Question about Electrical Supplies
I got a 1999 motorguide 67lb brute 767 it is 12 or 24v when i swich it to 12 volt it dont work but when i put it on 24 volt it runs but not like it should i need help
  • 76 Answers
My guess is that the motor has leaked water and requires the 'extra' power of 24V to spin it up. To check for a water leak, first remove the prop.
Here is a schematic to get you started:
http://www.mikesreelrepair.com/schematics/displayimage.php?pid=8362
After the prop is off, you will see 2 or 4 bolt heads. You'll need a 5/16" socket. You'll want to remove only one of the outermost bolts. The bolts are about 8" long but only threaded for an inch or so. When you get it out you will be looking for a black, oily looking residue, whch would indicate water still in the motor unit. If you see rust or a white, powdery substance that would indicate there was water intrusion but has since dried out.
Give everything a good clean, replace all the o-rings, clean up the armature commutator (copper brush contact on the armature) and re-assemble.
Posted on May 22, 2014
4 Suggested Answers
  • 5 Answers
SOURCE: I have a 767P motorguide that is 12/24 volt. The
Yes and ...no. I'd look for one made for marine use... although any good quality switch will work...for a time. Corrosion will catch up with a :cheapie."
Try these guys... http://www.trollingmotorparts.com/default.aspx/MenuItemID/184/MenuGroup/Home.htm
Good Luck and God Bless, Luckymann77
Posted on May 14, 2010
miket756
  • 2702 Answers
SOURCE: The switch keeps burning out and the motor turns
i think its time to strip this motor out,, it sounds like its has a short in the field coil winding,,as its pulling far to many amps,,,,
Posted on Jul 01, 2010
SOURCE: Ihave a motorguide brute hyper 67 trolling motor
This is most often caused by a faulty 24 Volt, section, (usually damaged output semiconductors, or the drive?) in the speed controller, fault, the only "Fix" is replacement. Simply obtain the entire speed controller and replace it "En Bloc" as it were. You will need to also obtain a service manual so you can disassemble it and obtain the parts numbers for the replacement parts.Otherwise take it to a professional and ask for a "Quote" as to prospective costings and go from there.
Posted on Oct 21, 2011
Ihave a motorguide brute hyper 67 trolling motor can't get the 24 volts to work motor runs on 12 and 24 volts and all five speeds but don't have the thrust of 24 volts
Oct 20, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
I have a Motor Guide Brute 767, 67 lb thrust 24 volt trolling motor. It will only run at about half speed even with new batteries.
I believe you may have a bad low voltage circuit board problem. I do not think they make the board any longer but you may be able to convert it to work by bypassing the circuit board. I am working on one now.
Mar 22, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
The switch keeps burning out and the motor turns about one turn and then will not turn again. Motorguide Trolling Motor Brute,767 67 lb thrust 12/24 volt Hyper Drive
Jul 01, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
May 10, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
I bought a used trolling motor (motorguide brute 750 50# thrust) it has a 12-24 volt selector switch and three wires to hook up to battery, a black, a white, and a red. i'm assuming on 12v setting of...
the black wire goes to - and the red goes to + for 12 volts. If you want 24 volts you need to add another battery and run a jumper wire from the - of the first battery to the + of the second battery and hook the white wire to the - of the second battery. Here is a picture to help you.
Mar 15, 2010 | MotorGuide Electrical Supplies
My 12/24 volt trolling motor only runs on 12 volts
Did you connect 2 batteries to try the 24 volt version? You have to link them together like a flashlight, positive to neg and then out the other side, for 24 volts, like a golf car.
Feb 23, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Wiring diagram for 12/24 volt system
here is a wire diagram. follow the pictures. you can do fuses but i like inline breakers. you can get them at your local outboard dealer.e9e9f8a.jpg
Nov 05, 2009 | Boating
Need to know how to wire a motorguide 767 brute trolling motor
The white wire is the ground. The black wire is neg. and the red wire is pos.
Mar 15, 2009 | Electrical Supplies
Electrical Supplies Logo
103 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
