Basic procedure What does it mean
    Master:
  • 678 Answers
Posted on Mar 31, 2014
Replacing the seal by the pulley
If you mean the seal where the CV shaft enters the differential, remove CV shaft, carefully pry out old seal, clean up and install new one being careful to get get it in straight, and lube the seal inner lip, then reinstall CV.
If some other seal, same basic procedure.
Oct 07, 2015 | 2006 Ford Bantam 1.3i
Sensor replacemet procedure
Well the basic and most simple way to describe your answer which is very basic as well, is 1st disconnect your Neg battery cable from the battery then disconnect the pigtail from the sensor and then remove the sensor replace it with the new sensor and install is reverse of the removal. Of course depending on what sensor your replacing the job will be either easy or difficult depending on its location and access.
Dec 29, 2013 | 2003 Ford Taurus
1998 4 cylinder codep0404 what does it mean
Code 404 is a problem with the performance of the EGR valve.
Someone would need to test the operation of the valve and the sensor that watches it. You would need a shop manual for the procedure and basic tools.
Jan 09, 2013 | 1998 Pontiac Grand Am
I have a Chrysler Concorde 2000 LXI I with the Check Engine light on, so I ran it thru the computer scanner and it appears to say Fuel to Rich. What does that mean, and how do I fix it?
I agree with the comments posted from Jeremy, you dont have the code number?
A Fuel too Rich code basically means that an oxygen sensor in bank 1 detected a rich condition (too little oxygen in the exhaust). On V6/V8/V10 engines, Bank 1 is the side of the engine that has cylinder #1.
Here you have a description and test procedure: Repair/05/200o8c05/cip0171.pdf
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 09, 2012 | 1999 Chrysler Concorde
Started with out of colour ink - changed coluor ink cartridge. then came up with out of black ink - so changed the black ink cartridge now sais scanner failure when run through procedure to align...
"Scanner failure" basically means buy a new machine. Once the scanner fails on an all-in-one it will refuse to do anything. Replacing or fixing the scanner will cost much more than buying a new machine.
Sep 28, 2010 | HP PSC 750 All-In-One InkJet Printer
I would like to disasemble my laptops hinges but dont know how
What is the Model Series number?
There is a slight difference between the ZV6000, and ZX5000/ZV5000 series, for this procedure.
I want to give you the link to the Service Manual, (Free)
It won't describe, or illustrate the entire procedure of removing the Hinges, but will help for me to guide you.
The basic procedure is to remove all electrical sources first.
AC adapter (Charger), and Battery. Work on a table.
Follow Anti-Static Precautions before you begin.
Have a multi-compartment container, for the various screws you will remove, and label each compartment for where the screws came from.
(You can use a clean egg carton in a pinch)
Open the laptop, remove the Strip Cover,
(Below the LCD screen, and above the Keyboard. There are screws to remove from the bottom, so that the Strip Cover can be removed)
The Strip Cover will be popped up, and out, and there is a procedure for this.
(Start at one end, work your way along, basically)
The Keyboard is removed next. There is a procedure so you don't break the tiny keyboard connection cable.
There is a Thermal Cover to remove.
Next are the Wireless Antenna cables, and Display cable.
There may also be a Display Ground cable.
Screw covers for the hinges are removed from the back. The hinge screws are removed next.
The above is a General, Basic, set of procedures.
Advise do not follow it.
It's just to give you a basic idea of what is entailed.
If your problem Does Not relate to the HP Pavilion ZV6000, ZX5000, or ZV5000 series of laptops, state what laptop manufacturer, and model series it is.
(State in a Comment)
Jul 02, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
What does code ccd mean on overhead display 1997 dodge ram 2500 diesel 4x4 automatic?
It means "Crystal Clear Display" but in basic term its called a ccd bus, basically the OH console module is not communicating with body control module so you want to check power and ground pins or you just might have a bad module, sorry.
A self-diagnostic test is used to determine that the
compass mini-trip computer module is operating
properly electrically.
CCD communications test.
Following completion of these tests, the compass
mini-trip computer will display one of three
messages: “PASS,” “FAIL,” or “CCd.”
if the “CCd” message is displayed, the use of a
DRBt scan tool and the proper Diagnostic Procedures
manual are required for further diagnosis.
Jun 30, 2010 | 1997 Dodge Ram 2500 Club Cab
What is the basic difference between c and c
There are many differences between C and C++. Basically we have 5 OOPs concept which is followed by C++ a)Inheritance b)Polymorphism c)Encapsulation d)Abstraction e)Object C is a procedural language which does follow polymorphism and inheritance concept. Major one are as follow 1)C is data oriented and C++ is object oriented language.This implies C is inefficient in handling real world problem as there is no class concept present. 2)C uses top down approach and C++ uses bottom up approach. 3)There is no concept of inheritance in C. 4)C++ have concept of dynamic memory dispatch,which is not supported by C 5)C is function oriented while C++ i,Function are building blocks of C while objects are building block of C++ program 6)C++ have function overloading but C dont have. 7)C++ also have concept of namespace. 8)C++ have reference variables but C dont have it. 9) Standard input,output function aree different in both languages. 10)C++ is free form language means we can declare variable at any place but in C we can declare only at starting of main block.
Jun 18, 2010 | Computers & Internet
Going into the control panel on my computer when i try to click on add/ remove programs. It states that i have an windows rundll32.exe. what does that mean and how do i fix it.
This is usually the sign of a major infection and means you machine will need professional help. Basically many modern threats attack the system and will disable things like Antivirus, Control Panel access, and the ability to add and remove programs from the system. Many times the threats have to be removed form outside the Operating System, in your case Windows XP.
As this is highly technical and will involve many tools and procedures to effectivly remove all the infections I suggest seeking a good local company.
Your other choice is to format and reinstall the Operating System from scratch.
Feb 23, 2010 | Microsoft Windows XP Home Edition
Flashing apple
The flashing question mark / picasso face means your com puter cannot find a bootable volume or start up disk. Basically, it cannot find your operating system to load. That could mean a few things. Mainly it means your hard drive has failed, and is not performing properly, or cannot be detected. It could also mean the bootsector of the hard drive ( where it wrote os x when it was installed ) has bad blocks or sectors, preventing it from reading the disk correctly. if the hard drive is anywhere from 3 -4 years old or older, all of these options are likely. YOu can try to power the computer on holding down the OPTION key. THis will boot your machine into start up manager. Also try this procedure with an OS X cd or dvd inserted. If you have another macintosh running 10.3 or later, that has a firewire port, you can boot the emac into target disk mode by holding down the "T" key. The other mac should be on , and hopefully the emac will appear on the desktop fo the other computer. THis allow you to hopefuly recover the contents of the emac.
http://docs.info.apple.com/article.html?artnum=58583
http://en.wikipedia.org/wiki/Target_Disk_Mode
Hope this helps, KEEP ME POSTED.
Jan 15, 2008 | Apple eMac G4 Desktop
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
