Question about GE JBS55DMWW Electric Ranges
BURNRER URN OUT
THE BURNERS ON RIGHT SIDE HAVE BURNED OUT. WHAT MODELS WILL CROSS WITH THIS MODEL SO I CAN BUY NEW BURNERS
    Top Expert:
  • GE Master
  • 9,472 Answers
Here are the elements for the model you listed.
Posted on Apr 05, 2014
Jenn-Air Model 720-0061-LP. Burners will not
burner is blocked needs cleaning out remove burner and clean it or put it in clr , or buy new one
May 18, 2010 | Grilling
Center and back burners won't light
cross over tube could be out of postion blocked or you need new burner
May 15, 2010 | Weber Genesis Silver B Grill
Need new lid for Hamilton Beach coffee urn model 40515
If you go onto the Hamilton Beach website and look at products there is a tab for spare parts.
www.hamiltonbeach.com/coffee-pots-coffeepots.html
Regards
Alan Hood
ami-man
UK
Mar 30, 2010 | Hamilton Beach GE 42-Cup Coffee Urn Coffee...
Laser burned out
If you are convinced that the laser burned out, the most you can do is to buy a new drive. It's possible to buy a new diode and replace it, but it's highly not recommended as it might not be compatible and can be very dangerous.
Mar 09, 2010 | Pioneer DVR-112D DVD RW Dual Layer Burner
Jenn Air gas grill with cast iron burners...only ignite on one side of burner...other side ports will not ignite...but will ignite right away with lit match...all three burners do this...
It sounds like your cross-over **** located underneath on the back of the burner is needs cleaning. Take your burner out, turn them over and your will see a slot on the rear of the burner. wire brush the slot until it has a clean ****. This cross-over **** is what brings the flame to the right side.
Apr 19, 2009 | Grilling
Crooked stovetop burners
This happens when purchasing pans/bowls from home depot ect..., there are so many different shapes and models you never get the right ones. Order new bowls online with your model number located behind oven door to get the correct size and the elements should be fine.
Phil
Apr 11, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Faberware Coffee Urn 55 cup
I was able to buy a spigot for my Farberware Coffee Urn FSU236 from Mxim/Toastmaster in Macon, MO PHONE: 1-800-233-9054
Jul 25, 2008 | Faberware 12-55 Cup Coffee Urn
Jenn-Air grill half burner issue
Re: only one side lighting, it is a problem with the cross over **** that carries the flame from one side of the burner to the other. It is located at the rear bottom of the burner and is probably clogged. Wire brush them to clean; failing that, replace with new ones and keep the new ones cleaned with a wire brush regularly.
May 31, 2008 | Grilling
Ignite prob
You've got two different things going on.  First - the type of igniter used on your model does wear.  I have had mine for over 10 years and have gone through 3 such igniters - and I grill nearly 3 times per week over the 25 week "grilling" season where I live. Spring for the $12 part and just replace it. The other issue sounds like a clogged cross-over system.  I would remove the burners, including the cross-over bar on the far left side that connects them.  Clean the exterior with a stiff steel/brass brush and the inside with a bottle brush.  Make sure all the holes are clear to allow gas to flow easily - use a wooden tooth-pick to do this to make sure you don't change the size of the holes! Put that baby back together and I think you'll find you'll be good as new!
These grills are great.  Now, if Weber could only fix the uneven heat problem between the left and right side I'd REALLY be happy!  (I wish they would even just admit there IS a problem!)
Good luck and happy grilling.
Mar 03, 2008 | Weber Genesis Silver B Grill
GE JBS55DMWW Electric Ranges Logo
24 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
