544KTO SER#...
Hi and welcome to FixYa, I am Kelly
Here is a video that should solve the mystery:
This does a much better job than any text that I could post here but just in case take a look at this Whirlpool Job Aid L-55 for Direct Drive Washers. Page 17 shows how to set the Neutral Drain on the Brake Pawl. Also see pdf page 20.
Between the video and the Manual this should help you.
Thanks for choosing FixYa,
Kelly
Aug 09, 2011 | Washing Machines
What is the spark plug gap for the ryobi 320vbr blower
Hi and welcome to FixYa, I am Kelly.
The spark Plug Gap is 0.030. Any original or aftermarket spark plug for this unit is pre-set to 0.030. Unless you dropped the replacement plug it should be fine. All Ryobi engines 2 and 4 cycle have a 0.030 spark plug gap.
Kelly
May 07, 2011 | Garden
I've got a Baumatic Mini4 table top dishwasher: what is err6 and what do I do?
Hi and wlecome to FixYa, I am Kelly.
Your table top dishwasher has an open circuit in the thermostat.
'E6' OPEN CIRCUIT THERMOSTAT.
Technical / Advice Telephone. +44 118 933 6933
SPARES
TEL: 0118 933 6922
FAX: 0118 933 6942
UNITED KINGDOM
T: +44 (0) 118 9336 900
F: +44 (0) 118 9310 035
info@baumatic.co.uk
I do not have the parts list for this unit. You wil have to contact Baumatic to order parts.
To correct the E6 code you will have to have the thermostat replaced or wiring to the thermostat repaired that is causing the open circuit.
Kelly
Jan 25, 2011 | Dishwashers
Good evening I refill the freon for a Carrier 14000 BTU and to my surprise when I start it back it was within a couple of minustes full of ICE. What can I do ? Let some gas escape. How do you control the...
you must charge the unit in accrodance with the manufacture recommendations posted on the side of the unit. check your superheat by converting low side pressure into temperature and get the temperature of the low side line and subtract them to get your superheat reading. It must be 10 degrees F for proper operation.
Nov 26, 2010 | Heating & Cooling
13 degree Delta T
I assume r-22 refrigerant by the pressure... you have a saturate temperature of approximately 41 degree and 71 degrees at the service port this equates to a 30 degree superheat. a condenser saturation temperature of 105 degrees and since the liquid line temp at the service valve is not given only the enterin indoor coil on the liquid line a 96 degree temperature this would equate to a subcooling temperatureof about nine degrees. You have too high of a superheat reading. verify that the bulb for the txv is correctly positioned and insulated. if it is then you need to remove the bulb from the suction line, hold it in your hand to warm it up and see if the superheat changes. you could also have issues with your ductwork. If the supply temperture is around 50-55 degrees then the unit is doing all it can.. Check the txv and the ductwork as the subcooling indicates that the condenser side is doing it's job, but the superheat readings indicate that you are starving the evaporator..
Jul 28, 2009 | Heating & Cooling
Federal Industries RSSM678SC Logo
18 people viewed this question
Top Federal Industries Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Federal Industries Refrigerator Expert? Answer questions, earn points and help others
