Question about RTO Burdick Quest Stress Test System w/ TM55 Treadmill - OUR PRICES ARE TOO LOW
How to change internal memory battery on burdock Quest stress system w/TM55 treadmill.
Treadmill not working
3 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: moved treadmill and now its not working
1) Test the outlett power wall, and rese the c.breaker from your home
2) Test the power cord for wires loose, break or burn with VOM
3) Reset the c. breaker from treadmill
4) See if there are some wires looses
5) Tight any wires connector very well.
6) See if there are some fuse blown inside,
7) Test again. Note: NOT use any extension cord. see the block diagram for help .
God bless you
Posted on May 21, 2012
ercupa190
  • 12223 Answers
SOURCE: IMAGE 19.0 R treadmill
1) Adjust the REED switch, clean it, and tight the plugs or connector very well, see the diagram
2) LUBE the deck belt, this could be happen to due the lack of maintenance, you must do it every weeks of use, use 100% silicone LUBE, and do it.
3) LUBE the rollers bearing with DW-40 with small quantity.
3) Tight a little drive belt motor, and replace if necessary, the tension must be 1/4" of flexibilit.
4) Test the input voltage motor, if there are the motor need repair, see my personal TIPS for troubleshooting motor.
5) Test the output voltage board, for input voltage motor, if there are NOT voltage, the board is faulty.
see the block diagrams
God bless you
Posted on Nov 26, 2012
Replace control board
see this The most likely cause of the problem is a worn treadmill belt and deck.
Most of the time its caused from not lubricating between the treadmill belt and deck. This causes friction and the surfaces wear putting greater stress on the electronics. The treadmill is shutting down to protect the electronics. You should stop using the treadmill and have a technician check it.
If it sounds like metal rotating on metal then it could be roller bearings or motor bearings. Its best to have the treadmill work carried out by a technician in the workshop. Most of the time the bearings will have to be pressed out and the new ones pressed in
Jul 17, 2013 | Nordic Track Exercise & Fitness
Ironman Quest Treadmill Unfolds Improperly
see the video and proceed according. God bless you
Jun 08, 2013 | Proform Exercise & Fitness
Treadmill stop working
Dear Sir:
Try to run the software calibration for easy diagnose and troubleshooting.
See my personal TIPS for HELP.
sincerely. God bless you
ernesto cuadra
managua, nicaragua
Mar 11, 2012 | Exercise & Fitness
Cybex 520t treadmill runs for about 2 minutes then says end and quits running?
Dear Sir:
Most of the time its caused from NOT LUBRICANTING between the treadmill belt and deck.
Remember the treadmill is complex electronic system. sincerely.
God bless you.
ernesto cuadra
managua, nicaragua. c.a.
see the block diagram that I design for easy diagnose and troubleshooting.
Feb 15, 2012 | RTO Cybex 520T Remanufactured Treadmill
Treadmill stops dead during workout
Dear Sir:
Feb 14, 2012 | Exercise & Fitness
Treadmill want fold up am i doing something wrong
Yes.... An elongation may occur within the treadmill belt... Due to stress contributed during the fold up...
Oct 09, 2010 | Cadence Weslo SL25 Treadmill Walking Belt
Need to buy a thermal printhead of an quest atress system, thanks in advanced
I buy most of my parts from Parts Source. I speak with Tamara there and she can usually get most things I need.
Feb 08, 2010 | RTO Burdick Quest Stress Test System w/...
My treadmill will not work
check your fuse on the lower board first. you may have damaged the lower internal board onthe treadmill. check the out let. Is there power on the head board?
Feb 14, 2009 | Reebok Vista Treadmill - RBTL13305
RTO Burdick Quest Stress Test System w/ TM55 Treadmill - OUR PRICES ARE TOO LOW Logo
53 people viewed this question
Top RTO Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you a RTO Medical Expert? Answer questions, earn points and help others
