Cyberlink powerdirector problem
Have installed cyberlink powerdirector and connected to my computer but when I open the capture button says unable to load content from specified folder/disc cyberlink powerdirector does not support any content in the folder/disc. this program worked fine on windws xp but now it will not connect to my video player starts to show box like it is connecting but then I get the box with the unable to load from specified folder I am on windows vista and I have used it before what can I do
Quack
  • 542 Answers
SOURCE: putting video footage on my computer
To get your footage into the computer from DV tape you need a four pin firewire (IEEE1493 or iLink) cable from the camera to a six pin cable into the computer. USB will not do a proper job, it's for downloding photos or as you already mentioned, Web caming.
Posted on Sep 15, 2005
SOURCE: EasyCap Video Capture
Hi
I had the same problem. No picture and no sound.
Here is what I did to solve it.
1. I Un-installed the software and restarted the computer.
2. Placed the installation CD (that came with the product) back in the CD drive.
3. Click on "Install Driver" (this only installs the USB 2 drivers so that the computer can see the device)
Make sure you do not attach the Easycap Device before you have installed the USB Driver (as above).
4. Once USB Driver has been installed then plug in the Easycap USB Device, windows should then detect the new device, to make sure:-
5. Right Click "My Computer" "Properties" "Hardware" "Device Manager" check "Imaging Device" (which is where my STK1150 Driver was installed) and make sure it has no yellow exclamation mark next to it.
6. Go back to CD and "install the Uplead Software", you then have to Restart the computer.
Once all installed you can then connect your external device VHS Player/Camcorder etc to the Easycap device, using the Red/Yellow/White leads.
I like many before me, tried and I tried to get the image to play on the software "Capture" screen but all to no avail, I was pulling my hair out, I wasted two days on it, I finally decided that this product was a total load of rubbish and I had wasted my money and it had to go.
Then a major break through, some smarty pants made the comment about INPUTS & OUTPUTS, my prayers along with many others could have been answered ??....
I had actually plugged the Red/Yellow/White leads into the INPUT terminals of the external VHS Player, when they should be plugged into the OUTPUT terminals of the external VHS Player/Camcorder.
On a Camcorder the RED/Yellow/White terminals are usually Output terminals but on a VHS Player they are usually always Input only !!....
I tried running my Camcorder through the software and Hey Presto that worked a treat.
So in order to get my VHS to play through the software I ended up having to buy a Scart OUT (very important "OUT") Red/Yellow/White adapter (see link for product image)
http://www.maplin.co.uk/Search.aspx?criteria=scart%20out&source=15&SD=Y
Once all connected I pressed play on the VHS Player and I have to say that nearly fell off my chair "IT WORKED - IT WORKED - IT WORKED"
Posted on Feb 16, 2008
SOURCE: wb-1400 webcam
The 'filter
> graph' message comes from that. I suggest running the command "DXDIAG" to
> see what tests fail, and what you might do to reinstall DirectX.
> Download details: DirectX Redist (June 2007) :
> http://www.microsoft.com/downloads/d...displaylang=en
Posted on Jul 16, 2008
  • 11 Answers
SOURCE: Connect LG Shine KE970 to Window Vista
Set the phone to Mass Storage.
To do this, go to settings, connection, usb connection mode, mass storage.
The computer should recgonize the phone and have it appear in My Computer.
Posted on Aug 19, 2008
SOURCE: My Samsung Tocco wont connect to my laptop with the software on
I think u would not had installed the drivers software properly. Uninstall the drivers for ur phone in ur laptop . then without connecting the phone to the laptop install the drivers . now restart and connect the phone to ur laptop . go to add hardware option and add the phone. now it'll ask for the location of software. select the option as cd. it'll ask for the port no. and all other details.. give them correctly ... select ur phone from the list and install it. now ur phone is ready to work with ur lap top
Posted on Mar 08, 2009
Code error
Before following the suggestions given below please make sure that you have the latest firmware for your DVD burner drive. Please contact your vendor or visit the manufacturer's website for the latest updates.
Please follow the steps mentioned below to resolve the issue:
1) Empty the contents of the C:\Windows\temp folder and C:\temp folder, if you have one. Then empty Recycle Bin.
2) Defragment your hard drive. DVD video files are very large and can quickly fill your hard drive to capacity. A fragmented hard drive can cause problems during DVD burning. Make sure to defragment your drive(s) regularly.
3) To avoid any compatibility issues, please close all other software and utility applications including virus scans, screen saver and instant messaging software before you launch PowerDirector.
