Question about Gateway MT6723 Laptop AC Power Adapter (4.3A 75Watts) by Amstron (Generic) AC Adapter
Laptop will not turn on
I bought a gateway laptop from somone on the street and they told me that they were using it until the battery died out they did not have the charger so i bought one at amazon and the lap top makes a high pitched whine when i plug it in and it will not power up at all no lights or anything please help me....
  • Gateway Master
  • 3,320 Answers
The hard drive is dead. Replace the hard drive, add an OS like Linux (free) and away you go. Next time don't buy a computer from someone you don't know.
Posted on Apr 01, 2014
Gateway 6920
The dying hdd cause some problems. Replace the hdd.
Feb 21, 2014 | Computers & Internet
How to do a clean restore without the disks?
if it has a recovery partition you should be able to use it by pressing Alt and F10 after you switch it on. If not you will have to use a windows disc.
Jul 24, 2012 | Acer Aspire 6920 Notebook PC
MD781 battery wont charge...will run with the power cord plugged in, I replace the battery first thinking that may be the trouble. Still wont charge...it would run for a short while on the battery when...
Hi
Can you please try to leave laptop switched off
plug in laptop and leave until the light on front goes green or at least 2/3 hrs
then unplug power cord
switch on laptop and use it or leave it until it looses all power and switches off
then recharge until green
when battery is fully charged always un plug and use on battery power
until it reaches about 10% before recharging
some people even remove their battery to preserve it if they always use power cord
if this does not sort the problem please come back to us
many thanks
Feb 23, 2011 | Gateway MD7818u Notebook
My gateway M-7031U stops charging at 30%
Unfortunately your battery is probably shot. First though, try to run the battery down until the laptop dies. Now with the discharged battery, and the laptop powered off, plug it in and leave it off for a few hours. Power the laptop back on and check the charge level. Still at 30%? Then the battery is very likely just bad. Unfortunately, the cells in the battery just simply die for a number of reasons, and capacity is lost. This is why most manufactures will only warranty a battery for 1 year.
Take the battery out and write down the model number and the "MAh" or "Ah" number. The MAh number represents the capacity of the battery. The higher this number, the generally longer the laptop runs on battery. Go to http://gateway.shopbysystem.com/gateway-m-7301u-notebook-accessories.html and verify that this is your laptop model. This is a Gateway authorized reseller. Looks like they want $90 for a small battery. Take your battery model number and go to Amazon and look up the battery there. Make sure it's MAh number matches or exceeds what is on your battery. Usually you can get a replacement battery from Amazon for about $20 less than Gateway.
Oct 21, 2010 | Gateway M-7301u Notebook
My laptop will not charge not one bit it is a gateway solo#5189
Usually this just means it is time for a battery replacement. They will last 1-3 years depending on how you use and charge them. Here are a few things to try to make sure it is the battery.
Some laptops will run without the battery installed so you can check this out by a few simple tests. Take the battery out and try turning on the laptop if it runs then you know its not the laptop or the power supply. If it is one of those laptops that wants the battery in then you need to check the power supply with a volt meter. Normally its not the power supply so if you can't do this don't worry.
Next look at the battery and if it has a reset button on it. Laptop battery's have a little micro controller that sometimes needs to be reset to operate normally. If it does reset it and try charging. If it doesn't have one don't worry.
The last thing we can try is try charging the battery then unplug the power supply while running. If the laptop just dies within a few seconds or minutes then your battery is definitely the problem.
Usually you will notice that the battery is getting warmer and the time it will run on the battery is shorter and shorter until it just won't run at all on the battery. Check around for a replacement battery, don't just get the first one. Just had one customer last week have this problem and they were told $160 and a week to get one in, checked another place and it was $84 and overnight. So it pays to shop around for these.
Aug 05, 2009 | Gateway Computers & Internet
I have a Gateway 4525GZ power problem
your ac adoptor is not correct it is low amh
please check for original adoptor
Jul 30, 2009 | Gateway 4525GZ Notebook
Battery keeps dying?
clean the cables, if still not working, every time you finished using the car disconnected the negative cable from the battery. and then connected it back when about to use it again.
Mar 30, 2009 | 1994 Jeep Cherokee
Gateway Laptop M350WVN- not booting at all
it may need to be left on charge for a while...
when u first boot by pressing power wait for a minute or so and press and hold power button til shut down then try reboot..also try boot from disk....need to distinguish whether motherboard or software issue.
Feb 05, 2009 | Gateway Computers & Internet
Laptop Gateway mx8711
Gateway laptop is really ****.
I bought Gateway MX8711 in March 2007, after 6 months i use it...the hard disk failed.
Gateway replaced a new Hitachi hard disk for me but not more than 8 months and it failed again.
Gateway told me that i have no more warranty because the repair warranty is only 90 days.
I bought this laptop and use it not more than 2 years, the hard disk was failed twice.
Usually Hard disk manufacturer provided 3 years warranty for the hard disk. The manufacturer year of the hard disk is May 2007....they should able to help because the har disk not more than a year being used...but they don't. This is really bad customer service and not fair to the buyer.
I will not buy any Gateway products anymore....i swear.
Jun 24, 2008 | Gateway MX8711 Notebook
Gateway MT6723 Laptop AC Power Adapter (4.3A 75Watts) by Amstron (Generic) AC Adapter Logo
49 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
