Question about Sewing Machines
Have a singer model 401A but no manual and need to do a zig zag stitch quickly
The machine works beautifully however i only know how to straight stitch and need to do a zig zag.. what are the settings on the two knobs at the top for a zig zag. Thank you
  • Sewing Machines Master
  • 7,365 Answers
Try this link for a free manual and see if it's the right one
http://www.singerco.com/uploads/download/cb49471fa8cb14674b2e1cbda398dc9bfb86924c.pdf
Posted on Apr 29, 2014
bargainbox
  • 1388 Answers
SOURCE: singer sewing machine will not zig zag
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Denatured alcohol is fine, surgical spirit too, different countries have different names or products, essentially alcohol with few impurities that will evaporate quickly with little residue.
Hope this does work for you, tho' as I said, it may take a little time to penetrate depending on severity........the same applies to the reverse mechanism of many machines when they seize.
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
bilabon
  • 46 Answers
SOURCE: zig zag stitches are not holding
When ever a machine is jamming up the bobbin thread, it is a result of your top tension. It is either set to low (under 4), or the thread has come out of the take-up lever. Check your threading, fromt he spool pin, down to 2 and up to 3. Three is the take up lever. From the take-up lever down to 4. Set the thread behind the thread guide and thread the needle form front to back. Low quailtu thread 9dual duty or all purpose) can also create this problem.
thanks,
Bonnie
Posted on Sep 02, 2008
  • 46 Answers
SOURCE: only does zig zag stitches, no straight stitches,
make sure the pattern selector is set for straight stitch first. If it is set correct then the machine may be "stuck" is zig zag mode. May need to be de greased and then re lubricated.
Posted on Jul 27, 2009
  • 980 Answers
SOURCE: Singer Fashion Mate 257 won't make a zig-zag
You may need to retime the machine, email me for attachment of instructions drivewithken@blueyonder.co.uk
Posted on Nov 14, 2009
  • 1788 Answers
SOURCE: I bought a 1986 singer
If you do not have a manual, you can buy one from singerco.com and buy one for $15., great investment. A manual is invaluable for answering your questions, also Singer has fantastic customer service at 1-800-4singer
Posted on Sep 13, 2010
Please how do I work a zig zag pattern on my manual operated singer sewing machine
Hello, Annelien -
Unless your manually operated sewing machine has switches to realign your sewing machine needle to make zig zag stitching, as is demonstrated in this YouTube video (starting at around 6:30 minutes in the video):
https://www.fearlessmakers.com/manual-sewing-machine-works/
you cannot. Note: The machine in the video is a Necchi brand sewing machine.
Without knowing the model number of your manually operated Singer sewing machine, I cannot try to find operating instructions for it to determine if your machine has zig zag stitching potential.
Best wishes.
Jan 24, 2018 | Singer Sewing Machines
On a singer machine from the 70's, how do you change it from sewing zig zag to straight line?
Most likely you change the stitch-width selector to straight, otherwise it will stitch in varying degrees of zig-zag.
Jul 07, 2017 | Singer Sewing Machines
HOW DO YOU CHANGE THE STITCHING FROM STRAIGHT TO ZIGZAG
Check that your sewing machine is even capable of zig-zag. Some machines are straight-stitch only.
Consult your owner's manual.
If your machine can do zig-zag, somewhere there is a dial or setting called "stitch width" that will determine how wide the zig-zag will be.
May 21, 2016 | Sewing Machines
White sewing machine won't stop the zig zag stitch
my suggestion is take the machine in to a sewing machine shop
to be check to see if something inside is broken or come loose
knowing the machine is in good working order gives peace of mind
instead of wanting to through it out the window
and get a instruction manual
Go to the singer website for a free pdf manual
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example w265) & click search
Jul 24, 2012 | Sewing Machines
I just bought a Singer Golden Touch & Sew at an estate sale. The straight stitch works great but it will not do a true zig-zag. It starts at wide width and the zig-zag narrows steadily for about one...
Go to www.singerco.com and under customer support, you can download a free copy of your manual. Save it to your computer, then enlarge the diagrams, it is so much easier to see the details. The machine is a little more complicated than we are used to. It will also teach you how to lubricate and clean this little beauty. Good luck, have fun. Happy New Year.
Jan 01, 2011 | Singer 5050 Mechanical Sewing Machine
ZIG-ZAG NOT WORKING
Make sure your presser foot is tight down. If the needle is going from side to side, it's doing it's job. If the stitches are coming out straight, the material is probably slipping back and forth to center area. The presser will eliminate this.
Aug 28, 2009 | Singer 2638 Mechanical Sewing Machine
Singer Athena 2000 won't zig zag
Did you switch the metal plate to one of the ones that won't allow left/right movement by any chance?
If the wrong plate it in -The machine somehow figures out that the plate won't allow the needle to move in the left/right directions and only does a straight stitch or funky other stitches.
Jun 08, 2009 | Singer Sewing Machines
Sewing Machines Logo
101 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