4) Increase Virtual memory :
1. Right click on "MyComputer"
2. Select Properties -> Advance
3. Click on "settings" under Performance.
4. Select "Advance"
5. Click on "change" under Virtual memory.
6. Select "Custom" and enter initial value as "512" and Max value as "3096".
NOTE: If your existing settings are higher than recommended then leave them as before.
5) Please check whether the drive where you have installed Power Director software has enough space on it. At least 15 GB of free space is required and recommended while burning a DVD.
Now, try to burn the DVD at low burning speed.
If the issue still persists, try to uninstall other CD/DVD burning software like Nero, EasyCD Creator, Direct CD etc. Two burning software installed on same computer are known to cause conflict due to common files in them.
Also disable the XP built-in burning software. To disable the Windows built-in burning software:
- Open My Computer.
- Right-click your CD-RW or DVD drive and click Properties.
- Select the Recording tab.
- Remove the check mark from the 'Enable CD recording on this drive' check box.
- Click OK.
Also make sure that the total size of the video does not exceed the disc limit. (It is recommended that the total size should be less than 4.3 GB)
Now, close all other software and utility applications and then try the 'Create a DVD folder' option in the burning options screen and let us know of the result.
If the DVD folder is burned successfully, then the issue is burner specific and not software specific.
If the issue still not resolved, you may need to reinstall the Power Director software. Uninstall other burning softwares and then reinstall Power Director.
Follow the steps given below to reinstall your PowerDirector. Before installing your program, please close your MSN messenger, since we found that MSN messenger my lock some installation programs.
i) Uninstall PowerDirector software:
a.)Start--> Programs -->Cyberlink PowerDirector --> Uninstall PowerDirector
b.)Start --> Run --> type "regedit" --> click "HKEY_LOCAL_MACHINE" --> click
"Software" --> click "Cyberlink" --> "PowerDirector". Delete folder "PowerDirector".
c.)Start --> Run --> type "regedit" --> click "HKEY_CURRENT_USER" --> click
d)Reboot your PC.
ii) Reinstall PowerDirector. (NOTE: Before installation please close MSN Messenger, if open)
Now try again to 'Create a DVD folder'.
Go ahead with burning DVD only if the DVD folder is created successfully and without errors.
Jan 24, 2008 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
Problems capturing image
Download the free full length tutorial guide to creative movie making with CyberLink PowerDirector 9.
PowerDirector 9 hands on tutorial
Dec 31, 2013 | Computers & Internet
Serial key powerdirector 12
Download link http://filesrightnow.com/0t77D8 for CyberLink PowerDirector Ultimate 12 Keymaker by CORE. With this Keygen you can easily register your new PowerDirector 12.
Watch video tutorial on link PowerDirector Ultimate 12
Dec 25, 2013 | CyberLink POWERDIRECTOR 7 VLICDELUXE for...
Powerdirector 10 script installer error cannot create file??
Try to install on a different PC. Also, ensure you have the latest Microsoft updates and service pack. Contact KWorld for support and possible newer compatable software download from their website.
Nov 16, 2013 | KWorld Xpert DVD Maker USB 2.0...
HOW TO INSTALL POWER DIRECTOR TO PERSONAL COMPUTER?
Installing the Trial Version
1. Navigate to the Cyberlink PowerDirector page and click the "Free Trial" link.
2. Click "Try Now" and type in your name, email and country. Click "Download Now" and click "Run" to begin the download. When the download is complete, the automatic installation will open.
3. Click "I Accept" after reading the terms and agreements. Select the location to install your program and finalize the installation. You do not need a CD key with the trial version.
Dec 30, 2010 | CyberLink PowerDirector 3 for PC
PowerDirector 7
Try this link at CyberLink.
http://forum.cyberlink.com/forum/posts/list/15/1823.page
Maybe uninstall and try a new version. Try this link for that.
http://extratorrent.com/torrent/1559723/Cyber+Link+PowerDVD+8+Ultra+1830.50+Build+%2B+Updated+Keygen.html
Hope this helps. Let me know how it goes.
JimmyC
Sep 27, 2009 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
Usb connection will not shown
have u tried to go to controle panel and go to scanners and cameras and see if it is there if it is click on it
Aug 21, 2008 | Computers & Internet
The TV picture is flashing
The problem seems to be due to Cyberlink PowerDirector. Most people suggests to remove it from the computer and use other capture programs. This, of course, does not explain the stuttering display of the TV channels on a Plug-and-Play LCD monitor.
Feb 23, 2008 | ASUS My Cinema-P7131 (90C1VFV00UAYZ)
Computers & Internet Logo
600 people viewed this question
David Payne
David Payne
