Question about Apple Power Mac G4 Desktop
If I shut down system it will not start again for a few days. Then I have to push switch on tower and monitor at the same time
If I only push one power switch harddrive stops when switch is released
    Problem Solver:
  • 10 Answers
It sounds as though you may have a power supply going bad. The photo that accompanies your question is a G4 MDD. Is that the exact computer you have? If so, the power supplies are known to go bad on these specific machines. I had to replace my power supply last year. I would suggest - if your Mac is a MDD - doing a search on that topic. I found very good help at the Apple forums. If you determine the power supply is the culprit there is a gentleman in Austin, Texas who rebuilds power supplies. He sells through ebay and offers a very good and fair deal. His ebay ID is baltimora2000. That's who I got mine from and it is still running well after over a year of use. Hope this helps you out.
Posted on Apr 02, 2014
Monitor immediately goes to sleep. Tower shuts down from unplugging it.
have you tryed starting up in safe mode to see if you can get into your windows?
Apr 09, 2015 | HP Pavilion Media Center TV m8400f...
My tower will not power "on" I shut-down the
Remove the power cord.
Locate the 120V / 240 V ac selector switch. (within 4 inch from the power inlet)
Move it back and forth few time.
Make use it's set to the correct voltage selection.
Reconnect power cord and power up.
===== This AC selector switch can get shifted and set to different position.
Jul 28, 2011 | Acer Aspire™ T180 PC Desktop
I have set the screen resoloution to high for my monitor and now get a message saying "screen resoloution to high set to 1680 x 900" but cant reset it as all i get is the message and a blank...
First try shutting system down, unplug tower for 1 minute and restart. Give it time to come up and if that doesn't work, shut it down again and try to start in "safe mode" do you get any screen at all? If you can start in safe mode try going to "control panel'", "device manager" then "personaliztion", and adjust your resolution. If you can't adjust your resolution in safe mode do a "system restore" back to when monitor worked.
Apr 04, 2011 | Computers & Internet
My furnace stopped working. It'd start up shut down start up shut down all in the matter of seconds. Then would fire up and work. it did this maybe once every couple days then it stopped all together. ...
Replace pressure switch. If you blow any air into the pressure switch it has been damaged,check air ports for debris by looking never ,never blow on air switch they work on a very small pressure or vaccum,where your breath is to much pressure and also loaded with unwanted humidity.
boilerman56
Mar 04, 2011 | Goodman GMS90703BXA Heater
Pc won't boot ...
it seems to be an issue of a loose Hard drive connection.. you can open up a tower and re-connect the cable.
Feb 25, 2010 | HP Compaq Presario SR2150NX PC Desktop
Monitor will not turn on including power switch
I suspect the power supply for the monitor. Try a power supply from a working monitor. If you have a used computer store nearby, take your power supply to them and try it on another monitor.
There is no need to turn off a monitor using its power switch. Monitors automatically go into standby mode when they are not receiving a signal. In standby mode they use less than one cent of electricity per day. If saving electricity is your goal, raise the temperature in your home by a degree and run the air conditioning less.
May 17, 2009 | Dell Computers & Internet
Computer has shut down and can not re-start
The Dell 8300 does not use industry standard parts. You need Dell specific parts in order to replace the fan. Here is a link to a replacement fan shroud assembly for your Dimension: http://www.discountelectronics.com/index.php?l=product_detail&p=845
You may be able to find cheaper if you do a Goggle search and dig deeper. Hope this helps & please take a moment to rate this solution. Thanks.
Mar 14, 2009 | Dell Dimension 8300 PC Desktop
Tower intermittently loses power
i think you have a problem in you power supply sir try changing it or try separating your monitors source of power.
Dec 10, 2008 | Computers & Internet
Compaq presario sr1115cl wont power up
dont u dare ever use 220 line on thes eon usa power u blow it ever time u turn it on at 220 v dont u dare do that not no reset switch erther u must now buy new power supllly ok
Oct 12, 2008 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
Apple Power Mac G4 Desktop Logo
55 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
