Question about Samsung Security Cctv Sod-14c Soc-120 Color Camera
I need to conenct yamaha rx v420 to Samsung tv
I need to conect yamaha rx v420 to Samsung tv 47"
    Top Expert:
  • Samsung Master
  • 6,702 Answers
Unless your Samsung has optical digital entries, I'm afraid you can't use them together in high quality.
Today, everything is connected through HDMI. Your Yamaha receiver has only analog connections. As well in as out. Although on the left side, when you look from behind, there are some digital connections.
I found the manual still online, so if you don't have one, click the link below.
http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V420.pdf
Posted on May 14, 2014
When playing the DVD when you turn up the volume the amplifier turns off.
Amplifier and an over load issue and is shutting down to protect the circuits. Needs to be checked out by tech.
Mar 08, 2015 | Yamaha RX-V420 Receiver
No sound on left front speaker
you need to set up the individual volume levels for each speaker.
do a sound test tone which will check for a signal from each speaker.
if you hear the speakers at different volumes you know you need to adjust the ones that are too weak. hope this helps
Mar 27, 2014 | Yamaha RX-V420 Receiver
Need remote control code for Samsung BD-P1600 on a yamaha RX-V461 remote
http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V461_U_en.pdf
this web page has complete manuel for your yamaha RX-V461 home theater system they list code for samsung tv as 30739
press dtv button
press code set button
enter five diget code any questions refer to online manuel good luck ron
Dec 12, 2009 | Televison & Video
No power
Crystal for system micro should be in front panel display and near the lcd display .while your there check solder connections in display board
Aug 05, 2009 | Yamaha RX-V420 Receiver
How much for a digital board for my yamaha a/v rxv 420 ?.an expert check my a/v and tell me the problem is the digital board.
What concerns me is why do you need a digital board, which cost around $150 or so. I just repaired a rx-v620 that needed the volume and mode crols replaced. These controls affected mant aspects of the digital circuits opperation. Your 420 could have a similar fate. What is it doing?
Jul 17, 2009 | Yamaha RX-V420 Receiver
Xbox 360 dashboard will not show using Yamaha RX-V663
I had this issue once before, recheck all the conenctions on the tv, and make sure that the HDMI plug in for the TV * if its the older model * make sure it is placed to HDMI not TV.
Please let me know how it goes,
Thanks
Justin
Please rate me
Jan 07, 2009 | Yamaha RX-V663 Receiver
Remot control dont working
dropping to a hard floor is always the reason when remote dont work.change the transmiter led or check some crack inside.clean the board and the rubber button with alcohol.
Oct 21, 2008 | Yamaha RX-V420 Receiver
Yamaha RX-V420 No power
If the standby voltage exists, the next step is to see whether or not the clock is working. Find the main micro chip. There should be a 3 legged crystal close by. You should see this oscillate (use a scope). No oscillation = no micro control = no turn on. It is possible that the micro is bad or the crysal is bad. Also, check to be sure that the output transistors are not shorted. It is also possible that these are preventing the system from turning on.
Dan
May 12, 2008 | Yamaha RX-V420 Receiver
TURNS ON BUT NO SOUND
if the amplifier integrated circuit is busted that will not sound even the power will display the front panel.
Sep 13, 2007 | Yamaha RX-V420 Receiver
Yamaha RX-V420 Will Not Power up
Hi Daniel if your set does not have a fan that trips on when the volume gets louder surely the audio output will damage. every working component generates heat and when the heat sore up to an uncontrolable level it cause damage.have a tech look on your set to repair it.good luck.
Apr 26, 2007 | Yamaha RX-V420 Receiver
Samsung Security Cctv Sod-14c Soc-120 Color Camera Logo
59 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
