Question about SMC Barricade g SMC2804WBRP-G Wireless Router
Invisible network hard disk
Hi, i have this Freecom External Hard Disk connected via cable to the router, but even if i can ping it from my computer (wireless connected), i can't see it in the network resourses. I've tried turning off all firewalls, but nothing happened.
    Master:
  • 409 Answers
Well, if you can Ping it, then the firewall is not likely going to be blocking it. Regardless, which product do you have ? The Silver Stone 2-drive NAS ? If yes, you should be using the FNS Assistant (FNSA)
The Freecom Network Storage Assistant helps you to locate your Freecom SilverStore 2-Drive NAS in your network. It can also be used to:
- quickly open the SilverStore 2-Drive NAS configuration website.
- configure the basic settings.
- mount shared network folders.
a) Start the FNS Assistant and select the device from the device list.
b) Go to "Web interface of your Freecom Network Storage device" for initial configuration
hope that helps.
Posted on Apr 14, 2014
SOURCE: My laptop cannot locate my network
have you tried MAC filtering to remedy your problem?
Posted on Mar 24, 2008
ziraffa
  • 827 Answers
SOURCE: Using Wireless + PPPoE at the same time kills router. SMCWBR14-G2
From your description, I am assuming you have a direct ethernet connection from an RJ45 connection in a jack in the wall. If this is the case, then you would just need to purchase a wireless router (linksys, D-link, netgear, etc). Connect the ethernet connection from the wall to the routers internet or WAN port. You will need to access the routers firmware configuration and set it to connect with PPPoE, so get your username and password from your ISP if you are not sure what it is.
You will be able to continue to have the PC plugged into the router with an ethernet cable, and then run the laptop with a wireless connection, just be sure to configure the laptop with the security key if applicable.
If you were using a software PPPoE connection on your PC, quit using it. Just set your network adapters on both computers to DHCP, and you should be good to go.
Hope this helps
Chris (ziraffa)
Posted on Jan 14, 2009
beeveez
  • 167 Answers
SOURCE: continues lost of connection using router
- Kindly make sure you already configure the required ports of emule to your router.
Posted on Mar 14, 2009
  • 5 Answers
SOURCE: cannot set up security on wireless router "wireless card nt found
Are you trying to configure the router wirelessly. Connect your computer to the router with a lan cable and then access the router and change its wireless settings. since you cannot change the wireless settings wirelessly as you will get disconnected.
Posted on Sep 07, 2009
  • 40 Answers
SOURCE: SMC2804WBR router: The lights are on but nobody's home.
Sounds like the router is about to die. I had the same issue with a wireless router a few years ago. It would broadcast but I would not be able to get onto the wireless no matter what I did but plugging straight into the modem and it worked just fine. If you've done a hard reset and it is still not connecting or staying connected, it is about time to replace the router.
Posted on Nov 17, 2009
Testimonial: "Well, that's not the answer that I wanted, but it does make sense. Thanks :)"
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Says 4gb not 250gb.
It sounds like your OS (windows XP+, I presume, as it's NTFS) is reading the wrong partition information from the hard disk.
Use this (free) partition software to delete all partitions on the external drive (and make VERY sure that it's pointing at the external, and not your main hard disk!).
http://www.partition-tool.com/personal.htm
...so delete all partitions; make a new one and see if that is 250 GB.
If yes, format.  Sorted.
If no, you could try editing the partition table directly with this:
ftp://ftp.symantec.com/public/english_us_canada/tools/pq/utilities/PTEDIT32.zip
...you'll again have to be careful you're working on the right hard disk.  To use this, you'll need to know the number of heads, cylinders etc.  This data might be on a label on the disk (inside the external drive case), or you might be able to get it from the disk's manufacturer; either on their website or by emailing their tech support.
If editing the partition table doesn't work, or if the numbers keep reverting/changing, then it's highly likely that the hard disk is stuffed.  Only thing to do then is replace the hard disk in the external case (make sure you swap for the same type: IDE for IDE and SATA for SATA); or explore your warranty options.
Hope that helped.  Good luck!
Mar 03, 2010 | Freecom (24358) 160 GB Network Hard Drive
My toshiba lap top starts up as normal then the msg media test faiure and no bootable device whats wrong
The laptop isn't seeing the hard drive. It has either bounced loose (doubtful) or the hard drive is defective. You can open panels on laptop and find the hard drive, remove and then replace it and see if it reads. Failing this check to see if it's still on warranty or buy another one similar to yours.
Nov 27, 2009 | Computers & Internet
My 250gb hard drive is not working
Assuming this external hard drie is powered via USB, you probably just need the drivers:
http://www.freecom.com/ecsupportdetail.asp?serie=Mobile+Hard+Drives&group=1148826&interface=1148827
Jul 01, 2009 | Freecom (24358) 160 GB Network Hard Drive
Hard Drive not detected
If you are sure that the disk is okay, then I do suspect it is a power problem. Laptop USB ports often can not provide as much power as desktop USB ports. If possible try using an external power adapter with the disk and see if that works.
You can try some other external hard disk troubleshooting ideas, but probably it is the power.
Jules
Jun 10, 2009 | Freecom (24358) 160 GB Network Hard Drive
Freecom 400gb not being detected
you may need to format it via Computer Management->Disk Management if there is nothing in it.
Apr 17, 2009 | Freecom (24358) 160 GB Network Hard Drive
Freecom external hard drive classic 2.5
Have a look here>
http://www.freecom.com/ecDrivers.asp
I can't see any Mac drivers for the drive...
I found this page>
http://freecom-usb-osx.sourceforge.net/
You might be able to get some help here...
Jan 03, 2009 | Freecom (24358) 160 GB Network Hard Drive
Secured and compressed jpgs will not open
Hello patsyzara
(01) 1st, for now (as a precaution against data loss), please, don't add or delete anything to or from that external HDD (hard disk drive)
(02) Just to make sure, the photos and not just a catalog of the photos were originally stored onto the external HDD, yes?
(03) Do you still have access to the computer where you originally had the external HDD connected at the time you encrypted the files (photos)?
Even if the protected files were on the same external HDD that you are using now, the protection software is possibly associated w/ the computer on which the files were fist stored.
(04) Please, tell us exactly what mechanism (the name of the software, etc) you used to originally encrypt these files.
(05) Did you recall if you used software that came w/ the external HDD to encrypt your files?
(06) Please, tell us the the following:
(A) The operating system that was installed on the previous computer you're referring to. (Windows 2000, Windows XP, etc.)
(B) The model number of your Freecom external HDD. (look for a sticker or any markings on the case).
(C) The name of the encryption software if you can remember.
(06) If you still have access to the original computer, connect the external hard disk to that computer and tell us if you can see the files again.
(07) If you can, decrypt the files and then transfer the external HDD to the new computer.
If you need assistance w/ ANY of these steps or have any questions at all, comments, observations, etc., please, post back here w/ them. We will continue to work w/ you on this issue until it is resolved or we reach an impasse.
Thank you
BJ @:)
Apr 15, 2008 | Freecom (24358) 160 GB Network Hard Drive
Freecom external network drive 500gm I installed today via wireless router and connection main pc and laptop and copied files over. Now does not work and will not see the external drive. Operating...
If it is a network drive. I believe it must have an IP address.
The best way to start troubleshotting is to know the ip address
Then you can ping the Ip address to know if your computer can see the drive.
If the ping time out...then the drive is not on the network.
If the ping reply then it is on the network. so you'll need to look at the share.
Rgds,
Mar 21, 2008 | Computers & Internet
SMC Barricade g SMC2804WBRP-G Wireless Router Logo
91 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
