Question about Huffy 12" Minnie Mouse Bowtique Bike
Sweetie bow activity trike rear wheel construction issues
Hammered/tapped one wheel into place as instructed. Second wheel won't 'click' into place. At a loss on how to get the bar to click in.
Sunny MC-300TKA has a severe front end wobble
Hi, Clemente and the usual suspects are:
1. Improperly loaded motorcycle. Non-standard equipment on the front end such as heavy radio receivers extra lighting equipment or luggage tends to cause unstable handling.
2. Incorrect air suspension pressure.
3. Damaged tires or improper front-rear tire combination.
4. Irregular or peaked front tire tread wear.
5. Incorrect tire pressure.
6. The shock absorber is not functioning normally.
7. Loose wheel axle nuts. Torque to recommended specifications.
8. Excessive wheel hub bearing end play.
9. Improperly vehicle alignment.
10. Steering head bearings improperly adjusted.
11. Tire and wheel unbalanced.
12. Rims and tires are out-of-round or eccentric with the hub.
13. Rims and tires are out-of-true sideways.
14. Loose spokes.
15. Shock absorber improperly adjusted.
16. Worn engine stabilizer links.
17. Damaged rear engine isolation mounts.
18. Swing arm pivot shaft improperly tightened or assembled.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
***** Wobble How To Fix ***** Wobble KevinsOffroad com
http://www.spyderlovers.com/forums/archive/index.php/t-51337.html
Sunny Trike Scooter MC D150TKA Assembly instruction part 3 the end
Sunny TRIKE 300cc
MC D300 TKB Sunny 300cc Roadrunner 3 wheels Trike Motorcycle at...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 24, 2014 | Sunny Motorsports Sunny Powersports...
How to repair locked up rear end on trike motorcycle
you could lift on wheel with a trolley jack and spin it.
if you can do it on either side then it sounds like your transmission is jammed or some kinds a parking brake is applied.
it might sound dumb, but it look likes your trike is in gear?
Is the handbrake on the transmission or the wheels hubs?
Can you provide more details on the trike?
make, model... And maybe what happened.
thanks, Franck.
Sep 10, 2014 | Motorcycles
Smart trike aged15months -36mnths , I assembled it putting on wheel locks etched only to discover I put bar in the wrong way ( space for screws didn't match up) I'm blaming the poor instructions!! Now...
Lift up back. End and hit the wheel on each end where rod goes threw use the wheel too. Push the pressure fit washer use a long punch with tap around the end or use a rag so u don't mark. The wheel up good lucl
Aug 31, 2014 | Cars & Trucks
Smartrike front wheel won't turn with pedals once on the ground
Old question but I just needed the answer and figured it out. On one side of the wheel there is a disc with two arrows, line this arrows up with the arrows on the wheel and push the disc into the wheel until it clicks into place. Pull it out to convert back to a stroller.
Nov 29, 2012 | Kent International Smart Trike Sport...
Trike conversion issues
hi
the abs stays on
because it is a trike not a bike
ie: the abs is there to detect 2 wheels
it now has 3 wheels and two brakes that are not standard
the preload adjuster
i do not know what you mean by this
as we do not get this sort of gadget in the uk and the translation may be different
is it on the braking side or the acceleration side
Jul 02, 2012 | 2008 Honda GL 1800 Gold Wing
I need instructions for the meridian 3 wheel trike...the ones in the box stink
This comes up frequently. In my tips and tricks page is a link to the www.schwinn.com instruction manual download page. But they are most likely the same instructions you have already got. There are no other specific instructions for building.
So what is the best method of assembly? Not much beyond taking the project to your local bike shop and having them assemble it, Fees vary on this but it is the most effective method to make sure the bike/ trike is assembled correctly and safe to operate. Or you can find a friend that has some mechanical knowledge and maybe even owns one and can help.
Poor instructions are the norm, sorry. If you get the majority of the bike together you can post specific questions along the way and the community may be able to help solve that specific issue.
Apr 06, 2011 | Schwinn Meridian Adult 26-Inch 3-Wheel...
I inbstalled a trike kit on my ultra classic and the steering is terrible. I have been told I have bump steering. How do I resolve this. Bill
Who made the kit? Is it a true trike kit or one of these kits that leaves the original swingarm and rear wheel on and simply adds two more wheels to the rear. Either way, I'd contact the manufacturer of the kit and see what they had to say. It sounds like the rake on the front end has changed or the center of gravity has changed.
Good Luck
Steve
Mar 22, 2011 | 2000 Harley Davidson FLHTCUI Electra Glide...
Hi, Not a novice in the assembly dept., but the Schwinn easy steer trike is a KILLER! Should I use the excuse that this is the 4th assembly I've done today? #!. Do the smooth-top screws hold the seat...
Take a little trip to www.schwinn.com They have instruction manuals, videos and most importantly a customer service line with someone that can walk you through their specific product.
It should not be that difficult for someone who is not a novice to put the trikes together, something is definitely wrong. Double check on the schwinn site that you have the correct assembly manual and parts list. You still have time, don't panic yet.
Dec 18, 2010 | Schwinn Cycling
2010 1800 Honda Goldwing Trike clicking noise front wheel
Hi, Robert I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
1. Bearings---SCREECH
2. Belts---CHIRP
3. Brake Rotors---BUZZ
4. Cam Chains---CLICKIT
5. Clutches---CHATTER
6. Cylinders---PING
7. Fairing Panels---WHISTLE
8. Fenders---SCRAPE
9. Fronk Forks---Plunk
10. Fuel pumps---WHIRR
11. Gears---WHINE
12. Head Gasket---HISS
13. Hydraulic Lifters---TAP
14. Instrument Clusters---BUZZING
15. Kick Starter---GRINDS
16. Pistons---SLAP
17. Power Valves---CLINK& RATTLE
18. Radiators---GURGLE
19. Rear Chains---RATTLE
20. Rear Shocks---SQUEAK
21. Relays---CLICK&BUZZ
22. Shaft Drives---WHIRR
23. Shifting Trans---CLUNK
24. Solid Lifters---TICK
25. Speedometers---bzzz
26. Starters---CLICK
27. Rods Go---KNOCK-KNOCK---who's there, it's me "*****"
clicking noise apply rear front brake GL1500 Information Questions...
Diagnosing Front End Noise on Honda Goldwing GL1800
Honda GL1800 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda Goldwing GL1800 Owner Manual
Aug 19, 2010 | 2008 Honda GL 1800 Gold Wing
Huffy 12" Minnie Mouse Bowtique Bike Logo
166 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
