Question about Canon Office Equipment & Supplies
I have a Canon MP530 that won't power on.
I have a Canon MP530. After cleaning the printer head and replacing it... the printer wont power on. I tried the printer head in another MP530 and the same thing happened... no power. I unplugged for an hour or so and when I plug in again, I hear a very quiet electrical pop and still no power. It acts like there is a short but can,t figure out where it would be. Same thing on both printers now. I leave them unplugged then plug back in and hear the same pop sound and no power.
  • bexarbucky
    bexarbucky Apr 27, 2014
    this link has an error and is broken
I pulled the power cord.
inverted the printer, depressed the two click to release tabs that let the plastic power box slide forward.
i then unplugged the two plug in groups of wires and re-plugged them.
inserted the power cord again..... And it worked
took 1 minute to do
Posted on Mar 20, 2015
  • Canon Master
  • 783 Answers
Go To Below official Canon Printer Page For Your problem,
http://forums.usa.canon.com/t5/errors/FilterErrorHandlerPage Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Canon Printer Support
Posted on Apr 01, 2014
SOURCE: canon pixma mp530 problem error code 5100
i had the same problem. aall i did was open the printer up and moved the thing that holds the cartridges to the middle by hand. mine seems to be working fine. post again if its still not working.
Posted on Nov 16, 2007
  • 79 Answers
SOURCE: Clean printer head for iPF700 instead of replacing
If you have blocked nozzles unfortunatelly you have to replace the print head.
What about the nozzle check pattern?
Posted on Mar 30, 2009
  • 6 Answers
SOURCE: HP Officejet 7410 All-in-one No Power Light
Turn the printer upside down right underneath where the cartridge station is you will find a small white gear...sometime it may be covered with a blue rubber cover.
when you turn the gear ..the barrier in front of the cartridge will go down.
Then do a rest on the printer and then install it.
Posted on Jun 08, 2008
  • 145 Answers
SOURCE: Canon iPF700 printer used only occasionally - print head dried up
I recommend shutting it off when you dont use it.
Also if you use it on a regular day like say Wed, then print just a bit with it during the week on say Monday or Friday (or both)to keep it from drying up.
I hope this helps!!!
Jim
Posted on Aug 06, 2009
SOURCE: Canon MP530 print head malfunction
I had the same problem with my printer. There is a switch that tells the printer that the cover is open or closed. Unplug the printer. Open up the printer cover and look on the inside right side edge. About half way back, you'll see a 3/4 inch by 1/2 inch hole where this switch resides. If you put your finger into it, you may be able to push on a lever and it will go down. It should spring back up when you pull your finger out. If you can feel the lever but it just sits at the bottom then there either this lever is broken or the spring fell off.
The problem with my printer was the spring had popped out. To access the switch, you'll need to remove the right side cover. Do this by removing the two screws in the back on the right side. Open the printer cover and find the third screw. It is located on the right hand side, near the front of the printer, on the top. Remove this screw and pop out the cover and see if you can find the spring that is attached to the lever. Make sure you do this in an area that if a small piece fell out you could find it.
Look at the switch and lever. If there is no spring attached to the lever then it is most likely the problem, otherwise the switch may be bad or the electronics inside the printer. There is a hook on the lever and one on the printer. Reconnect the spring and it should fix the problem. I found my spring had completely fallen out and fell on the floor when the cover was opened. It is possible that this spring if fallen out can fall back inside the printer so you may have to shake the printer to find this little spring. It is about 1/2 inch long. Hope this helps.
Posted on Sep 10, 2009
Canon pixma mp530 not printing colour. The cartridges are new, when I print an alignment, no colour prints, only the black and white. I've performed a clean, deep clean, print head alignment, nozzle...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jun 15, 2011 | Canon PIXMA MP530 All-In-One InkJet...
MP530 all in one printer - bought Staples magenta & blue inks but printer won't print those colors but did print older Canon inks not needing replacing; bought new Canon magenta & blue inks but...
What you can do is take the ink cartridges out of the print head and remove the printhead. Hold the print head over a trash can and take some 409 cleaner and spray the little pads inside the print head til you start noticing the colors dripping into the trash can. You will them want to dry off the print head as much as possible and litely wipe off the outside and the bottom of the print head with a paper towel. Then reseat the printhead back into the printer and the inks. You will then want to run a nozzle check from your printer software or from the printer properties. If the inks still are not showing up run one or two cleanings. If the issue still persists then you might have to replace the printhead. If this is the case you can look up part number: QY6-0059-000 online to replace the print head.
Jun 30, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Check ink canon mp530
Hi! You may need to run HEAD CLEANING first before the ink goes the ink well. Try this and it may work. Hope this helps and good luck!
May 12, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Printer will not print docs. ink cartrdges are in
I had to replace the printer head!! I cleaned the heads twice and then did a deep clean....still did not work! I replaced the head and now is good as new!
Feb 14, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP530 All in One Printer won't print black
Try deep cleaning the black cartridge in the Maintenance section of the printers properties. Print head might be clogged cli-8m
Sep 11, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP530 Error Code 5100
OK. It sounds like there's something on the carriage bar restricting the movement of the ink carrier. Perhaps some ink got on the bar.
Try taking a clean lintfree rag dampened with rubbing alcohol and clean the bar. This may have to be repeated a number of times to get the foreign matter off the bar and the ink carriage.
Let me know if this helps. iF it does not we can try something else.
Thanks.
May 05, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Installed all new ink cartridges and now poor printing results
Dear louis,
You have done right thing by cleaning the print head. If the print head still clogged after repeatedly cleaning, It seems that the print head need to be replace with new one. Make it sure by printing nozzle check pattern. Is it good or not?.
Regards,
Source:
Canon Inkjet Printer Forum
Nov 28, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon mp530 all-in-one
have you tried cleaning the printhead. on the printer there is a button that's labled menu, go to maintance and selelect print head clean. after the printer has done this, in the same section "maintance" you can print a nozzel page and that will show if if there's a blockage in the print head. if the nozzel check is ok, and your getting the problem when you print from the computer, check the setting and make sure you haven't got it set on draft or lower. Good luck
Feb 11, 2008 | Canon PIXMA MP530 All-In-One InkJet...
No yelllow on Pixma MP530
Yes you are correct, it will be print head, to ensure long life of head stay clear of so called compatible supplies they often trash heads.
953c462.jpg Part info/pricing
Jan 11, 2008 | Canon PIXMA MP530 All-In-One InkJet...
170 people viewed this question
old marine
old marine
