Question about Jl Audio Class D E1400D Car Audio Amplifier
Can you please tell me how many gauges my JL audio e1400 amplifier has, cause i have no clue and i am going to buy an amp kit but i need to know how many gause to get.
I just bought s used one today and it didnt come with the wiring.
  • Logan Cook
    Logan Cook Mar 31, 2014
    there`s nothing wrong with the amp, i just need to know how many gauge wiring kit would be recommended
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 104 Answers
12 g
Posted on Apr 02, 2014
SOURCE: blue low voltage light
might wanna do a 0-guage to 4-gauge conversion.... hit me up on AOL Instant Messanger and i'll give you more details as to why on there (normando86)
Posted on Feb 14, 2008
SOURCE: bad amplifier need help!!!!
I had the same amp! It is the JL 300/4 and one of the chanels came in really fuzzy. It sounded as if the the wires were touching during my installation. I called JL and a JL authorized dealer it would have costed me 190 dollars total to get the amp fixed. Instead I opened up the amp to see if anything looked out of the ordinary. When you open the amp, see if the green fuse looking things are aligned. If they are not aligned then straighten them out. I think they had gotten out of place from being dropped becaue I baught my amp used. My amp works perfectly now!
Posted on Mar 06, 2008
Jexx
  • 148 Answers
SOURCE: My JL audio 1000/1 amp does not work
Best bet is to send it back to JL, they do not sell the PCB with all of the components loaded on it. Most likely the transistors in the power supply have fried. Open it up and see if you can find any physical damage. Google the part numbers of the bad parts, and you should be able to fix it relatively easily. www.digikey.com is a great place for parts. Read this for more testing procedure: http://www.bcae1.com/ampfail.htm The whole site is wonderful, really.
Posted on Jul 16, 2006
GooFyTiS24
  • 33 Answers
SOURCE: i bought a 500/1 jl audio amp and also a w7 10 sub
if its cutting off and right back on then check your ground and your power wire makes sure both are connected good and none of your fuse's are blown, either that or you got a wire hooked up backwards in the sub.. but my guess is that the sub is hooked up wrong... that sub should be hooked up in a series or in parallel,
ok if your running just one speaker, it should be hooked up like this and 2 speakers are a different way...
this is parallel :pos to pos , neg to neg, then one wire coming from pos on sub to pos on amp then neg on sub to neg on amp but bridge the amp on your amp should be 2 pos and 2 neg in two different channels take the pos off the sub into the pos on 1 channel and then the neg from sub to the neg on the other channel,
this is series : on the sub it will go pos to neg then the other neg and pos will go to the amp, but make sure the pos and neg r on different sides of the sub, dont hook them both to the same coil
if your need more help give me your email and ill send you a pic of how to do it...
Posted on Aug 12, 2008
  • 12 Answers
SOURCE: Jl 500/1 amplifier will not turn on
you may have burned the channel you were using..try taking the cover off the amp and checkin for burned spots or any wires that may be loose or touching within the amp.
Posted on Feb 26, 2009
Can you run a 8 gauge power wire to a jl audio 1000/1 amp and not have problems even though jl reccommends 4 gauge power wire?
Hi, if you're going to run a smaller wire, you also need to use a smaller fuse. A 50 amp fuse is needed for 8 gage wire. The fuse is there to keep the wire insulation from melting, which is what will happen if you run too much power thru the wire. If you don't plan to turn the amp up too high, this may work fine, but I would test it first with a 50 amp fuse before installing. You will need all of the speakers hooked up and the gain set to max to test the power draw. See the following link on wire sizing for more info: http://www.bcae1.com/wire.htm
Mar 14, 2011 | Jl Audio 1000/1 Car Audio Amplifier
With the gain in the middle was runing vibe12" sub in bandpass box it blew the sub in 4 min of using could u please tell me what sub I can use to play loud it has to be 2 x 12" thanks.
