Question about Whirlpool Refrigerators
How to replace water line whirlpool refrigerator
There was a pinhole size leak in the water line behind my refrigerator. I need to know what parts to get and how to replace this hose.
    Master:
  • 439 Answers
You should valve the water off to stop the leak first. You can remove the complete line that is defective, usually a 1/4 inch tube either plastic or copper. Use two wrenches to loosen the compression nut fittings on each end, one wrench holds one part and the other wrench on the nut on the 1/4 inch line. Your local hardware store should have a kit or replacement parts readily available if you bring them what you removed, the water line and connecting device. It may be a good idea to replace the water filter while the water line is out of service. The water filter should be flushed out before using the water from it.
Posted on Apr 12, 2014
SolutionGuy
  • 331 Answers
SOURCE: Whirlpool GD25 replacing water line
Nick, this is a bear of a job. You may just wanna have fun at parties after all is said and done! 1.) Remove the door from the unit. at the top hinge, remove all screws and disconnect all wiring. Tilt the door toward you and lift it off the bottom hinge. Lay it on the floor handle down. 2.) Remove the liner. Peel the door gasket back a little... see all those 1/4" screws? They have to come off. (*NOTE---> note how the door gasket fits/tucks into the liner, it'll have to go back that way) After the liner is off, you'll see the back side of the dispenser area. Make a note of how all of the insulation and the wiring is located, then remove all of it. There you go! Good luck with it. Speaking of parties, you could actually invite your friends over and make a "drinking game" out of this one... someone takes a drink every time they moan and say "how does this go, again?" or "#%@^!**". Then again, maybe not... 'cause once you start, you HAVE TO finish. Otherwise the freezer would be open and you and all your friends would most likely be passed out on the floor 'til mid-morning! Moral of the story? Don't drink and do this job.
Posted on Aug 23, 2007
SOURCE: frigidaire refrigerator leaking water inside refrigerator
There is a plastic panel inside the frigidaire looking at the underside of the freezer inside the refrigerator compartment which holds the thermostate dial and the light fixture. remove the four 1/4 in hex head screws holding the assembly. pull the panel toward the front. you will expose the drain hose connection you can let it dangle from the plug wires or remove the panel completely, I worked with mine in place. look at the back funnel shape drain. just in front of that see a rectangular styroform collar which should be snug fit to match the underside. clean and dry all. there is a divider between the two funnel compartments, mine was separated between the plastic and the styroform. I used kitchen and bath tub caulking to seal the gap. and a little around the rectangle shape that fits to the underside. plug the wire back in if disconnected. reassemble the panel. that may fix it. good luck.
Posted on Jun 17, 2008
  • 6 Answers
SOURCE: water line broken for Kenmore refrigerator near compressor
Cut off a piece of line and go to a good hardware store, they can show you how to fix it. Need a coupling, and a nut and ferrel. House water line goes on one end of coupling, nut and ferrel on the broken water line on fridge. A good hardware store will be able to show you how to fix.
Posted on Aug 07, 2008
  • 198 Answers
SOURCE: Water Dispensor leak on Whirlpool Refridgerator
The solenoid valve needs replacing, located at the back of the refrigerator. If you have well water you will need to install a filter on the supply line.
Posted on Jan 05, 2009
peyton32034
  • 410 Answers
SOURCE: Water spout replacement
this is a surprisingly easy repair that you can do in about 30 minutes.
  • first remove dispenser cover: there are 2 slots on the very bottom of the cover insert flat tip screwdriver and carefully pry it off. then you should be able to disconnect a wiring harness and lay the cover to the side.
  • next move switch console out of your way: you will either have 2 screws or 2 thumb latches on either side. you may need someone to hold this out of your way for the following steps.
  • we need to disconnect the incoming water line down at the bottom hinge: remove kickplate and find the water line you should find a connector. while pushing the tube into the connect push down on the collar then pull the tube out of the connector.( you will most likely get a little bit of water when the tube pulls loose.
  • back at the dispenser: find where the tube comes out and remove any retaining screws, then gently pull the entire tube up and out of the door.
