Question about LG 500g TracFone
How to transfer music to tracfone lg 500g
I have tried using a Miro SD Card. It will show up on the top left of my phone, but with an x over it or a blue circle with ! in it. I have also tried a using a date cable. When I connect to my laptop my phone doesn't show up. Sometimes my Sd Card will completely disappear. Can you us bluetooth to transfer music? Can you us a PNY Mirc SD Card 8GB with the phone, if so can someone give me the step by step formatting? How can you just us a cable to transfer music, if so how?
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • 22 Answers
To transfer files to a phone, you can use an android transfer assistant, which allows you to export and import data between phones and computer.
MobiKin Assistant for Android Windows Version
Posted on Jun 08, 2017
SOURCE: My LG Chocolate VX8550 wont recognize micro sd card
Here are the steps I took:
  1. Insert the micro sd card with the metal plates facing you (that took me a second). Don't worry about the little push you have to give.
  2. Go to the Settings & Tools option in the Menu.
  3. Select *. Memory
  4. Selct 3. Card Memory
  5. Select Options while the bar is on "1. Memory Usage". The only option available to me was 1. Format and select that.
  6. It will ask for the phone lock code-if you have never set it IT IS THE LAST 4 DIGITS OF YOUR TELEPHONE NUMBER.
  7. The phone will format the card and put the file folders on it.
  8. Use the adaptor USB reader or whatever you have to connect it to the computer. Copy songs to the my_music folder.
for mp3 as ringtones:
  1. You should select the part of the song you like, and can add effects with this:http://www.mptrim.com/
  2. To set it as a ringtone, send it as an attachments to you areacodeandyourphonenumber@vzwpix.com. It must be small to go through, around 30 seconds.
  3. You will get a text message, and select options. Select Save As Ringtone.
Posted on Oct 17, 2008
marked
  • 6487 Answers
SOURCE: need to format micro sd card
It will be better if you use a card reader and put the SD card on it and format it using your computer so you can set it to FAT and that should do it....
Posted on Dec 28, 2008
  • 3 Answers
SOURCE: 8gb micro sd card does not work. lg vu cu920. is there a fix
I HAD THE SAME PROBLEM AND KEPT ON MESSING WITH THE 4G MEMORY CARD AND FOUND OUT THAT I HAD TO FORMAT THE MEMORY CARD ON MY COMPUTER AND NOW IT READS THE CARD..ON THE SIDE OF THE SD ADAPTER HAS A SLIDING PIECE THAT SAVES YOU FROM DELETING THINGS ACCIDENTALLY BUT IF YOU SLIDE IT INTO THE MIDDLE POSITION THEN IT WILL ALLOW YOU TO FORMAT THE MEMORY CARD BUT YOU WILL LOSE WHATEVER THAT IS ON THE MEMORY CARD AND WILL HAVE TO DOWNLOAD IT ALL OVER AGAIN..I HOPE THIS IS CLEAR ENOUGH FOR EVERYBODY TO UNDERSTAND BUT THIS IS HOW I GOT MY MUSIC AND PICS ON THE MEMORY CARD
Posted on Feb 13, 2009
SOURCE: transfering pics on sd card to phone
all you have to do is insert the card into the phone, go to your picture, hit the options button, go to and click manage pics from the options menu, mark the pics that you want to move to your phone, hit the options button again and select move, from that menu select move to phone.
Posted on Mar 19, 2009
SOURCE: PNY micro Sd card will not format and will load music.
Sounds like you have Windows 9x/2k. That's the only reason I can think of that it would ask for a disc, because it's asking for drivers that it does not have. Windows XP/Vista have these by default built into the OS. I would check the PNY website for drivers to install on your system so it can read the card.
Posted on Mar 26, 2009
Tracfone Lg 800 sd card has x over it
X probably means that it can't read the card. Either the card is not compatible or faulty.
Jun 12, 2016 | LG RH177 DVD Recorder/HDD Recorder
Does PNY 8GB Mirco SD Card compatible with an LG500GHL Tracfone?
check your manual. When I had one the capacity of your card may be 4G. If it is just get a 4G card to replace the 8G card.
Hope it helps
Apr 06, 2014 | LG 500g Black tracfone CePhone Lg500g...
White screen
try takeing out the battery sim and sd card if u have 1 blo on every thing and put every thing back and turn on the phone
Dec 23, 2013 | LG 500g TracFone
My lg tracfone reads unregistered sim.It has always worked until I was not using it for about a wk.
Tracfone deletes SIM cards and the associated phone number from their registration database if the available airtime minutes goes to zero. Try buying minutes for the phone. (If you wait too long (~2 months), Tracfone may not be able to re-register the SIM card. In that case, you'll need a new SIM card.)
Do you remember when your minutes were due to expire? (Remember Tracfone doesn't do roll-overs of minutes.)
I hope this helps.
Mar 18, 2013 | LG 500g TracFone
How do i transfer contacts from droid to tracfone
Is the tracphone also an android device? If so when you open your new gmail account on your new phone they should all be there.
Dec 05, 2012 | LG 500g TracFone
Can't transfer my music to LG800g micro SD card. It will go to internal memory only.
you have to download a file moving app or viewing app. it should allow you to copy the music files on your phone and past them to the sd card. This may work but if not you may have to reformat your sdcard and but that will wipe everything on your card. Another solution is to get your phone rooted is what you may have to do giving you acess to move files around better
Oct 19, 2012 | tracfone.com
My LG 500g cell phone won't connect to my computer to transfer music
see in connectivity settings for pc connectivity and change it to what you want.
Oct 19, 2012 | LG 500g TracFone
When i try to send a picture on TracFone LG500g I get a message telling me I cant send/receive message
i guess u might have not activated mms setting. ask your network operator for these setting
Mar 12, 2012 | LG 500g TracFone
My LG 500g cell phone won't connect to my computer to transfer pictures.
Completely shut of your LG 500G and remove the back. Take out the battery (and SD card) and then put them back in. Make sure your SD card is seated correctly. Turn your phone back on and connect your data transfer cable to your phone and computer. You should then be able to see your phone on your computer (under My Computer). This has worked for me when I couldn't see my phone on my computer. Hope this helps.
Mar 04, 2012 | LG 500g TracFone
LG banter won't recognize data on SD mirco card
Please try to back up the music and picture that you have on the memory card, try to format the card using the phone before transferring the music and pictures again. Try to consider the memory capacity of the card, make sure that it is compatible with the phone.
Jul 09, 2009 | Cell Phones
LG 500g TracFone Logo
61 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
