Question about Nintendo 64 Console
Reciving no signal
Need diagram of how to connect to TV
    Master:
  • 508 Answers
Connect yellow wire to tv input and red and white to tv audio.
Posted on Apr 01, 2014
No remotes work
WHAT WENT WRONG WITH THE ORRIGINSL REMOTE. NEED NORE INFO. If the remotes are not working , is the TV reciving the signal from the remote rather than the remote sending the signal .If the TV is reciving it the light should flash on TV every time it receives a message from remote. if this is not happening it sounds like the decoder in the TV needs replacing / LED might just need cleaning to open access to the sight of view. Jeff
Mar 21, 2014 | Vizio 42 in. LCD TV
Monitor showing no signal and button not working
The monitor needs a signal ( source), i.e., DVD, TV, to show a picture. If your monitor shows no signal then either the source is not connected or not functioning. Check the connections from the monitor to the source. Also, check that the source is functioning properly and is receiving power.
May 24, 2011 | Sony XVM-H65 6.5 in. Car Monitor
HOW TO HOOK UP TWO SATELLITE RECIVERS THAT I HAVE LIKE MODEL 4000 DISHJNETWORK RECIVER I FOUND IN MY CLOSET AND MY NEW DISH NETWORK RENTED DVR 625 RECIVER HOW TOO HOOK BOTH OF THEM UP TO THE 3 CABLES AND...
Ok since you have A 625 it uses different technology than the 4000 in a sense but I will assume that whomever connected the 625 use a Dish Pro Plus LNB. You can verify this by going out to the dish and looking at the LNB which is the eyes if you will on the dish. The cover facing you will read DP Plus, or Dish Pro, Dish Network, or you may have nothing at all on the housing. You will want it to say DP Plus for the easiest install.
On this LNB there are three ports. You will only need the two on the left if looking at it so you can not read the housing. One of the ports will be connected to a line running to the 625 and the other to the 4000. The line going to the 4000 should not contain any breaks in it after the ground block if one was used. Once inside the house connect the line from the lnb for the 4000 to the back of the receiver. Conect the receiver to the TV and run a check switch. This receiver will go into a test of 1 of 38 if all connections are good. A 1 of 50 indicates a loss of signal somewher on that side of the install.
The 625 can utilize di plexers but that type of install is to detailed to go into straight away so we will connect it using a straight feed to TV2. Run the cable from the LNB into th room with the 625. Inside connect that line to a siver device called a seperator that came with the receiver and connect the two leads from it to the sat in ports on the back of the receiver. Connect a line to the Home distribution port on the back of the receiver and run it to the room with the second tv you want to have DVR in such as a mater bedroom etc.Connect the cable from the tv out port on the receiver to the tv. Power all devices on and run a check switch. This test should read 1 of 3 if all connections are good. A bad connection will read 1 of 38 on the receiver. A total absence of signal will stay at 1 of 1 for a longt ime brfore going to 1 of 38.
You will need to call dish and activate the 4000 rx since it has not been on the account for some time and will need a software update that they will send to it via satellite.
Other obstacles could arise and if they do let me know. Thanks for using Fix Ya.
Feb 28, 2010 | DISH Network DVR-625 DTV Receiver /...
Where do the yellow,red, and white cords connect to on my Proscan 37'' DVD/HDTV
it depends on what signal your sending to the tv.
red and white are usually sound and yellow is picture or AV.
you may need to select the input on your TV to recive a picture. Does this help?
May 07, 2009 | Televison & Video
Connecting to surround sound system
Hi to connect your ps3 to your tv all you would need is a hdmi to hdmi connector which would mean the sound would come straight out of your tv. The sound comes directly out of the hdmi cable. If you want to connect the ps3 to an external reciver you might want to get an AV reciver with HDMI inputs. This would connect to your tv and you can switch channels to different sources connected into the receiver, also they come with very good seperate speakers so you wouldnt have to use you telly speakers and you can connect your directv box into it aswell.
Alternatively you can connect the audio phono outputs from your AV multiout connector on your ps3 (the cable should be provided) to a seperate sound system with phono AUX inputs, these are found on most soundsystems but check with whoever your buying it from. But this means that you cant use the HDMI output of your PS3 for video just the AV multiout video signal (which is a bit rubbish, so I suggest the latter solution.
Hope this solves your problem
Rob
Nov 26, 2008 | Audio Players & Recorders
Tv
no you will need the converter which will allow analog tuners to recieve digital signals
Mar 19, 2008 | Televison & Video
VSX-D711
Yes.
There's an integrated circuit that steers all the input signals thru.
That has crapped out.
Jan 28, 2008 | Pioneer VSX-D711 Receiver
Connection
Ok If you are connecting the VCR through the cable or antenna fitting on the TV set, you will have to see what channel the TV set has to be on. Look at the back of the VCR at the RF output and there should be a small channel switch. You also must tune the VCR in to recive cable channels unless you are using a cable decoder box. Good Luck
Mar 26, 2007 | Samsung SV5000W VHS VCR
Picture quality
The output from your sat reciver is not HD unless it says right on it that it is . The signal your getting now is a digital signal from the dish to the reciver, but from the reciver to the TV set, it is analog. To answer short and sweet, Yes, you will need an HD reciver for the satallite to get the most out of your HD TV set. Good Luck Ps and please dont forget to rate this.
Oct 16, 2006 | Hitachi 57S715 57" Rear Projection HDTV
Nintendo 64 Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
