Hi Lilliburger,
If you haven't install google chrome yet here is the link for you to do it.
Download and install Google Chrome
If you already have google chrome and wanted to set it up as your start up page I have another link for you. Hope it helps
Set your homepage
SOURCE: Getting only google page from I E
check whether are you typing in address bar and then uninstall ie 8.0 from the add/remove programs and try to access it through ie 7.0
SOURCE: can't open google or yahoo search pages, i keep
Sounds like adware or spyware (any kind of badware in your computer) is the issue. Perhaps a simple problem on the browser configuration is the issue.
You may try to download Firefox to see is you have the same problem. Have your computer updated (from the Microsoft Updates) and run the Malicious removal Tool (Click Start - Run - Type: MRT and press enter).
Good luck.
SOURCE: when using google search engine, after attaining
perhaps there's some issue with your system registry so you should use Reginout cleaner to fix this issue
Hi
Your are setted as that searchqu is your default search home page pls make sure to delete it through tools and internet options
Thank you
Harsha
Go to Control Panel, click Programs (software).
Uninstall "Browser Manager" +
"Bprotector" + "Object Installer" + "Babylon Toolbar
on IE"
Open Google Chrome and click on the "Customize and control Google Chrome " icon by the right side of the address bar; click on Settings:
Click> Settings , choose the option "Open a
particular page or set of pages."
Click "Set Pages" on page Babylon and delete from
the list.
To change the search engine in Google Chrome, please follow
the instructions below:
Open Google Chrome on the "wrench" icon on the
right side of the address bar, click:
Settings> Under "Search", click
"Manage Search Engines ...".
If you
see "Babylon Search" as a standard (default), select please another
search engine as the default from (Google, Bing, etc.). Only then will you
Babylon You can remove by clicking the little 'X'.
For demonstration click on the follow link:
http://www.babylon.com/uninstall_search/chrome
