Question about Cuisinart CJK-17BC Cordless Electric Kettle
KETTLE SHUTS OFF BEFORE BOILING
If I turn it back on the switch just shuts off again
Kettle does not automatically shut off even when water is at above minimum level and boiling
I think that standards require an auto-shutoff on electric pots to keep the component from softening down. You could override the shutoff by either taping over the switch or utilizing an elastic band. You can check deep details on electric kettle review sites.
May 15, 2010 | Chef's Choice 677 Cordless Electric Kettle
Shuts off
Does the unit shut off only before the water boils, or does it shut off and on periodically? I just fixed my friend's WK200 Braun kettle. His would shut off and on, eventually coming to a boil. During normal operation, when you press the switch, it is connected to a rod which at its other end (ie the bottom of the kettle) is able to close the circuit allowing the current to pass through the heating element. In my friend's case, the contact had become weak - I just had to slightly bend the metal pole a little bit to provide a better contact when the switch was depressed. To repair the unit, I only needed a couple of torx screwdrivers and a voltmeter to measure continuity. (note, if you bend the metal pole too much, then the circuit will always be closed even when the switch is OFF - make sure you test for an open circuit when the switch is OFF)
Jan 29, 2010 | Braun WK200 Cordless Electric Kettle
My kettle does not turn off when boiling
this is more likley to be the switch its just a bimetallic type,when it gets hot steem on it it flicks the switch to turn the kettle off try giving it a realy good clean up inside around the switch it may just be lime scale blocking the vent hole
however normaly when the switch playes up its a new kettle
Nov 03, 2009 | Russell Hobbs RHOK3123 Cordless Electric...
It starts to boil but shuts off before it boils and then may start uo again but then shuts off prior to getting hot.
this is a comon problem with them its the switch playing you up,it has a "bymettel spring in it" they just kind of were out and then they do what yours is doing popping off to early t-fal may be able to fix it for you (but at what price??????) could it be cheeper to get a new one
Oct 26, 2009 | Tefal T-FAL Avante Stainless Steel...
Kettle not switching off after boiling so carrys on boiling untill you turn it off
To state the obvious, the steam sensor has failed. Unless you are quite adventurous, and confident dealing with electrics, there's nothing for it but to get a new kettle (unless the kettle is still within warranty, in which case you should be entitled to a replacement of course).
Oct 11, 2009 | Morphy Richards 43025 Electric Kettle
Siemens porsche kettle on/off switch problem
Hi
Make sure that the lid is securely on. Otherwise its the replacement of the auto bi metalic strip which turns the kettle off
Feb 14, 2009 | Breville SK500-XL Stainless Steel Cordless...
Overheating kettle
this same thing happened to me
Sep 10, 2008 | Bravetti EK119H Electric Kettle
Switches off before full boil
Look under the kettle at the round circular connector in the bottom. Inside there is a small button that is depressed when the kettle is put on the base. If this is not pushed in far enough it will have problems.
The cause is that after some use the connector in the base plate collapses into the base by 1-2 mm This means the switch is not pushed in far enough.
My kettle had similar issues... I pulled the base plate apart (3 screws I think) and cut a round disk of plastic to lift the connector up by about 1-2mm and then reassembled the base.. No more issues
Nov 23, 2007 | Russell Hobbs RHOK3123 Cordless Electric...
Red light's on... but no hot water!
OK, inside the unit there are three items, the heating element, thermostat, and thermal fuse.What has happened is the element got too hot and the thermal fuse opened.There is no reset button.In some cases you may run across a defective heating element or thermostat but its not common.The fix would probably be replacement of the thermostat and thermal fuse.For this, you would have to contact a small appliance repair center in your area.
Nov 06, 2007 | Kitchen Appliances - Others
Kettle shuts off before boiling?
I had a similar failure. Switch it on and the lights flicker and go out before it boils. Took it apart (Tamper Proof TORX, available from Snap-On, Canadian Tire, probably most auto parts places that also sell tools). The On-Off switch has a mechanical lock out for the lid being open and also for when it is not mounted on the base. The kettle also has three bi-metallic temperature switches. One shuts off the kettle after it has boiled long enough. The other two sit up against the element assembly adjacent to each end of the heating element.They protect against boiling an empty kettle by sensing the higher element temperture when there is no water to conduct away the heat. In the case where the lights flicker and go out, but the switch stays 'On' these are the likely culprit.
In my kettle the contacts did not line up correctly. Instead of making good contact they were only partially overlapping like a couple of the olympic rings or a couple of rings from the Audi logo. This resulted in a localized increased resistance and high heat in one of the contact holders which eventually melted the surrounding plastic. At that point the wires going to the element behaved a bit like springs which forced the contact holder further out of alignment until it all became hot enough to trigger the thermal switch.
I fixed it by bending the contact holder, which is fused into the now hardened plastic, to the optimal position and hopefully it will not generate enough heat to remelt the plastic or trip the thermal switch.
I have boiled a couple of kettlefuls; so far so good!
What ticks me off about this is that I don't mind getting 'Made In China' ****; everything comes from China anyway. But don't charge me a ridiculous amount of money and try to pretend that I am getting a superiour product. If I had paid twenty dollars or less for it I would just chuck it and get the same one again because it looks nice, pours well, doesn't burn the hands, worked OK for couple of years, etc. Instead I walk away from this feeling really ripped off. I have a house full of Braun products(shaver, kettle multiple tooth brushes) but now I won't buy any more.
Oh and if you take your kettle apart and your house burns down it is not my fault. There, now I feel better.
Aug 29, 2007 | Braun WK600 Cordless Electric Kettle
Cuisinart CJK-17BC Cordless Electric Kettle Logo
99 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
