1. Press the Alarm Button. Screen will appear as shown above. 2. Press the Set Button. Use the Up and Down Arrow Buttons to set the hour you wish the alarm to start. Press the Set Button again to set the minutes. 3. Once the minutes are set, press the Set Button again. The AL, Bell, and Musical Note Icons will begin to flash. Use the Arrow Up and Arrow Down Buttons to choose the sound you want to hear when the alarm sounds. Use the Volume Button to set the sound volume. There are a total of 10 possible alarm sounds. Six sound soothers and 4 alarm sounds. 4. Press the Set Button to finalize the alarm. Press the Home button to return to the home screen.
1.set time: hold down "clock" button for five seconds, then use up and down arrows to change, and press "clock" button once to toggle between month/day/year/hour/minute. Try it a few times b/c sometimes it just goes to the alarm setting (i don't know why, i think it's a glitch).
2.set alarm: hold down "alarm" button for 5 seconds, use up and down arrows to change, press "alarm" button once to toggle between hour/minute. press "clock" button to return to clock
3.turn on/off alarm: press "alarm" button once, press up to turn alarm on and press up again to turn alarm off. press "clock" button to return to clock
4.to project the images: push the buttons that look like video cameras. to focus the image, rotate the cylinder around the lens that projects the image. on the daisy clock, there's a button on top that you can use to flip the projected image of the time upside down. use the dial next to the lens-cylinders to select a different image (you may need to point the cylinders in a different direction to reach the dial)
1) set time: hold down "time set" button for five seconds, then use up and down arrows to change, and press "time set" button once to toggle between month/day/year/hour/minute. If it goes to the alarm setting instead of time setting, try again. 2) set alarm: hold down "alarm set" button for 5 seconds, use up and down arrows to change, press "alarm set" button once to toggle between hour/minute. press "time set" button to return to clock 3) turn on/off alarm: press "alarm set" button once, press "up" to turn alarm on and press "up" again to turn alarm off. press "time set" button to return to clock 4) to project the images: push the buttons that read "time" or "image". to focus the image, rotate the cylinder around the lens that projects the image. use the dial near the lens-cylinders to select a different image 5) military time: press the "up" button when the time is displayed (not when you're setting the time) Good Luck!
You have to press the alarm setup, then press the up button. This turns the alarm off completely. If you want the alarm to go off again tomorrow you will have to set it again.
I can't upload a manual but I can give you instructions: 1) set time: hold down "time set" button for five seconds, then use up and down arrows to change, and press "time set" button once to toggle between m/d/y/hour/minute. If it goes to the alarm setting instead of time setting, try again. 2) set alarm: hold down "alarm set" button for 5 seconds, use up and down arrows to change, press "alarm set" button once to toggle between hour/minute. press "time set" button to return to clock
4) to project the images: push the buttons that read "time" or "image". to focus the image, rotate the cylinder around the lens that projects the image. use the dial under the lens-cylinders to select a different image
5) military time: press the "up" button when the time is displayed (not when you're setting the time) to change from 12 to 24 hr or vise-versa
