Question about Cycling
Is the fuese on my jonway dcooter cause everythimg is dead and its not6 the battery
Elect
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 70 Answers
Try to connect same voltage rated bulb directly to ur battery it should ignite with full intensity if it did so baterry is good. if baterry is good check fuses, wireing and switches.
Posted on Apr 06, 2014
Jonway 125 will not start
Hi, Koos and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the enrichner.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. Fuel injectors stuck open.
13. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a cursory reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
14. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
15. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
16. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
17. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
18. Faulty neutral, clutch lever, or kickstand safety switch.
19. Faulty fuel pump or fuse or relay.
20. A stuck bent or burnt valve.
21. Tilt sensor needs a reset.
22. Security system not disarming alarm needs a reset.
23. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
cranks but wont start
Scooter Troubleshooting Scooter won start All about Scooters
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
parts JONWAY GT 125 parts jonway aztral parts jonway js120 125cc 150cc...
http://absolutelyscooterparts.net/pdf/CGEN_dawg_scooter_manual.pdf
Aug 15, 2017 | Jonway Motorcycles
Can I add a ground wire to the front of starter on yy250t jonway scooter
Hi, Becky absolutely as long as the negative battery cable is grounded to the frame or engine for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Jonway motorcycle manuals
http://www.partsprousa.com/?vehicle_type=Scooter&brand=Jonway&brand_model=YY250T-19B&srch=2#searcharea
Free Jonway Motorcycle Service Manuals for download
Jun 14, 2016 | Jonway Motorcycles
2014 Jonway YY250T 125cc Scooter..What type of carburetor goes in this scooter?
Hi, Terry I believe it is a WHYJO or ASIN B008AD23FO for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Amazon com Chinese Scooter Parts GY6 Jonway NST YY250T Carburetor...
Chinese Scooter Parts GY6 Jonway NST YY250T Carburetor Unimerc Amazon...
Service Support China Jonway Group
May 21, 2016 | Goes Motorcycles
150 quad has no power to start it is totally dead
alot of times a bike with a totally dead battery will not start . the fuese are in a plastic holder behind the seat useally around the solenoid on the side , good luck
Dec 03, 2014 | Cars & Trucks
I replaced the alternator truck will not keep a charge or stay started
did you have the battery load tested?if good check all conections and
fueses
Aug 29, 2012 | 1997 Mercury Mountaineer
Audi battery replaced whit new battery electic windows not working tryed fueses still no joy
im not sure what year or make this audi is but some will loose the programing and need to be reprogramed, the dealer does this, but if the windows had a problem before the battery replacement then there good be a problem with the driverdoor window switches, if that switch goes bad then no window will operate, pop switch up and test for power to switches, also make sure all wires are connected back on to the battery and that nothing was pulled apart. good day.
Jul 30, 2011 | Audi A4 Cars & Trucks
My son has a 1992 Barina and it is completly dead. Battery has been tested and is fine. Was going well and then not driven for couple of days and now nothing
It has a short somewhere, the easiest way to find a short is to charge the battery, put an volt meter on the battery, then start pulling fuses in the panel in the car and watch for a rise in voltage. make sure everythimg is turned off. once you get a rise in voltage that will tell you what area/s to look at. if one fuse runs several things, install fuse and unplug one at a time and watch for rise
Jun 14, 2010 | Cars & Trucks
I HAVE A2000 FORD RANGER 4.0V6 AND IT WONT START I HAVE CHECKED ALL FUESE WITH A METER CHANGED BATTERY STARTER IGNITION AND ELECTIC IGNITION BOX UNDER STEERING COLOUM EVERY THING COMES ON BUT WONT START OR...
There are braided metallic bands that help ground your engine. They are usually located at the back of the engine going to the firewall. If they are frayed or disconnected in any way it could be causing the starting problem. Check all your wires for loose connections or corrosion. Hope this helps. God bless!
Sep 30, 2009 | 2000 Ford Ranger SuperCab
Cycling Logo
63 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
