Question about Toshiba TW40X81 40" Rear Projection Television
Toshiba 50H81 - inputs are not providing color picture
The picture is fairly clear, but the image feed is totally black and white. I have tried all three video inputs and both colorstream HDMI inputs, but all have either this problem, or a distorted screen. I have tried different cables and 2 different Wiis to make sure its the TV. I have reset the image settings in the menu, and have messed with color controls and such. I can't seem to get the picture in color. The menu icons are in full color. And when I do the color convergence stuff, it is also in color- so I know the TV can do it.
  • Mike K
    Mike K Mar 31, 2014
    I should clarify: I just got this from a friend, who says it worked fine for her. And if I'm on the video feeds, there is color but the picture is very distorted. On the HDMI plugs is when the picture is pretty clear but there is no color.
    Sergeant:
  • 418 Answers
I would say problem with hyper board.(Dig video bd.)
Posted on May 09, 2014
Cpyles07
  • 56 Answers
SOURCE: Scrambled Picture/Snow Screen, has sound, can play DVDs through colorstream
I had this with a rca once. Can you hear a crackeling noise coming from the flyback transformer? My problem was just the wire was loose
Posted on Dec 06, 2007
  • 92 Answers
SOURCE: Toshiba 57H82 Blurry Pic on HD inputs except Xbox 360
Probably your G-Hyper board. You will need expert servicer and should cost about 3-400.00
Craig www.classtorations.com
Posted on Jun 08, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Toshiba 57HX81 is all wiggly and distorted (youtube video attached)
I don't know about that. Someone probably was rough with it and messed them up. You should have a technician look at it.
Posted on Jun 16, 2008
SOURCE: Redish distorted cable picture until I change input source and then go back to cable input
I have direct TV and I have the same problem also. It happens about 1 ot of 8 times. All I do is turn off the satellite receiver for a few seconds and turn it back on while the TV is left on. It works everytime. Don't drive yourself crazy with repairs and the like. It is just one of those things.
Posted on Jun 22, 2008
Slinteriors
  • 8617 Answers
SOURCE: color convergence messed up
you can get the convergence repair kit for your model that has both convergence IC and the six feed resistors at this link, The repair kit also has step by step instructions with pictures so you can do the repair your self. Heres the link.The 50H82 kit is the same for the 57H82, http://servicemanuals.vstore.ca/product_info.php/pName/toshiba-50h71--50h81-convergence-repair-kit/cName/convergence-repair-kits
Posted on Feb 01, 2009
Ps3 plays in black and white with av composite cable
Some newer TVs do not have the traditional "yellow" video input, known as an "AV" connection. Even without that input, you should be able to use the standard three-color Wii AV Cable that came with the system.
What to Do:
  1. Look for "component" inputs on your TV. These connections have a row of five differently-colored inputs (green, blue, and red for video, white and red for audio). If you have more than one set of component inputs, it's the first set that generally works with standard AV cables. Look for a set that has a green input with yellow around it, or the word "video" just above or below it.
  2. Plug the yellow end of the Wii A/V cable into this green "Y" input. Plug the white end into the audio "L" and the red into the audio "R." Leave the blue and second red holes open.
  4. Turn on your Wii console and set your television to the input select being used.
  5. If you are seeing the image from the Wii in black and white, try the following to get the image in color:
    • Cycle through your television's input channels (usually with the "Input Select" or "Source" button on your TV's remote control) to find the input select that has the image in color.
    • If you're only finding the image in black and white, you may need to switch the setting of the input select from a component signal to a standard AV signal. This can be done by:
      • An on screen menu option. This is often accessed by using the "Menu" button on the remote.
      • A button on the remote that switches between the standard and component signals. These can be labeled such things as "AV" or "Video."
Jan 28, 2018 | Haier HL22R 22 in. LCD TV
Toshiba 50H81 very dark, blurry picture on all inputs.
check if the problem looks zig zag looking or it its not present in the PIP window. If so this may be an issue with the hypermodule - you can google TV repair Kits to find parts.
Mar 27, 2012 | Toshiba 50H81 50" Rear Projection...
Picture is only clear on color steam 2 and shacky on every other input diferent equip. have been tryed
Possible that the input logic selector is faulty as there can be a digital gate failure.This can cause the input to be scrambled and so there is loss of sync. which can result in the poor picture. So it is important to trace the input, check using a signal feed to find the switching fault.
It can also be related to a fault in the video board but the fault points to this section as the video signal is clear otherwise.
Sep 27, 2011 | Toshiba 50H81 50" Rear Projection...
The sound does not work on my 50H81 Toshiba rear projection HDTV, when it's in the HD mode. It was working prior to being moved & was hooked up through a Bose surround system. The sound on the TV works...
Check to see if the comp inputs have a red and black audio input. Those must be connected, second go inside the menu and make sure the inputs match..good luck..
Mar 09, 2009 | Toshiba 50H81 50" Rear Projection...
Color convergence messed up
Feb 01, 2009 | Toshiba 57H81 57" Rear Projection...
Scanned Items or Copies all print in Solid Black
I assume that you mean color images are being produced in black and white. If that's the case, there's a document on the HP web site that shows you what to look for and provides solutions:
Color Image Prints in Black and White
Good luck.
Sep 13, 2008 | HP PSC 1610 All-In-One InkJet Printer
Sony KV-27TW75 Black and White Picture
this is usually due to bad ground check cable line comming into tv and
CHECK/RESOLDER CONNECTIONS IN TUNER WHERE CASING IS SOLDERED TO PCB NEAR 4TH FEED THRU BACK FROM ANTENNA INPUT
Feb 04, 2008 | Televison & Video
Wavy, jumpy picture, ghosts, occasional color loss/change---you name it!
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 12, 2007 | Toshiba 50H81 50" Rear Projection...
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Hitachi pj-tx100 black and white picture when using s-video
s-video carries luminance and chromanance. In simple terms, luma provides a a black and white picture, chroma the color data. without chroma, you get no color. Either - the cable is bad (usually in the form of bent/broken pins in the connector ends - the source device is bad - the projector input is bad
Sep 21, 2006 | Hitachi PJTX100 Multimedia Projector
Toshiba TW40X81 40" Rear Projection Television Logo
108 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
