Question about Frigidaire Refrigerators
Fridigaire lghs2655keo My neighbor replaced his main board, but now nothing turns on. Is there a reset switch on this unit?
    Top Expert:
  • Frigidaire Master
  • 12,962 Answers
If your neighbor replaced the main board he must obviously know what he did and is doing.. Maybe he failed to connect something. Check with him first.
Posted on Apr 01, 2014
I have a kld55w900a sony tv and it will not turn on when pressing the on/of switch unit.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. ..
Feb 12, 2017 | Sony Televison & Video
How can I fix a power cycling issue on my samsung tv
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. ....
Apr 26, 2016 | Samsung UN55D7050 55 3D-Ready LED-LCD...
Leto senl/18hd/I or 18hd/o unit keeps turning itself on and switching from heat to a/c mode on it's own.
Is unit still under warranty? If so call manufacturer And request new board and is there a board for outdoor unit? If so, get one of those too. Tell them U will return unused parts. replace outdoor board first and check. replace indoor board and test.
Oct 24, 2014 | Senville 18000 BTU Ductless Air...
Eheat will not come on
When resetting anything electronic, leave switched off for about 15 mins. The electronic boards store the memory of any failure or problem and switching off for only a few seconds or minutes will not reset the board. Turn off at the mains supply not the wall control.
Nov 25, 2013 | Heating & Cooling
Wont turn on just makes a click like it is trying
Mar 26, 2017 | SVA-USA HD4208TIIIBU 42 in. HD-Ready...
Malfunction(Code 3451) of Bizhub C252
This is a fuser heat error. The fuser unit is located in the area where the paper exits the machine. It heats up and "fuses" the toner onto the paper. The error code means that it did not heat up properly. This means you will most likely need a service person to come out and diagnose the problem.
You can try to reset the error but I doubt it will help.
Turn off the MAIN power switch (not the one on the control panel)
Now hold down the utility key while turning on the main switch and continue holding the utility key for at least 10 seconds. You should see a screen come up with nothing but "trouble reset"
Touch trouble reset and you should see a small "ok" come on. Then turn off then on the main switch again.
Good Luck and Thank You for using Fixya.
Apr 01, 2010 | Office Equipment & Supplies
E-5 error code
E5 code refer to fuser unit.To dfisplay both digits press the Enter.
E 52 Fusing error 1 Defective thermistor,heater lamp open,defective main or ac/dc drive board.
E 53 Fusing error 2 thermistor in shortcircuit,fusing harness shorted or ac/dc power supply board defective.
E 54 fusing error 3 main board or ac/dc board defective.
E 55 Fusing error 4 rhermistor open,defective main board or fusing lamp open.
When E5 service call condition occur for safety reasons they cannot be cleared by turn OFF/ON the power switch.After repairing the copier turn ON the main switch.Enter in the SP mode and press 97.Turn the main switch OFF wait 10 sec and turn ON.
Oct 07, 2009 | Ricoh FT5832 Copier
I have gestetner 2722ztd copier when i replace the explosure lap the copier dispalys error code e1 on the screen .how i clean/remove the error massege ? please help me
Please check after replace the continuity the expo lamp,expo thermofuse.The E codes are displayed in the copy counter.To display both digits of the E codes press the enter key.
E 11 - Exposure lamp error.Possible cause: expo lamp open,expo thermofuse open,power supply defective,main board defective.
E 12 - Exposure lamp error.Posible cause:AC drive board defective,main board defective.
E 13 =Zero cross signal error.Possible cause:main board,power supply defective,zero cross line open or the conector on the main board is not conected correctly.
For reset turn ON/OFF the main switch unplugged wait 10sec and turn ON or:turn ON the main switch,turn DIP switch 101-1 ON/OFF and turn the main switch OFF/ON.The DIP switch is located in the rear parts into the main board.
Sep 20, 2009 | Gestetner Office Equipment & Supplies
Rudd Furnace under-achiever 90 no lights nothing power going to unit and 3 amp fuse check out OK! I had the board, and blower replaced today ran for about two hours and now nothing again!Same problem!...
You say you have power but what is the voltage? You said that that you are using a 3 amp fuse so you are referring to a gas unit. Ok, have you checked the safty switch that is located on the blower cabinet, the one that the door sits against to make sure that you have power leaving the switch? Also, on some units, there is a limit switch that come directly off of the above mentioned blower cut off switch that when tripped, will cut main power to the board. Its located on the inducer or on the flu pipe, but mostly on the inducer houseing. Make sure that all your manual reset limits are reset. But check the switch first and then work your way to the limits. This is the only thing left and was probably the probablem before you replaced the board. If you have any more questions, please respond to the thread.
Mar 31, 2009 | Ruud UBHC Air Conditioner
Back light comes on nothing else
This is indicative of a bad main board that will need replaced. For this model make sure the repair person has the full product code (from the back of the unit) so that they can get the correct main board ordered (there are multiple versions depending on the product code). Hope this helps.
Oct 21, 2008 | LG 32LC2D Television
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
