Question about Refrigerators
Fridge freezer not working properly, can hear it running lights on and fan in freezer is running constantly but its not getting cold
It's a second hand fridge freezer i've just been given, it was working before my friend brought it here, he had it laying down in his truck would that have made it stop working?
  • 400 Answers
Possibly. I would always set one that has been on it's side upright for about 24 hours before plugging it in. You might try that. Hopefully it is not too late. I hope this helps.
Posted on Mar 31, 2014
  • 1462 Answers
SOURCE: fridge not working
almost certainly a compressor fault. not worth repair
Posted on Sep 02, 2008
SOURCE: Kenmore Trio 596.75509400
My problem is identical to jcalhoun on Sep 21, 2008..I have a Kenmore Trio 596.75502400. Freezer is ok..Lights are on. Any help would be appreciated.
Posted on Sep 21, 2008
  • 24 Answers
SOURCE: freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Posted on Oct 08, 2008
deby69
  • 16 Answers
SOURCE: whirlpool side by side freezer not working fridge is fine
Pull out the fridge and unplug. Remove the back cover. Clean the condenser coils and fan. If they're difficult to get to, use compressed air to blow out. (you can get a can from walmart). That should fix the problem. If that doesn't work, then write back.
Doug
Posted on Jan 05, 2009
  • 28 Answers
SOURCE: Hi i have a hotpoint mistral plus fridge freezer,
hi is this the frost free version ??? if it is which i think it is it could be a fault with temp module{frost free have electronic modules to control the system rather than a old fashioned bog standard thermostat inside the fridge} the fans should be controlled by the module in case of frost free models it could be the module which is playing up
Posted on Jul 23, 2009
My kenmore 253 upright freezer/fridge is not cooling the fridge part correctly. It's cool but not cool enough to keep the food fresh. The freezer works well sometimes. And sometimes it seems that it's not...
Try this test. Set a window fan behind the fridge to constantly blow air across the lower coils at the floor. If the fridge works well after a while of this, then the lower fan on the fridge needs replaced. Sometimes though, after a while, the fan will finally start working again because the cycle has finally corrected itself with the test. Leave the window fan run on low for a few days before removing it. The hum you hear is the compressor moving the coolant and is supposed to do the hum sound. That's good. Now once the fridge is working, and you still have a good freezer section and not cool enough below in the fridge for you, there is a knob that sets the cool lower by opening flaps under the freezer to let more cold down to the fridge area. Set this knob to colder and the flaps will open more.
Nov 11, 2014 | Refrigerators
GB2SHDXPS01 FAN RUNS CONSTANT, FREEZER ICES UP
Buy a used fridge on ebay, they are very cheap.
Dec 21, 2013 | Whirlpool GB2SHDXP Bottom Freezer...
Kenmore side by side fridge. Green temp light flashing for fridge side, freezer side working fine. Fridge side not cooling.
possibly frosted up at the air door between the fridge and freezer, or the fan in the freezer is not pushing cold air into the fridge side, if you can not hear a fan running in the freezer when the fridge is running (compressor on) then change out the fan
Jul 18, 2011 | Kenmore Side by Side Refrigerator
I have a kitchenaid superba ksrs25ilwh side by side fridge. The freezer is working fine but the fridge wont get cold enough even at the lowest temp
check the damper vent door for proper opening and closing as if this door is frozen shut or broken and jammed it cant open to let cold air in from freezer it will be behind a plastic grille between the freezer and fridge compartments and you should hear a fan in there running to move cold air too
Jul 02, 2011 | Refrigerators
Hi, I have a Bosch intelligent frost free 44 which I bought second hand a few days ago. Manufacture date appears to be 2006 and was told it works fine but I am not sure. When I first turn fridge on the...
I think it's the freezer fan that stopped working,open the freezer and see if it goes you should hear it running and even see.This fan allows the cold air into the fridge compartment,without it it takes ages for the fridge to get cold.I've got the same problem if you find the motor online let me know on alvalen31@hotmail.com
Nov 03, 2010 | Bosch Refrigerators
My Whirlpool side by side fridge and freezer not working
Most likely, if you can hear the compressor running, the fan inside the freezer is not working. When the compressor is running, open the freezer and listen for the fan running. If you don't hear it, locate it and, with a voltmeter, test for voltage across the terminals. If you have voltage present, replace the fan. You can buy replacement fans at a local appliance parts store, internet parts suppliers, even ebay.
Jan 29, 2010 | GE Refrigerators
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