  • now do everything in reverse to finish up: the tube will push abck thru. when you get back to the hinge the tube may hange up I use a very small screw driver to line the tube up to come back thru the hinge.
  • whne you reconnect the tube at the grille make sure that the tubing seats all the way to prevent any leakage
Be surre and be safe by unpluggin the unit before you perf any type of repair water and electricity dont mix. good luck Peyton
Posted on Jan 31, 2009
Have whirlpool gold refrigerator with freezer on top. Water leaking continuously out bottom on floor. I turned water valve behind to off. All leaking stopped. Can someone tell me where to look for the...
One big question before you go hunting. Before you turn off the water, was the water running all the time? Meaning if the water had a continuos flow the leak is before the fridge. If the leak is erratic then its on the valve side to fridge.
Follow the water source in the fridge, supply line to water valve (bottom right behind the fridge), from there it should run straight up the back into the freezer. So, if the water is coming from the valve, replace it, if from the water line - replace it. If the water line came off or out of the freezer reconnect and check for a frozen fill tube.
I hope this information helps.
Oct 21, 2013 | Refrigerators
Whirlpool refrigerator water dispenser not working
hve u tried to clean any blockages in the unit.let me know wat other problem u face
Oct 23, 2008 | Whirlpool GS6NBEXR Side by Side...
I have a Maytag MSD2432GR side by side. I am finding water pooling in the bottom of the Refrigerator side, as well as finding periodic puddles in front of the fridge. What is the cause and how do I fix...
IT MAY NOT BE LEVEL. the fridge has condensation that builds up on it but usually evaporates. you may also have a pinhole size leak in the icemaker line behind the fridge.
Jan 13, 2011 | Maytag MSD2756G Side by Side Refrigerator
I have a side by side GE refrigerator model # PSC25MSSA. The ice dispencer recently started to leak water, after producing ice. Water is frozen as it's leaking from the ice tray and forming icicles. What...
You need to replace the ice maker. There is a updated ice-maker that replaces the older models. Here is a link to the part you need and it comes with the instructions.
Happy Holidays The FixYa Team
Dec 23, 2010 | GE PSC25MSS Stainless Steel Side by Side...
Leaking from a tube like object under the front of frig. It looks like a small pinhole in the bottom of tube. Can I take part off and replace
Here is a link to Whirlpools User and Part Manuals=> sea_breeze_21.jpg From the drop down choice choose Consumer and paste or write ED5VHGXMB10 and then click search.
And below is a link to Point and Click=> sea_breeze_6.gif I believe your water supply line has a pinhole in it and you should shut off the water at its source to pevent any electrical shorting. Here is a front view of your refrigerator=> ED5VHGXM10
I believe it is either the tube filter inlet or the tube filter outlet=> 8201597 or 2255153 You may find locally, If you need me please let me know, Thanks, Sea Breeze
Dec 11, 2010 | Whirlpool ED5VHGXM Side by Side...
Auto defrost works fine except for water accumlating in the bottom of unit under the bottom trays instead of in the water tray by the compressor. graywolf7499@yahoo.com
There is a leak or damage of the pipe leading from the evaporator downwards.The defrosted water is leaking out of the tubing to the bottom,replace this tubing or check the leak on the collecting tray under the evaporator.
Sep 30, 2010 | Whirlpool Refrigerators
Why is water pooling under the crisper drawers? someone mentioned a humidity problem but there aren't any controls so what do I do? whirlpool ET18GMXHW0
Check the water reservoir behind the crispers for a leak. It could be a clogged defrost drain also. If you keep a jug of drinking water in the frig check closely for a pinhole. These are my first places to look.
Eric
Feb 01, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker Input leaks
Yes, you can replace the part. It's the water fill valve.
But take the line off the connection first and make sure the valve is corroded too severely. It may be that you can just redo/replace the fittings cut the line back a little on the house side water line.
Jan 28, 2009 | Whirlpool ED5VHGXM Side by Side...
Jan 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water valve
order the water inlet valve model specific. its located behind refrig where he wateline is hooked into
Mar 06, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
150 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
