Question about HP Office Equipment & Supplies
Printing in color
In installed new tricolor cartridge but my hp deskjet 5650 does't print in color. Why?
    New Friend:
    Problem Solver:
  • 6 Answers
Check cartridge touch point and clean this
Msquire
Posted on Apr 01, 2014
Joed911
  • 4338 Answers
SOURCE: I have a HP 7410, every time I print I get three error messages.
Perform a semi-full reset on the all-in-one by following the steps below
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find the hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
8 Allow the all-in-one to re-initialize. This may take a minute or two.
9 If prompts appear in the all-in-one display to set the front panel language and country settings, perform the steps to set this information.
Let me know if this helps.
If it doesn't, I will research it further. If it does please rate it.
Joe
Posted on Nov 21, 2008
  • 990 Answers
SOURCE: HP DESKJET 5650 - DOES NOT PRINT ON ANY PAPER
Hi dear; When you put in the new cartridge ,did you removed the plastic seal(tape)?
Posted on Dec 29, 2008
SOURCE: HP Deskjet 4280 does not print. 'E' error on Control panel button
I had the same problem. It was solved once I bought an original color cartridge. Refilled cartridge seems not to work on this printer. Glad if it might help.
Posted on Jun 18, 2009
beboybutiki
  • 126 Answers
SOURCE: i have a hp desk jet 5440 i put i a new tricolor
Make sure that your buying a new Tricolor as the same and Geniune too.
Only solution to this is put it properly inside your printer.
At first sometimes New Cartridge are being initial & calibrate by your printer before it works.
Power Off first your printer and put the cartridge inside. If the problem still exist then put back again your old cartridge and identify what is the problem occur before you put a new cartridge on it.
Posted on Sep 23, 2009
CW Oly
  • 240 Answers
SOURCE: hp officejet v40. new cartridge but missing blue when printing
Sounds like your cyan print head is clogged. You can try to get it flowing yourself by rubbing the print head with a wet paper towel. If you press the print head on a dry paper towel you should see three distinct lines of color. If you still don't see the cyan, try letting the print head rest on the wet paper towel on a surface that ink can be cleaned up from or one you don't care about staining. If the cyan still won't flow, you should go back to where you purchased it and return it for a new one.
Posted on Jan 12, 2010
Print cartridge installed incorretly
Its not reading the cartridge. There's no way around it, you have to buy a new cartridge. It happens. Especially when you refill cartridges.
Sep 24, 2012 | HP 78 Tricolor Ink Cartridge C6578dn...
I have a new HP TriColor Cartridge and my printer will not print anything except black. Also have a flashingterdrop light on left side. What is the cure?
Hi. it actually sounds like something is not contacting with the cartridge. remove the cartridge and inspect the contacts inside the printer, the ones that touch the front of the colour cartridge, for dry ink, dirt or dust, use a cotton bud dipped in boiling hot water to remove any ink on the contacts, make sure the printer is off before doing this any make sure no water is left inside when you switch it back on.
I hope this helpsRegards
Grant
Nov 11, 2011 | HP DeskJet 6540 InkJet Printer
It is reading Print cartridge problem(tri-color)
if it is not yet empty try to remove and reconnect the cartridge, if same error, try printing without the tricolor cartridge. if that works, you need a new tricolor
Mar 14, 2011 | HP Officejet 5610 All-In-One InkJet...
My HP Deskjet 5650 will not print in color even though i have installed a new cartridge yet the test page is in color??
Just check your printing property and choose color print and apply the settings and then ok.
Good Luck
Feb 26, 2011 | HP DeskJet 5650 InkJet Printer
The printer's black ink cartridge won't print without the Tri-color print cartridge
Most of the HP printers are designed to allow printing onlywhen all cartridges are installed and
have ink.
Install a new tri-color ink cartridge and printing will continue as usual.
My printer, which is HP, does the same thing as yours, until I replace the empty cartridge,
printing stops.
Feb 22, 2011 | HP DeskJet 3745 Printer
I just installed a new color cartridge for an HP 5650 Deskjet printer but it only prints in black. I'm printing from a MacBook, OS 10.6.6
Hi, Try printing whatever you were wanting to print but click the drop down arrow right next to the printer selection tab. Then you should see a drop down menu about halfway down the menu, click it and select print settings. You should see another drop down menu called color, just click it and change it from grayscale to color.
Hope this helps, Justin
Feb 13, 2011 | Apple MB985LLA 15.4" Macbook Pro Notebook...
HP Deskjet 5550 quit printing red color. Installed new color cartridge HP57. Quit printing red again after 5 pages. Is it a printer problem or cartridge problem?
Have you check your color cartridge if they are properly installed.
Make sure your are not using a refill cartridge.
Replace your tri-color cartridge with original an HP tri-color cartridge.
Aug 26, 2010 | HP DeskJet 5550 InkJet Printer
Hp 5650, black ink not working
try cleaning the copper contacts of the cartridge and the inner area of the slot where the cartridge goes in..
Also go to the Printer & Faxes under Control Panel and open the printer's properties..select Printing Preferences >> Paper / Quality >> under the color section check if "print in greyscale" is checked..
it shud not be checked...
save changes and try to print
Oct 01, 2008 | HP DeskJet 5650 InkJet Printer
Color printing in hp 3745
i need driver deskjet 3744
Sep 29, 2008 | HP DeskJet 3745 Printer
One color missing
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Dec 22, 2007 | HP DeskJet 5650 InkJet Printer
76 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
