Sansui stb-sd01 user manual
Need instructions in connecting to a tv
  • 3,320 Answers
Not an mp3 player question
Posted on Apr 01, 2014
Connecting rca tv model#F20352SF to a tv converter box
  • Connect ANTENNA OUT of STB to antenna terminal on rear of TV OR, for better picture, connect 3-wire cable to color coded L AUDIO, R AUDIO, and video outputs on rear of STB and connect other ends to L AUDIO, R AUDIO, and video inputs on rear of TV.
  • If STB connected to antenna terminal of TV, set CH 3/4 switch on rear to whichever channel is NOT used in your area.
  • Connect antenna to ANTENNA IN of STB
  • Connect STB to power and use STB remote to turn on
  • Turn on TV
  • If STB connected to antenna terminal of TV, use TV remote to select channel 3 (or 4).
  • Use STB remote to select SETUP and perform channel search.
  • Use STB remote to change channels.
Oct 23, 2016 | RCA Televison & Video
I need to find a user guide for the sansui gs35, the instructions do not come with the box and I have no idea how to use all of the features. can anyone help with an online guide I can print off?
datasheet,schematic,electronic components, service manual,repairs,tv ... ( welcome to eserviceinfo.com at 04 Jan 11:35 pm GMT) ... Kyocera FS-1900 Service Manual.part1.rar, 24-05-2005, FS-1900 Laser Printer Service Manual, Printers, 2041 kB, 3734 ... Sansui G-8000.part2.rar, 22-08-2006, Service manual for Sansui ... www.eserviceinfo.com/index.php?what=search2&searchstring=sansui rz 1900 www.eserviceinfo.com/index.php?what=search2&searchstring=sansui+rz+1900
checked this site and they definitely have a manual for yr printer. Hope this will help
Feb 06, 2012 | Office Equipment & Supplies
Manual for tivax stb-t8 converter box
http://michley.net/STB-T8.User.Manual.pdf
Nov 13, 2011 | Fulltone TIVAX STBT8
No instructions to connect base to LCD in the manual
www.retrevo.com/support/Sansui-HDLCD4212-TVs-manual/.../2
Mar 21, 2010 | Sansui HDLCD-4212 LCD TV
How to access the usb port on a samsung le32b450
according to the user manual,the USB port is intended only for software upgrade, here are some of the supported inputs for your TV : VCR / DVD / Cable STB / Satellite STB / PVR STB / AV Receiver / Game / Camcorder / PC / DVI PC / DVI / TV / IPTV /
Blu- ray / HD DVD / DMA
Aug 29, 2009 | Samsung Televison & Video
How do you connect a Sansui STB-HD01 (set top box) to an LCD tv?
Hi trishallan! I will be more than glad to assist you in this concern.. On the back of your Sansui STB-HD01 (Set top box) there is an input name - ANT In- Attached an external antenna to this terminal. If your LCD TV is an HDTV you can use the HD-YPbPr (you will see there Red, Green, Blue) on the back of the Sansui-STB-HD01, The cable that your going to use is the component cable - the color is Red, Green, Blue) - connect the 1st end to the back of the sansui-set top box and the other end is going to your LCD-TV. If your LCD TV is not and HDTV you cand use the other terminal which is on the right side of the HD-YPbPr, the SD-YPbPr, you can use the same cable - the Red, Green, Blue, .. then there is s display switch-Set this switch in conjunction with MODE switch according to your TV display capability.and there is a mode select- Set this switch in conjunction with DISPLAY switch according to your TV display capability, then u need to tune in the tv to compionent channel, use the LCDtv remote to cycle the input of your tv.
if you have any query please feel free to get in touch..
Aug 28, 2009 | Televison & Video
I own a Go-Video DVD-VCR Player, Model DV3140. I recently switched to Verizon service and find that I can no longer olay my DVDs/VCRs with the Fios System. Can you assist me in how to program my player...
Hi
You can reprogram it by following these instructions--
Power turns on or off both your STB and TV when you are in STB mode. (If you have a DVR STB, the DVR will continue to record scheduled programs when off.) However, you can reprogram how the Power Key works. If you want the Power Key to control multiple devices at once --
1. Press and hold the STB key.
2. While holding down the STB key, press OK.
3. Release both keys. The Device Keys will blink twice.
4. Press 9 - 7 - 7. The STB key will blink twice.
5. One after the other, press each Device Key you want the Power Key to control, in the order you want them to turn on or off. Each selected device Key will blink twice after it is pressed.
6. Press OK when done. The STB key will blink three times to indicate success in programming.
For example, to program the Power Key to turn on or off your TV, AUX and
STB, in that order with one press of the Power Key, press [STB+OK], [9-7-7],
[TV], [AUX], [STB], [OK].
These are the codes for GO Video DVD Player--
Go Video 0771, 0768, 0810, 0896, 1071, 1102, 1185, 1757
You can view/download the manual for the fios from this link--
Verizon fios remote programming
You can visit this link for more information--
Verizon FiOS Troubleshooting
If you want to doanload the user manual for your verizon set top box you can get it from here
Please do accept this solution and revert for further assistance.
Thanks
Rylee
May 30, 2009 | Televison & Video
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
 Grubhead
Grubhead
