Question about Texas Instruments TI-5045 SVC Calculator
Can't load new roll of paper
The paper advance button won't advance the paper
  • 3 Answers
The rubber sleeve on the paper advance shaft has likely lost it's elasticity. It expands then the shaft just spins inside of it. It's tricky but I disassembled the paper advance assembly and replaced the old sleeve with a piece of small silicone tubing. Works fine now.
Posted on Apr 15, 2014
I have an old Sharp EL-1701C calculator and for some reason can not feed a new roll of paper into the unit? Batteries are new and the feed option works well, just doesn't grab the paper roll to start?
you may need to cut the corners off a little bit on the start of the new roll and feed the paper in while advancing with the calculator advance control/button
Dec 10, 2014 | Sharp EL-1701C Calculator
My tec ma 1450 register won't work just blinks 0.00 and none of the keys work
With paper loaded properly, turn off/unplug register, turn MA or Service key to "Blind" position (approx. 5 o'clock), turn on/plug in register. "Status-C" will print on the receipt. Some of these TEC's won't reset after changing paper, and this procedure becomes necessary after each installation of a new roll of paper.
Jul 18, 2012 | Computers & Internet
Canon ipf605 paper error
Here is what I've found out by trial and error.
Paper Roll Won't Load:
    -Usually occurs when the roll is less than 50% full
    -Printer will give the error "paper loaded askew"
    To Correct This:
      - Press and hold Stop until Job Cancel comes up on the
      screen
      - Press Menu
      o Scroll Down until Adjust Printer menu comes up
      o Press right side arrow next to OK button
      o Scroll down to Manual Band Adjust and press right side
      arrow again (or select one of the other adjustments)
      - Select Yes and press OK
      - Load paper roll - make sure paper is straight
      - When asked (printer will beep) select Plain Paper and
      press OK
      - Let paper load
      - When printer starts to print press and hold Stop to cancel
      job
      - Paper should now be loaded
      When all else fails load a new roll.
      This would be a temporary solution until the sensor is fixed.
Mar 12, 2012 | Canon imagePROGRAF IPF605 InkJet Plotter...
Just want to get a new roll of paper to feed in
Simply press down on the spring loaded button above the F1 key on the right side of the unit, next to where the paper feeds out of its slot - you may see the symbol of a roll of paper and a right arrow. Then after you open the new roll of paper, just place it into the cavity with the end of the roll coming out from underneath the roll itself, towards the serrated cutting blade, leaving a small amount of paper (2-3") sticking out of the top of unit. Now close the lid until you hear it click closed, and the button you pressed to begin with has returned to its 'up' position. Your paper is loaded and you may resume normal operations.
Feb 22, 2011 | VeriFone VX510
Canon MP145 Error 2
Just press the green (color) button about 5-10 seconds. Hope this help a bit.
Mar 25, 2010 | Canon Office Equipment & Supplies
Cannot load new paper roll into the calculator so it catches
Replacing the paper roll involves feeding the evenly cut, uniform end of the roll through the fine slot located under the paper arm at the back of the calculator. (Even if the paper is only slightly wrinkled or cut unevenly, it will not feed through the teeth in the loading area.)
When getting ready to feed the paper into the calculator, envision your printout feeding out of the machine away from you and back toward the paper roll. Don't insert it upside down.
To get the paper feeding through once you have partially fed it into the teeth, gently tap the paper feed button. Once or twice should do it. (The button is located on the far top left of the control panel, indicated by an arrow jagged saw mark icon).
Then, slide the paper roll onto the feeder arm and you're in business.
Apr 09, 2009 | Sharp EL-1801C Calculator
I have a Canon P23-DHV calculator and I cannot remember how to load the paper into it. I tried to read some of the solutions but could not ger any of them to open so I could actually see the solutions
  1. cut the paper/tape cleanly on a slight diagonal
  2. hang the paper/tape so it comes from under the roll
  3. insert the fresh cut into the slot on the back (between the power plug and tape roll holder)
  4. press the FEED button to advance the paper.
Now, does anyone know how to turn off this blasted auto-shut-off feature????
Jan 24, 2009 | Canon P23-DHV Calculator
LOADING NEW PAPER
HOW DO I LOAD PAPER INTO THIS
Aug 10, 2008 | Canon P23-DHIII Calculator
Load new reel of paper
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. > (Fold one side to the middle and the other side to the middle so both sides meet in the middle.
Then, place the paper into the slot where the paper feeds in.. (Usually goes under the printer assembly) and then hit the PAPER FEED button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Feb 10, 2008 | Victor 1230-2 Calculator
Paper Loading
Cut a diagonal to make a sharp corner on the end of the roll, then stick the corner into the paper slot, and then press the feed button.(arrow on top left)
Oct 18, 2007 | Canon P23-DHIII Calculator
Texas Instruments TI-5045 SVC Calculator Logo
411 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
