Question about Clear Blue Hawaii Molokini Kayak Cbh57702
Crack in clear blue hawaii molokini hull
What would you use to repair a crack in the molokini hull?
about 6 inches long below the water line.
    Problem Solver:
  • 15 Answers
Use a fiberglass repair kit, available at most hardware stores. Use an overlay prior to patching so you don't develop a soft spot in the hull.
Posted on Aug 15, 2010
Where are the drain plugs situated on a T Cat boat
has to be out on the rear hull area
below water line or deck platform
upgrade hull with
aftermarket stainless steel or brass systems
wise to have a bilge pump
and carry bailing buckets
9f16875a-8021-465a-81f2-8f6b06be53e4.jpgindex-cvxygyvu0vydc25j522ljeey-4-2_0.jpgst-cvxygyvu0vydc25j522ljeey-4-3.jpg
Mar 31, 2017 | Boating
Water in hull of bass tender pro
Find the leak and patch it. Use a good marine epoxy system with a sheet or two of fiberglass cloth laid-across the crack. Be sure to sandpaper the area thoroughly with rough paper. If you can't find a leak or crack, fill the hull with water and inspect for leak. Repair after.
May 20, 2014 | KL Industries Basstender 10.2 Fishing Boat
Repair gas line leak
WHAT TYPE OF LINE STEEL OR PLASTIC, IF PLASTIC IT WILL REQUIRE A SPECIAL REPAIR KIT YOU GET FROM PARTS STORE . IF STEEL IN NEED TO BE FIXEDWITH COMRESSION FITTINGS
Oct 21, 2013 | GMC Jimmy Cars & Trucks
I can't find any id on my old scanoe, how can i get an id number for it.
I have one from the 1980's and found numbers stamped on the side stern quarter, hard to see
Mar 21, 2011 | Coleman Boating
Torn bow
Repair any cracks or damage to the hull with fiberglass repair kits, available at most hardware stores. Use an overlay prior to the fiberglass if the area is bigger than a quarter so you don't develop a soft spot.
May 10, 2010 | Advanced Elements Advancedframe...
My 1997 polaris jet ski keeps taking in water? what could this be??
Unplugged water tube, cracked water tube, bad drive shaft hull seal, hole/crack in the hull, cracked water box, broken exhaust jacket water seal, water tubes plugged in incorrectly, no cap on flush kit, broken fitting on motor,etc. Dry out the boat take off the seat and place it in the water and look to see where the water is coming into the hull.
Sep 07, 2009 | Polaris ATV
HI I got a 1993 mainbuilt eagle boat. with a 130 hp honda .also have a 24 inch setback plate. Ihave got the top plate above the prop 2 inches above thebottom and I'm haveing a hard time to get out of the...
I think the prop is too far out of the water. The front of the hull is going to push the water away from the transom until you get lift. If you consider the prop is just below the planing fin you need push, not cavitation. With the setback you are actually lengthening the boat and you have a void of 24 inches of water before the hull starts to throw the water out of the way.
Aug 04, 2009 | Boating
Split hull
V out the cracks with a grinder, cut fiberglass matting with an overlap of about half an inch. pre-cut 6 more pieces gradually stepping overlap to 1 1/2 inch starting with smallest piece soak in resin and place over v'd out crack, once all pieces are in place press out any air bubbles. takes a while to dry. once dry sand flat with 36 grit then 80 and 150. place a gelcoat on top
Jun 01, 2009 | Boating
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Mar 30, 2009 | Televison & Video
Not getting water from dispenser in door
if you can get ice but not water from the dispenser then suspect a frozen water line within the door . Check you get water to the connector at the bottom of the freezer door. Sometimes you can clear the blockage by connecting a steamer to the pipe but this will only be a temporary fix . If the pipe has frozen within 6 inches of the dispenser outlet then there is a heater mod that can be fitted WR49X10173
Nov 28, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Clear Blue Hawaii Molokini Kayak Cbh57702 Logo
288 people viewed this question
Top Clear Blue Hawaii Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Clear Blue Hawaii Boating Expert? Answer questions, earn points and help others
