Question about Precor Efx 5.21i
How do i change the bely on precor 5.21i
Need to change the belt
Hi...
Do you know the serial number for the elliptical? Some of them have two drive belts and some have one. Once I have this I can give you more information. Please feel free to call us as well 877-805-1030 for all your fitness equipment needs. Treadmill Repair Fitness Equipment Repair Parts Services Fitness...
Posted on May 16, 2014
Why is the Precor AMT 100i Adaptive Motion Trainer Elliptical primary belt making noise and should I adjust it?
SOmetimes belts make noise when they are worn out and need to be replaced - belts like that are considered 'wear' items, like tires on a car - they have a very limited lifespan compared to the other parts.
Jun 18, 2014 | Precor AMT 100i Adaptive Motion Trainer...
Where are the fuses on Precor 9.27
Fuse is a dead end in this case. Is there belt movement with the LS error, where the belt moves for a few seconds then quits? If so, there may be a problem with the upper - contact Precor and have them look up bulletins on that model/SN. If no belt movement, then there is a problem with either motor or MCB, probably MCB.
Mar 25, 2014 | Precor 9.27 Treadmill
CHARGE BATTERY ON PRECORE EFX546I
The machine recharges the battery while in use. If your battery is dead, chances are you have a battery with some dead cells. You will need to locate your battery, usually mounted under the lower electronic board. You can try a 12 volt charger, or purchase a replacement battery. Precor Equipment Repair Parts Treadmill Belts Ramp Sleeves SPORTSMITH...
Oct 14, 2012 | Precor EFX 546i Elliptical Version 4
Precor efx 5.33 belt replacement
This link will take you to the replacement belt. If you use your serial number, you will be able to access a service manual on our Website to assist with the belt change. Drive Belt Poly EFX PPP000000010217131 SPORTSMITH net
Jul 01, 2012 | Precor EFX 546i Elliptical Version 4
Precor 9.33i belt slows down when i step on. Runs fine without me on it
It is the aluminum rollers they used in manufacturing. Precor will replace the rollers with steel and the belt for labor only (it was about $80 for me in Idaho) It has worked like a champ since.
Feb 28, 2012 | Precor Exercise & Fitness
Loose belt
tighten the back bolts to check tension lift the sides of the w/belt in the middle . sides should be 2-3 inches high
Feb 28, 2011 | Precor 9.21 Treadmill
Where can I buy a replacement walking belt for a Precor 9.21 treadmill?
FitnessRepairParts.com has a walking belt for Precor 9.21 treadmill (it says it is used on four different versions of the 9.21... make sure your specific model number is listed)
Jan 12, 2011 | Precor 9.21 Treadmill
Belt replacement for precor efx 645 verison 1
You may have to purchase the belt from a Precor dealer in you area, if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you. Most of these part have not hit the secondary market yet and Precor pretty much call the shots.
Feb 26, 2010 | Precor EFX 546i Elliptical Version 4
CHANGE THE BELT
Remove the two screws on the top of the hood, usually hidden amongst the four little holes on either side of the top of the hood. This should allow you to lift the hood away and access the belt and brushroll.
-R
Oct 01, 2008 | Eureka Mega Boss 4460DT Vacuum
Precor Efx 5.21i Logo
87 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
