Question about Astoria Argenta Coffee Makers & Espresso Machines
Asotoria model aep12n - do I have to use a water softener?
Does the Astoria need to be hooked up to a water softener or can I use it without one?
    President:
  • 1,618 Answers
You can use it without one but it would be best to install a water softener system like an everpure ql3 head with a 7S0 softener. That might run you about $200 installed.
Posted on Apr 05, 2014
3 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: maximum water supply pressure
About 3 bars, not more that 5 or you will need to install a pressure regulator on the line.
Posted on Apr 12, 2010
EsWorld
  • 1618 Answers
SOURCE: I have a Astoria espresso machine Model AEP12N we have 208 Volts
The machine will use 200 -240 volts, if your voltage is lower than 200 then you will need a booster.
Posted on Jul 16, 2010
We have an astoria model SAE.2 for some reasen the machine has gone very quiet and appears to be strugling when re charging after each use
It sounds like the water pump is not doing its thing or the machine cannot get water, either blocked filter or water line.
Jan 03, 2011 | Astoria Divina SAE-1 Espresso Machine
Jul 14, 2010 | Astoria Argenta AEP-2 Coffee Maker,...
I have bought a used Astoria sae Espresso Machine and I need to know how to clean it - can you help?
You'll want to back flush the machine with espresso machine cleaning powder:
http://www.kaldi.com/cafe_supplies.htm and regenerate the water softener regularly.
May 21, 2010 | Astoria Argenta SAE-2 Espresso Machine
Maximum water supply pressure
Apr 10, 2010 | Astoria Argenta SAE-2 Espresso Machine
Salt water running out of machine
Check the silver bullet softener canister, it might have been installed backwards or someone was charging the crystals and did not move the knobs in the correct way. Machine will have to be flushed a few times and softener needs to be charged again.
Feb 11, 2010 | Astoria Argenta AEP-2 Coffee Maker,...
We need to increase the hot water temperature, how
Depending on the model, if using a manual knob for the tea valve(same kind of setup as the steam) then you will have to turn up the p.stat. If it has an electronic button then remove the front top panel and look on the side of the solenoid you will notice a knob attached to another solenoid called an economiser valve, there should be a plus and minus sign on the knob. Reducing the amount of cold water being mixed with the hot water will increase the temperature.
Jan 25, 2010 | Astoria Divina SAE-1 Espresso Machine
Astoria double overfills with water
The machine froze at some point, one of the exchangers are busted, you will havew to replace the exchangers or the boiler depending on the model.
May 11, 2009 | Krups Small Appliances Espresso Machine
Need wire diagram for older 3 lever Astoria. Someone hooked up a 3 wire cord for 120v. and the way they hooked up the elements makes no sense or heat. I can't find a model # anywhere butit is older
No the machine is made for 220v. If you check the element closely there will be some markings on it with the voltage.
The other two terminals need to be connected to each other(check diagram below)
The two wires one at the top and the other at the bottom are each connected to one leg of the element, there should be a some kind of bridge connected to the other bolts on element.
Hopefully you can make out this drawing:
T-1 T-2
I
U-1 U-2
Use a 10 gauge copper wire or a bridge terminal and connect T2 and U2.
T is one leg of power for the element and U is the other Leg. If you open the cover on the pressure stat (rectangular box with 4 wires going to it), you will see the wires, two from switch and two to element.
Make sure there is water in the boiler and test machine (connect to power).
Apr 22, 2009 | Astoria Argenta AEP-4 Coffee Maker,...
Fabric softener not draining during rinse cycle
What type of water hoses are hooked up to it? If you have the flood safe hoses with the check valve in them then there isn't enough water pressure to distribute the softener.
Apr 25, 2008 | Samsung WF337AA Front Load Washer
Coffee Makers & Espresso Machines Logo
47 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
Charles T Nevin
Charles T Nevin
J.D. Browning
J.D. Browning
obsteiner
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
