Question about Polycom V700 (2200-23480-001) Video Conference
The unit says video conferencing across the top of screen
Black screen with the words video conferencing. Camera is not working and nothing else is showing.
Sanyo TV model T27547 has horizontal lines across the top of the screen in front of what is being showed on tv. Is the tv worth trying to fix the picture is still very good.
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 02, 2017 | Sanyo Televison & Video
GoToWebinar won't launch
Feel free to visit the GoToWebinar customer support page and find a solution.
https://care.citrixonline.com/gotowebinar?c_prod=g2w&c_name=mktg
If that doesn't work, try another video conferencing solution provider.
Top 5 Video Conferencing Programs
Jul 20, 2012 | Citrix GoToMeeting
When I turn my 60 gig PS3 on, it only gives me a black screen for about 5-10 seconds, then picture of 2 cartoon penguins in the top-left hand corner, and the rest of the screen has white computer text...
hold the power button for 5 seconds, a menu will popup to u chose to repair ur PS3, if it didnt work with u, do it all over again but this time go with format option and i will word :)
Nov 24, 2009 | Sony PlayStation® 3 (60 GB) Console
How do I video conference with someone? do they have to be a live member?
depending on who you want to video conference with. if the people is subcribed to live, and you have a live account then you can use windows live messenger to video conference with them.
Sep 23, 2009 | Microsoft LifeCam VX-3000 Web Camera
Black screen in REC mode, bars across the screen in Playback mode
My advice is that you should by a DV cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
Luwangula
Jul 20, 2009 | Canon ZR80 Mini DV Digital Camcorder
IBM Video Conferencing PC Camera Webcam ksx
IBM 33L4889 Digital Camera drivers for xp. contact me at billfox1966@yahoo.com and will discuss means of file transfer
May 08, 2009 | IBM Webcam
Black screen on camcorder
I think you have two different issues here. The black screen may be due to a CCD failure. Canon has a worldwide service notice regarding this issue, and will repair your unit at no cost if they determine this is the problem (it sounds like it is).
The little red symbol indicates your backup battery (or date/time battery) CR1616 needs to be replaced. It is located behind a small square panel which you can see to the left of the menu buttons when you open the LCD panel.
Dec 08, 2008 | Canon ZR70MC Mini DV Digital Camcorder
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Display shows a set of black bars
tape guides are out of adjustment, need to have brought in for service.
Jan 29, 2008 | JVC GR-D270 Mini DV Digital Camcorder
Display Screen is White
I would check the wires connented to the display screen. they run from the bottom to the screen.
You have disassemble the camera.
I would think first before tring this.
Remove 3 screws on bottom, 1 in battery compartment, and 1 at very top of usb flap (look good).
Now slide the side piece starting at the usb flap then apply pressure to top and away from unit.
now look for 1 silver and three black screws (facing back and front, look good).
See the screen look at the bottom follow the wires to the connector on the very bottom and check that. Remember to replace battery door first if it fell off during process.
*TEST NOTE: You can place batteries in and place a penny across the bottom to test before you put it back together.
Dec 23, 2007 | HP Photosmart M425 Digital Camera
Polycom V700 (2200-23480-001) Video Conference Logo
22 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
David Burbee
David Burbee
TEKUSER
TEKUSER
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
