Question about Maytag Neptune MAH5500B Front Load Washer
Leaking water Water is leaking out on the floor. It is not coming from the drain hose as I have replaced it and the problem still exists.
  • 32 Answers
If the hose is ok and you need to check if the leaking coming from the seal of the rotating shaft you can check when you remove the cover behind the machine if it is ok check the rubber seal of the front door
Regards
Posted on Apr 03, 2014
Krazytech
  • 725 Answers
SOURCE: Drain hose leak
Hi Krazytech here, You will have to remove the cabinet to get to the pump end of the drain hose. First you must remove the top insert a putty knife to open the top lift up then remove screws that hold on the top then remove the screws that hold on the bottom. then you can get to the pump I alway replace the factory spring clamps with a screw hose clamp they are much better.. let me know
Posted on Aug 24, 2007
Amigaman
  • 248 Answers
SOURCE: Washer leaking water from bottom
Probably a main tub seal, big job!
Posted on Nov 16, 2007
SOURCE: maytag neptune mah5500bww leaking water
Here is the solution I found that worked for me, there is a small drain hole at the bottom of the boot that is connected to a drain hose. Remove the hose and clean out to make sure that it has not become plagged. replace hose and reattach boot. Mine stoped leaking imediately.
Posted on Aug 20, 2008
  • 25 Answers
You may want to check the seal at the bottom of the agitator, there is a o-ring that keeps the water in the drum from leaking through the agitator as it spins. This is a cheap seal and will wear over a period of time from exposure to bleach and detergent. You need to take the agitator apart and remove it from the drum and you should see this seal at the base of the agitator were it meets the drum.
Replace the seal and reassemble, take the metal casing off the washer and fill the drum with a little water, wait, and see if the water is leaking under the drum. If no leak, try to reassemble and run the washer. If is still leaks then check http://www.applianceaid.com/genew.html
Yours Truly,
Mr.Fix-it-guy
Posted on Aug 12, 2009
  • 274 Answers
SOURCE: Water leaks when washer is filling up
The hoses are locted in the back do not open the top you may need to just replace the hoses,check intake selenoid
Posted on Jul 05, 2010
My Simpson exist set 950. Why does it overfill and pour water on the floor?
it sounds like your water level clip is broken and needs replacing
Jun 01, 2015 | Simpson Washing Machines
Why is my Kenmore Energy Star 50 pint model 251-50501012 dehumidifier leaking water after I disconnected the drain hose
If you reconnect the drain hose, make sure that it lays flat from the dehumidifier and into the sump pump hole. I did that and it solved my problem of water leaking onto the floor.
Jun 15, 2014 | Kenmore 50 Pint Dehumidifier Electronic...
Leaks water
see this causes and fix it. God bless you
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable
Tub Seal and Bearing Kit If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal kit can be replaced. This is common and relatively easy to replace.
Tub Seal If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. This is common and relatively easy to replace.
Tub to Pump Hose If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Sep 30, 2012 | Washing Machines
Leaks from underneath
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Tub Spin Seal If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Sep 30, 2012 | Kenmore Elite Washing Machines
Leaking
Hi
Please Follow this Instructions:-
Step 1 Look at the floor drain to make sure it isn't clogged. Sometimes it's not even the washing machine, but the drain causing those puddles of water on the floor. Unclogging the drain can be an easy and quick fix.
Step 2 Inspect the hoses for leaks or wear and tear in certain spots. Filling the washing machine may help identify any leaks or faulty hoses. If hoses are worn, replace them with non-burst stainless steel mesh hoses.
Step 3 Check the fittings of the existing hoses to the faucet fixtures and on the back of the washing machine. Sometimes a loose connection is the cause for the leaks. Tighten couplings and hose clamps if necessary to fix the leaks.
Step 4 Replace internal washers inside of the hoses if not replacing the entire hose. Something as small as a rubber gasket can create a lot of water damage. Use a screwdriver to pop the worn washer out and replace it. Repeat replacing washers on the other end of the hose.
Step 5 Examine internal components by opening the cabinet and starting the fill cycle to see if anything is leaking internally. Calcium deposits and rust may be evident around areas that have leaks.
Step 6 Use hose clamp pliers to remove any corroded spring clamps and replace them with new ones. Make sure the hose is still intact underneath the old clamp. If not, remove the internal hose and take it to an appliance repair center to find the correct replacement part.
Thanks for contacting fixya.com
Oct 30, 2009 | Washing Machines
Water leaking
hi friend,
  • Step 2 Inspect the hoses for leaks or wear and tear in certain spots. Filling the washing machine may help identify any leaks or faulty hoses. If hoses are worn, replace them with non-burst stainless steel mesh hoses.
  • Step 3 Check the fittings of the existing hoses to the faucet fixtures and on the back of the washing machine. Sometimes a loose connection is the cause for the leaks. Tighten couplings and hose clamps if necessary to fix the leaks.
  • Step 4 Replace internal washers inside of the hoses if not replacing the entire hose. Something as small as a rubber gasket can create a lot of water damage. Use a screwdriver to pop the worn washer out and replace it. Repeat replacing washers on the other end of the hose.
  • Step 5 Examine internal components by opening the cabinet and starting the fill cycle to see if anything is leaking internally. Calcium deposits and rust may be evident around areas that have leaks.
  • Step 6 Use hose clamp pliers to remove any corroded spring clamps and replace them with new ones. Make sure the hose is still intact underneath the old clamp. If not, remove the internal hose and take it to an appliance repair center to find the correct replacement part
  • hope this helps u
    thank u for using fixya
    please rate me.................
    regards
    sivaranjini
    Sep 12, 2009 | Kenmore Washing Machines
    Water on passenger floor...
    Two things: If there is a stickiness or sweet smell to the water, your heater core may be leaking.
    If this is just a summer thing, your a/c evaporator drain tube my be blocked/clogged or leaking inside the vehicle.
    Jul 24, 2009 | 2005 Mazda 3
    REFRIDGERATOR LEAKING WATER ON THE FLOOR
    HI. This may be a drain pan issue.
    The drain pan should be removed and cleaned at least once a year. The drain pan is located at the bottom of the refrigerator behind the front grill. Remove the grill, which snaps into place. Grasp the drain pan while pulling slightly upward and forward.
    Clean the pan with warm soapy water or warm water and baking soda.
    If the pan rattles when it is replaced, it is too close to the compressor. Simply reposition the tray.
    If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve. The hoses may be loose here.
    Jun 30, 2009 | Maytag MSD2454G Side by Side Refrigerator
    In the spin cycle water leaks onto the floor,
    If the hoses at the back are not leaking, you need to check the drain hose lines, aksi check that the machine is not dripping from the inlet valve hose, or because of a leak from the door gasket.
    Dec 09, 2008 | Maytag PAV3240A Top Load Washer
    Maytag Performa Washer
    when you put the drain hose on the floor the water will ALWAYS drain out. When the drain is in the proper location (above the height of the tub) and the water is still leaking, if its leaking as it fills you might have a loose hose,or a cracked water inlet valve. If after the water is in the tub and its still leaking you have a bad seal.
    Jul 03, 2007 | Maytag Performa PAV2200
    Maytag Neptune MAH5500B Front Load Washer Logo
    41 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
