Question about Facebook Social Network
Kayla Reyes Denied Job At Macy's Because She Served In Afghanistan
Kayla Reyes denied a job at Macy's because she served in Afgahnistan
Access Denied You don't have permission to access "http://www.directv.com/" on this server. Reference #18.f00af748.1389999059.336e14a
For whatever reason they blocked you. If you change your devices IP address. That new IP will not be denied.
Apr 21, 2014 | Directv (DWO2-10024)
What is the appropriate serving temperature of wines?
There are four different types of wine with different temperatures. Deep red wines should be served in 15-19 Celsius. Light red wine should be served in 13 Celsius. Sparkling wines and Champaign should be served in 6-8 Celsius. Dry white wines like rose and blush should be served in 8-14 Celsius.
Aug 13, 2012 | Furniture
How do I cancel print job. I get message access
OPen the printer program, select the jobs and select cancel.
go to the control panel to find the printer program
Dec 20, 2009 | HP Photosmart C7280 Laser Printer
Im trying to cancel a print job and all i get is Operation could not be completed (error 0x00000005)access is denied what do i do
open the print que and delete the job there.
controlpanel, printers, open yours, delete the job.
it may be that you are required to have administrative priviledges to do this. If this is your computer, go to the control panel as an administrator user and change your user settings.
Oct 26, 2009 | HP Officejet J5780 All-In-One InkJet...
Printer will not print
TRY SHUTTTING THE PROGRAM DOWN AND RESTARTING THE MACHINE AND ENTER THE PROGRAM THROUGH THE DEVICE MANAGE LOCATED IN THE CONTROPL PANEL.
THEN TRY REMOVING THE JOB QUEUES FROM THE PRINT QUE.
IF THAT DONT WORK START PRINTING THE EACH DOCUMENT AND THAN CANCEL EACH JOB.
Apr 08, 2009 | HP Officejet 4315v All-In-One InkJet...
Just got a sandisk cruzer 8 GB (with U3). I want to copy files from hard drive to flash drive. Error says :cannot create or replace 40: access is denied". But i can copy the same files from hard drive to...
Hi there
Have a look at the side of the flash drive for the copy protect switch and turn it off. Job done!!!!!!
Good luck and thanks for using Fixya
Jan 13, 2009 | Cameras
Trouble prining with my MFC 5480cn. Using
Hello you can delete the print job manually.
you need to have administrative right on the computer to do this.
go to run> input "cmd"
write
net stop spooler
go to
%SystemRoot%\system32\spool\printers or(System32\SpoolPrinters )
delete all files that ends with->
.SPL
and
.SHD
then
write in cmd "net start spooler"
check your printer job now and it should be gone.
good luck
Sep 16, 2008 | Brother MFC-5840CN All-In-One InkJet...
Facebook Social Network Logo
Top Facebook Computers & Internet Experts
David Payne
David Payne
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