There are many sub woofers out there that would be suitable for your amplifier. Just stick to the quality brands such as Elemental Designs, JL Audio, Alpine(type X), MA Audio, RE Audio and there are many more. Make sure the minimum power handling for each sub woofer is 600 WATT RMS. Another thing. The gain control on the amplifier is not a volume. It is there to match the output voltage (V) of your head unit to the input voltage of the amplifier. For example, if your head unit RCA output is (1.2V, 2V, 4V or even 5V) then match that on the amplifiers gain to be the same. The higher the V number is on your head unit, the stronger the signal is that is being sent to the amplifier. For example, If your have a 4V head unit and the gain control on your amplifier is set to 1.2V the you are sending almost 4 times the amount of signal strength to your amplifier. This causes distortion and distortion causes speakers and sub woofers to blow. I hope you understand the concept. IMPORTANT: This is a powerful amplifier, a 4 Gauge or 2 Gauge power cable MUST be used. Less than 4 Gauge, will cause over heating of both the cables and the amplifier. YOU DON'T WANT THAT. If you still have doubts and need more assistance, let me know.
dreamsystems
Feb 13, 2011 | Alpine PDX-M12 Car Amp
I have a jl 1000/1 and a pioneer 600/4 and i have noise from the motor i cheked the ground replaced the 4 gauge still the same
the noise is from the alternater i believe. you just need to buy a noise filter and install it. i believe this problem is from power supply for your amp going straight to the battery. is that helpful?
Dec 15, 2010 | Jl Audio 1000/1 Car Audio Amplifier
I am wondering what amp i would need for 2 JL Audio W3v3 - 2ohms. I am looking for something around 200. SHould I go with the Mono block and how many watts?
well you can go a couple different directions. you can wire them parallel or in series. parallel will get you down to about 1.3 ohms at the amp and series will get you close to 4 ohms. you need an amplifier thats stable at either of those impedances. the lower the resistance (impedance) the more power your going to get to the subs. I manage an electronics store and specialize in mobile audio/video. we are a 'Signature JL Audio Dealer' so i like to say i know the product line very well. JL makes an amplifier that is stable from 1.5 to 4 ohms and will put out the same amount of power at any impedance in that range which is really nice. Its called their 'Slash Series' you are looking for a JL Audio 500/1 amplifier. Grab an 8 gauge amp kit (4 gauge would over do it) and wire 'em up. Enjoy!
Mar 17, 2010 | Jl Audio 10W3v2 Car Subwoofer
Jl audio 1000/1 low voltage -keeps shutting off at high volume
You should definitely upgrade the power wire to the sub amp to 4 gauge -absolutely your choking your amp its starving for current-poor thing is starving !!!!!!!
Apr 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Wire three 10" jl subs to jl e1200
what is the impedance of your woofers it will be a number with an Omega symbol. Looks like a horseshoe next to your woofer . Like this JL Audio 10W1v3 8ohm. Please, Please tell me you bought 8 ohm woofers JR?? Because if not, it ain't gunna happen.. If you did buy 8 ohm woofers than wire them in parrellel which means all the +'s together and all the -'s together giving you a final impedance of 2 ohms and your amp will think your a car audio GOD... But if not be ready to smell plastic burning where your amp used to be.... let me know i can walk you thru the wiring but let me know what you have. ok. mark
Mar 18, 2009 | Jl Audio E1200 Car Audio Amplifier
Jl 1000/1 amp not working
If I'm not mistaken, the blue light is the low voltage indicator. You need to confirm that the voltage ON THE POWER SUPPLY TERMINALS of the amp never drops below 11 volts. If it does, the amp will shut off. It's possible that you have a bad connection or even a defective fuse that's causing the problem.
JL recommends a 100 amp fuse for the amp. If you use a fuse that's too large and something goes wrong, the amp may be very severely damaged (possibly beyond repair).
May 08, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Jl audio E6450 cutting out
hi, have you figured out whats wrong with ur amp ...i have the same amp ....and as soon as i finished the connections ...and connect the remote on wire,,, the amp goes on ...making a ticking sound with the green light blinking and the red light staying solid on ...whats the problem please help ....how can i fix this ......my amp is a jl e6450 ....im using a panasonic cd player with a built in amp ....and thats the cd player im trying to connect to the jl amp ...please HELP
Nov 01, 2007 | Jl Audio E6450 Car Audio Amplifier
Blue low voltage light
You most likely need a bigger alt. The low voltage light comes on simply because your alt. isn't producing enough to feed the demand.
Oct 16, 2007 | Jl Audio 1000/1 Car Audio Amplifier
Blowing fuses
You will need to have the amp bench tested at full load to see if there is a pending problem. It will need to see with speaker loading resistors, how much current the amp is drawing and at different frequencies. if the amp checks out with the proper current, at the rated output, have the speaker checked out. Good Luck
Jun 15, 2007 | Jl Audio 500/1 Car Audio Amplifier
Car Audio & Video Logo
67 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
