Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Black wire that goes from top to bottom on back of refrigerator is frosting up..
There's a black wire on the back of the refrigerator that comes out the top and its frosting up.
    Top Expert:
  • Admiral Master
  • 12,962 Answers
You sure it is not a tube? If it is the tube going up TO freezer from the high pressure side of the compressor then you are low on gas - evaporation is taking place there instead of the evaporator coil in freezer compartment.. If it is the tube returning to the compressor from the evaporator you have too much refrigerant - but this is only the case if you recently had unit serviced and maybe too much refrigerant was introduced into the system.
Posted on Apr 01, 2014
Testimonial: "Thank you Richie46, it is a tube. it had black insulation on it and i thought it was a large wire. lol anyhoo. There was also a putty wrap that had fallen off from the opening at the top that seamed to wrap around the tube to seal the opening. i put it back and now the frost is gone. Not sure that had anything to do with it, but I will keep an eye on the refrigerant and compressor. Thanks so much. Single female learning to take care of myself. lol"
Fridge side is warm
Do you see frost built up in the freezer side? if their is frost in the freezer its blocking air flow into the refrigerator side and here is what to check why it isn't defrosting automatically;
DEFROST HEATER ...remove back wall of freezer and you will see a black heater at the bottom of the coil thats frosted up,it looks similar to the bake element in your oven,or in some cases it is going to be a spiraled wires inside of a glass tube. To check it,use a multimeter set to the lowest ohms of resistiance setting and follow and find the wires at the top of that frosted coil,unplug/disconnect those wires and check for continuty with around 5-20 ohms of resistiance. If it has that amount of ohms the heater is good. If your meter display does not change or displays OL the defrost heater is broke and needs to be replaced
DEFROST TERMINATION THERMOSTAT... it's round and has 2 wires and clips to the top of that frosted up coil. IT MUST BE CHECKED WHEN COLD SO BEST TO DO WHEN FROST IS STILL BUILT UP. To check it disconnect the wires on it and check for ZERO ohms of resistiance. As with the heater if the meter display OL or doesnt change,it is the problem
DEFROST CONTROL...it is hard to check for a semi unskilled person and if the heater or defrost t-stat check good its going to be the problem. It will NOT be in the freezer it could be on back wall or inside the control panel in the refrigerator section.
Aug 20, 2011 | Whirlpool GS6NBEXR Side by Side...
Amana bottom freezer refrigerator model ARB2217CW keeps freezing up in the back. Please call 775 241 0494
Here is what to check to check on the defrost system;
Good luck,
Gene
oldtech2332_9.jpgoldtech2332_10.jpg-->
While these pictures are for a different brand ALL refrigerators are similar and may look some what different than your but will be similar enough to yours
I'll email you what to check but gotta pay for me us to call you
Aug 17, 2011 | Refrigerators
Maytag plus i purchased 4 -5 yrs ago went out the freezor over frosted, i defrosted the frige and now the freezor works like a really good refrigerator n the frige side doesnt work.
The thing you need to do determine why it isnt defrosting automatically like its supposed to be sure that you remove the frost from the crossover return hole in the left side wall of refrig compartmentat the bottom by the crisper drawers when its blocked w/frost air doesnt flow correctly into and out of freshfood section.
This is what to check to see why it isnt defrosting by itself;
Good luck,
Gene
Aug 17, 2011 | Maytag MSD2756G Side by Side Refrigerator
Hi...I have a Kenmore refrigerator with bottom freezer. Model #594.62234200 and it is freezing up on the bottom. (in the freezer) and getting warm on the top. I was told it may be a heater, I need? Is this...
Yes their truly is a heater it melts the built up frost in the freezer automatically so you do not need to manually need to defrost it. Heres what to check when it doesnt defrost by itself automatically
Good luck,
Gene
Aug 16, 2011 | Kenmore Refrigerators
Freezer is keeping food frozen but there is major frost build-up in the freezer compartment everywhere.
That is going to be a problem with one of the components in the automatic defrost system. It is supposed to automatically defrost. Turning it off overnight to melt it will defiently help. If you are mechinacally inclined here is what to check.
Good luck,
Gene
Aug 16, 2011 | GE Profile Stainless Bottom-Freezer...
I have a side by side and the freezer is working fine and refrigerator is not cold
Hello.
If you open the freezer door and look on the back wall do you see frost build up on the back wall?,if so yes thier is frost build up in the freezer heres what to check.
Good luck,
Gene
Aug 16, 2011 | Hotpoint Refrigerators
Freezer is cold but not freezing, refrigerator is not cold
your defroster heating element behind the frosted panel is either open(bad) or the defrost heater control in the refrigerator compartment is defective
Jul 13, 2010 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
This unit is not cooling, fridge or frezzer.All plugs are working and lights come on.
Compressor or compressor relay switch is bad. Pull the unit out from the wall, and with a multimeter check for voltage at the compressor and the switch which is located on the top of the compressor under the black box.
Jan 02, 2010 | Jenn-Air JCB2389G Stainless Steel Side by...
How do I wire the suoco 3 in 1 start in an amana refrigerator where do I connect for the power.
Good day,
Once all the original start components were removed from the compressor, there should be two wires That run back into the compartment that are your power source.
Those 2 wires go to the two black wires that are shown on the 3 and 1. Doesn't matter on those two which goes where.
You should have 3 wires left that are grouped together.
1.White goes to the bottom left.
2. Red goes to the bottom right
3. Black goes to the center top.
Dec 13, 2009 | Refrigerators
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
57 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
