Question about Crafts & Hobbies
The midi output will not send messages to my VHM5 vocalist harmonizer
Why does my M-Audio Fast Track Pro not send a signal to my vocalist harmonizer.
3 Suggested Answers
SOURCE: Sonar Producer 6 - Audio/midi devices/controller-surfaces..Which settings??
o always run at 0 on play back recording -3 with drums use anlog cables then select anlog 48000 24 bit if u can if its digital cable might use 96000 bit rate ok spdif watch it close on digital for digital clips never go in red keep steady balence cheak your sorse tape how loud is that adjust your stuff to sound good at peaks never hit red in digital mode does this help sum
Posted on Mar 13, 2008
  • 1212 Answers
SOURCE: No output signal for vocalist live 3
If the mic is a low Z- mic, that might be the issue. Check the mic straight into the sound card of the mac and see if it works or if it is shorted. Is there a switchon the mic? it may be dirty.
Posted on Jan 28, 2012
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
Jan 28, 2012 | Music
Have a Digitech Vocalist II that stopped reading the midi chords transmitted by my keyboard. Checked midi cords, all settings (keyboard and harmonizer). And the inside of the digitech. It does not appear...
try a different signal source (tape player, cd player etc) and see if the sound gets into your device, if it doesn't see that sound either, then the problem is with the digitech and not your midi keyboard. The digitech doesnt have midi chords, just analog so I'm a bit confused when you say MIDI. I have the digitech vocalist IV and it doesn't have midi in or out either. only analog in, also two XLR's and etc. great machine by the way, I'm sorry to hear yours has quit working for whatever reason.
Mar 19, 2011 | Computers & Internet
I am looking for user manual for Digitech Vocalist Model VHM5
Yup, that one's hard to locate...no real links on the website.
here's your link.
ftp://ftp.digitech.com/pub/PDFs/Discontinued/Manuals/VHM5.pdf
It's a bit poorly scanned, so they may have been too embarrassed to link it direct.
Feb 22, 2011 | Audio Players & Recorders
My PSR 550 giving signal (thru m audio fast track)...but no sound
You have to decide whether your keyboard will function as the controller to send the midi info to your program and have the program use the onboard sounds on your soundcard or use the sounds on your keyboard.Here is a link to a forum that I highly recommend:http://www.recordingreview.com/ It is free to join and the free download of Killer Home Recording Setting Up is great. There is lots of info on this site that will explain exactly what you need to know.Check out midi troubleshooting 101 and Getting Started with Midi Sequencing. The site owner Brandon Drury uses Cubase himself and I highly recommend their forum. Hope this helps.
Mar 02, 2010 | Music
How do we connect an m audio fast track pro to my pc and mixer (dp-01fx)?
All you have to do is to connect with 2 cables your mixer's output to the two 1/4” TS plus in the front side of the Fast Track Pro and a usb cable from the rear panel of the Fast Track Pro to your pc's usb port. I suppose that you have installed the drivers for Fast Track Pro at your pc.
Anyway in case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 20, 2010 | M-Audio Fast Track Pro Mobile USB...
How Do I Capture Live Audio with M-Audio Fast Track Pro
All you have to do is to connect with 2 cables your cd's or dvd's output to the two 1/4” TS plus in the front side of the Fast Track Pro and a usb cable from the rear panel of the Fast Track Pro to your pc's usb port. I suppose that you have installed the drivers for Fast Track Pro at your pc.
Thanks and regards
Stelios
Aug 31, 2008 | M-Audio Fast Track Pro Mobile USB...
How to hock up my behringer mixer to m-audio
All you have to do is to connect with 2 cables your behringer mixer's output to the two 1/4” TS plus in the front side of the Fast Track Pro and a usb cable from the rear panel of the Fast Track Pro to your pc's usb port. I suppose that you have installed the drivers for Fast Track Pro at your pc.
Thanks and regards
Stelios
Aug 20, 2008 | M-Audio Fast Track Pro Mobile USB...
Mar 13, 2008 | Cakewalk SONAR 4 Producer Edition for PC
Crafts & Hobbies Logo
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
